Still available here:
Stanton Inc.
And here:
Chain Reaction Cycles.Com
marty izip wrote:Hi, Just built up an Izip using the 16 tooth mod. What a difference to standard. Thanks for the effort you put into the detailed description and photos.
For information my standard free-wheel came off using a BMX 4 lug removal tool (it had the notches already in) so no grinding.
gmonster2 wrote:Hi Dark Angel thanks for the info. I got a freewheel from chain reaction $17 posted to Australia came in one week, so all good.
My Izip TrailZ I bought in 2010 the freewheel had no notches! Does it only work if u grind notches in the innermost circle and turn? I got the inner part turning where the 2 holes are and the wording that is turning clockwise but it still wont come off?
I will try grinding at a friends tomorrow but I don't understand how your second method with the park tool worked as that seems to be on the holes and wording part which is what I have turning around no problem.
also where does the washer go?
and yeah the original freewheel does feel like its full of tar the new southpaw is heaps better..cant wait for a souped up test run..
thanks for any help mate...
jateureka wrote:Great write up on a relatively easy and cheap upgrade to the Currie eZip and iZip.
There's an explanation for removing a freewheel here but your methods sound good http://www.electricscooterparts.com/freewheelclutchremoval.html
DrkAngel wrote:I ran into a 2009 EZip Trailz, that required motor mounting bracket "adjustment".
Currie XYD-16 Motor
I'm not sure how common this situation is, does not seem very frequent.
Out of 20+ responses, only 1 other person, has mentioned encountering this "problem".
slats wrote:Thanks Drkangel, I,m going to try this with my ezip. I can only get the Fat southpaw ATM , would that make any difference?
Slats
slats wrote:Drkangel, Sorry, i just looked again and it is not 1/8th . It is 3/16th, so it doesn't meet the specifications. I'll keep looking . http://www.chainreactioncycles.com/Mode ... elID=54098
Steve
Users browsing this forum: Bing [Bot], Holocene, Joppo, MAGICPIE3FOCUSPOWER and 15 guests
