17 Inch Wheels *SOLD OUT*
Postby Stevil_Knevil » Sat Dec 31, 2011 5:27 am
Hi there,
I have several 17 inch wheels for sale.
The rims are 36H FEMCO 1.20x17 chrome plated steel (that's 40+ mm wide folks!). Spokes are 12 gauge (2.58mm dia.) Stainless Steel laced 2-cross to a 100mm wide, disc compatible QR alloy front hub. Building a very strong, hub motored wheel should be pretty straight forward if you cut & thread these spokes to length, or just plop it in your disc compatible (QR dropout) fork as is!
Yes, DOT compliant. Cost is 50 bux each +shipping from NorCal ..you lucky people 8)
ERD = 418.5 mm
Spoke Hole Diameter = 5.14mm
Spoke Diameter = 2.58mm
Nipple Diameter (before the flare) = 4.6mm
Weight = 4.25 pounds
Hub Flange Diameter = 58mm
Hub Flange Width (C->C) = 58mm
Bearings = Sealed cartridge (made in Japan)
EDIT: Measurements and details in bold type added/fixed.
Last edited by Stevil_Knevil on Sat Mar 31, 2012 6:01 pm, edited 3 times in total.
Stevil_Knevil
Re: 17 Inch Wheels
Postby drewjet » Sat Dec 31, 2011 8:00 am
Is that QR, or is it a 3/4" through hole? Can I see a pic of the other side of the hub?
ImageSuzuki SP200, Mars Brushless, 300 Amp Kelly Controller,(18S12P) http://www.evalbum.com/1511
3220 Mountain Bike viewtopic.php?f=28&t=16705&p=244317#p244317
Suzuki Lipo Upgrade viewtopic.php?f=10&t=23088&p=335986#p335986
Race Bike viewtopic.php?f=3&t=32486
drewjet
Re: 17 Inch Wheels
Postby Stevil_Knevil » Sat Dec 31, 2011 8:11 am
Hi drewjet,
Yep, it is a QR axle..
..forgot to pull the axle savers for the first pics :oops:
Stevil_Knevil
Re: 17 Inch Wheels
Postby drewjet » Sat Dec 31, 2011 8:24 am
AH thanks.
What is the dropout width?
Looking at this side, it is hard to see from the pic, do you think I would be able to bolt a flat plate, for a sprocket adapter, against it by drilling through the hub with say 6 bolts. This is going to be for Meaga power, hopefully north of 20KW
drewjet
Re: 17 Inch Wheels
Postby Stevil_Knevil » Sat Dec 31, 2011 8:38 am
Standard 100mm front dropout width. >20KW? This wheel is practically Luke-proof (tm) :lol:
Stevil_Knevil
Re: 17 Inch Wheels
Postby drewjet » Sat Dec 31, 2011 8:46 am
"Luke Proof" That's exactly what I need!
Maybe you can get me some closeups of the non brake side of the hub from a few different angles. Do you have a link to info/tech drawings on the hub?
drewjet
Re: 17 Inch Wheels
Postby Stevil_Knevil » Sat Dec 31, 2011 9:05 am
If you need standard 6-bolt ISO rotor (chainring?) mounts on BOTH sides, I also have a few of these wheels with goofy 128mm wide hubs..
..same $
Stevil_Knevil
Re: 17 Inch Wheels
Postby Stevil_Knevil » Sat Dec 31, 2011 9:29 am
I can take a few more pictures and measurements if you need. Sorry, no links to tech drawings of the hubs as I have no idea who made them. I do know they are NOS wheels from the '01-'02 Voloci electric motorbike:
Stevil_Knevil
Re: 17 Inch Wheels
Postby drewjet » Sat Dec 31, 2011 3:23 pm
Now you got my attention. HMMMM
Do you have the weight of them?
Guess on shipping a pair to 32750?
drewjet
Re: 17 Inch Wheels
Postby NeilP » Sat Dec 31, 2011 3:54 pm
What tyres do they take? ?
What is the rolling diameter?
ERD? if I just want a rim to lace direct to a hub (5404)
Diameter of the nipple holes...will it take 10 gauge spokes?
Do spoke holes have inserts? or just straight holes in the rim?
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
10 GW
10 GW
Re: 17 Inch Wheels
Postby amberwolf » Sun Jan 01, 2012 1:40 am
Somehow I doubt I could fit either of the 17" tires in the below links on there...what do you think?
http://endless-sphere.com/forums/downlo ... p?id=72283
http://endless-sphere.com/forums/viewto ... 54#p508254
I'm pretty sure they're WAY too wide to squeeze into that rim. :(
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Re: 17 Inch Wheels
Postby The Mighty Volt » Sun Jan 01, 2012 5:42 am
Looks big for a 17" wheel, is it 17" Motorbike?
The Mighty Volt
Re: 17 Inch Wheels
Postby drewjet » Sun Jan 01, 2012 6:43 am
drewjet
Re: 17 Inch Wheels
Postby Stevil_Knevil » Sun Jan 01, 2012 5:23 pm
Don't have my scale handy, but I would estimate the front wheel at ~5 pounds. Cheapest shipping Option by USPS looks like 25 bux, and ~1 week to your door. I will get solid numbers for you tomorrow.
NeilP wrote:What tyres do they take? ?
-These are moto rims, measured at the bead.
-A 2.50-17 Michelin Gazelle would be a good fit, ~23 inch/584mm diameter.
-The display in my vernier caliper just went blank as I was trying to establish ERD and nipple hole diameters :roll: will have those numbers when I get a fresh cell later today, Neil.
-No inserts. Spoke holes are in a dome shape which will allow a few degrees of angle without tweaking the spoke at the nipple.
amberwolf wrote:Somehow I doubt I could fit either of the 17" tires in the below links on there...what do you think?
Sorry AW, 2.50 is proly the widest practical tire for these rims, width at the bead is ~1.35".
The Mighty Volt wrote:Looks big for a 17" wheel, is it 17" Motorbike?
Yes, DOT approved 17" Moto wheel :D
Those should all work well, Drew. I really like the tread on the Michelin Gazelles, reminds me of a flat-tracker..
Stevil_Knevil
Re: 17 Inch Wheels
Postby Stevil_Knevil » Sun Jan 01, 2012 9:34 pm
*Edited the OP with accurate measurements*
More pics?
This is what my C-lyte Hx motor shell looks like placed over the center of the wheel. Maybe possible to pull off a 1-cross lacing pattern?
'Domed' shape that the nipple fits into. Spoke Hole Diameter = 5.14mm
Japanese sealed cartridge bearings! I.D. (measured @ threaded inner axle O.D.) is ~11.84mm.
Stevil_Knevil
Re: 17 Inch Wheels
Postby drewjet » Fri Jan 13, 2012 1:55 pm
Got my wheels in Steve. These are Very Nice!
I think I am going to regret not buying a few extra.
drewjet
Re: 17 Inch Wheels
Postby Stevil_Knevil » Fri Jan 13, 2012 11:44 pm
Glad you like them Drew! They look Even Nicer wrapped in a Gazelle..
:D
Stevil_Knevil
Re: 17 Inch Wheels
Postby NeilP » Sat Jan 14, 2012 3:10 am
Thanks Steve. I have been looking for some like this locally. Looks like a t Honda C90 moped has them...actually slightly narrower..front on the Honda is 17x1.2 i think
Since no inserts, I can at least drill out to whatever nipple diameter I need
As for the question of a single cross pattern..highly unlikely that is going to work. A single cross pattern on even a 26 inch MTB wheel with an Xlyte 5xxx motor gives an almost un acceptable spoke exit, it ain't going to work with spokes as short as would be required
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Re: 17 Inch Wheels
Postby Stevil_Knevil » Sat Jan 14, 2012 4:12 am
NeilP wrote:As for the question of a single cross pattern..highly unlikely that is going to work. A single cross pattern on even a 26 inch MTB wheel with an Xlyte 5xxx motor gives an almost un acceptable spoke exit, it ain't going to work with spokes as short as would be required
All of the MTB rims I have worked with practically force the nipple to point at the center off the wheel, hence the inevitable, extreme spoke tweek when attempting even a 1 cross pattern on the 5 series motors. It appears that the dome shape where the nipples fit in these rims do direct the spokes a few degrees off center..
.. enough to pull off a 1 cross? I am feeling 95% confident it will work, but then again, empirical evidence rules!
This should be fun :)
Stevil_Knevil
Re: 17 Inch Wheels
Postby drewjet » Sat Jan 14, 2012 7:54 am
My Gazelles should be here by mid next week.
What is the inflated outside diamater of the gazelle?
drewjet
Re: 17 Inch Wheels
Postby NeilP » Sat Jan 14, 2012 2:54 pm
I'l wait and see what yours works out like before I buy my spokes then :)
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Re: 17 Inch Wheels
Postby Stevil_Knevil » Sat Jan 14, 2012 11:44 pm
drewjet wrote:My Gazelles should be here by mid next week.
The inflated height of a 2.50 Gazelle mounted on one of these rims is a hair under 22 inches.
Edit: fixed (measured starting at 1 inch and forgot to add it back :oops: Sorry!)
Stevil_Knevil
Re: 17 Inch Wheels
Postby Stevil_Knevil » Sun Jan 15, 2012 12:20 am
I put together a mock-up using spokes taken off another wheel and my Clyte HT shell. I only did one side of the motor and rim, but it certainly looks like a 1 cross pattern is doable!
This should also be the case for any of the original - and newer, 5-series C-lyte hubbies -- as well as CroMotors!
Stevil_Knevil
Re: 17 Inch Wheels
Postby NeilP » Sun Jan 15, 2012 3:08 am
What sopksa re they12 gauge?or bigger? I use 12 g on my current build but was going to go for 10 on this 5404 in a 17 inch hub.
With that dimpling in the rim, you may well be correct, the angle of spoke in relation to the dimple looks ok on that last pic.
How snug are those nipples in the holes? wold I get a 10 gauge nipple in there?
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Re: 17 Inch Wheels
Postby Stevil_Knevil » Sun Jan 15, 2012 4:02 am
These are 12 gauge spokes and they are a very good fit in the motor's flange holes, as are the nipples in the rim.
These rims would definitely need drilling to accept nipples for 10 gauge spokes ..will 10'ers fit in your 5404 flanges?
Stevil_Knevil
Next
Users browsing this forum: No registered users and 6 guests
