Letting the cat out of the bag...........
Re: Letting the cat out of the bag...........
Postby recumpence » Sun Jan 08, 2012 1:07 pm
deVries wrote:
johnrobholmes wrote:What a trick way to incorporate the mounting foot into a tensioning device!
Even more trick is how to get chain alignment? :?: :idea:
Do you see and understand how it can move laterally to get chain-line alignment? :?:
Use spacers or is there a tracking slot to move it? :?:
Lateral adjustment for sprocket alignment is accomplished by loostening the mount foot clamping screws and sliding the whole jackshaft bearing tube left or right in the assembly. In my mock-up, you cannot see what I mean. But, the bearing tube will be about an inch longer than what is in the mock-up. For chain alignment, the whole jackshaft is moved side to side to make infinate alignment adjustments. :)
Thanks for pointing out something that could be easily overlooked in something like this. Do not be afraid to make suggestions or ask questions. It is not out of the realm of possibility that I could ovelook something or not thing of something that would be a good addition to a given design.
Also, yes, I have looked into lazer cutting and water cutting. Those are great options for 2D work.
The freewheeling crank has been boiled down to one machined part ------ the sprocket adaptor. I, ironically, looks much like my disc brake/chainring adaptor. I do not have any CAD drawings to show. I will wait to show the finished part.
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
10 GW
10 GW
Location: On Earth right now. That can change at any time, though..........
Postby johnrobholmes » Sun Jan 08, 2012 4:20 pm
recumpence wrote:Lateral adjustment for sprocket alignment is accomplished by loostening the mount foot clamping screws and sliding the whole jackshaft bearing tube left or right in the assembly.... the bearing tube will be about an inch longer than (the drive foot and motor plate). For chain alignment, the whole jackshaft is moved side to side to make infinate alignment adjustments. :)
Matt
This is an extremely easy job too, it does not take but mere minutes on the initial installation.
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
10 GW
10 GW
Postby MitchJi » Mon Jan 09, 2012 4:00 am
Hi Matt,
recumpence wrote:Do not be afraid to make suggestions or ask questions.
You might want to either include or offer as an option a CA set to force pedaling at startup as described here:
http://endless-sphere.com/forums/viewtopic.php?f=9&t=34331&p=514207#p513941
mdd0127 wrote:The slipper clutch is set to prevent too much wheelie action and the acceleration is brutal.
The bike must be pedaled up to 4 mph to engage the drive to make life easier on the motor controller.
Mitch wrote:I'd like to know how your drive forces 4 mph pedaling to engage the drive and how that works in conjunction with the slipper clutch.
mdd0127 wrote:The CA-LRC has a minimum speed setting that allows the motor to sync up and avoid the super high amp surges from attempting to start the motor from a dead stop. The slipper clutch is just a mechanical torque spike limiter and I usually set it tight enough that it doesn't slip unless the throttle is totally pegged or I land the bike with the throttle engaged.
It's a pretty cool setting. On this bike, I have to make two pedal cranks to get to 4mph and then the throttle comes in. It lets the motor sync up before there's a load on it.
Best Wishes!
Mitch
MitchJi
Postby Sharkboat » Mon Jan 09, 2012 3:40 pm
I think the price is reasonable and the quality is amazing, as always. Can't wait to see more pictures.
-Pat
Sharkboat
Postby recumpence » Mon Jan 09, 2012 6:42 pm
I have more to show, but no time right now. You will just have to wait. :)
Matt
recumpence
10 GW
10 GW
Postby farmkid4 » Mon Jan 09, 2012 8:03 pm
recumpence wrote:I have more to show, but no time right now. You will just have to wait. :)
Matt
What!! Hold us in suspense how could you!!
:D
Do you have the ability to read?
Do you use it to increase your understanding?
9C Buildlog: http://endless-sphere.com/forums/viewtopic.php?f=6&t=47608&p=698343#p698343
farmkid4
Postby veloman » Thu Jan 12, 2012 2:26 am
It's good to see your progression after these last few years. I think $1500 is not out of the question for what you are offering, though I won't be buyer at that price. I've built crank drives and they are a lot of work, and compromises are always made. If someone wants a $500 system, there are options, but they won't come close to the attributes of what you seem to be offering.
Edit: for those looking for a cheap mid drive, they are out there, very cheap on ebay. I'm sure quality, power and function is considerably below Matt's however.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby recumpence » Thu Jan 12, 2012 8:47 am
Thanks for the votes of confidence, Guys. However, do not be afraid to give suggestions, recommendations, or outright complaints. I understand. The biggest complaint is bound to be price. That is something I am working on. My problem is (as I have gone through this with my RC helicopters and upgrades as well), I never seem to work the development cost and time into the final product. That never seemed like a big deal when I was spending $100 on materials and 2 hours of time developing a heli product. With bike stuff, I may spend $1,000 in fixturing, programming, and a couple prototypes. Hmm, well, if I make $100 on each drive, I can make up for that in 10 sales. Then there is $100 profit for me in further sales. But, I tend to update things in a regular basis. So, any profit tends to get eaten up by further development. See how that goes? With this crank drive, there are far more individual parts than any other bicycle related kit I have ever produced. In fact, this setup rivals my complete RC helicopter in parts count! I have a motor manufacturer, a crank manufacturer, a bottom bracket manufacturer, a sprocket manufacturer, controllers, two manchine shops for pulleys, two separate suppliers for various clutch parts, belts, CNC machined mounts and drive parts, freewheels come from two manufacturers, freewheel adaptors come from another machine shop, etc, etc, etc. And, I have to pay for programming, fixturing and prototyping for every individual part (machined part). It is mind boggling. It looks like I will be out of pocket upwards of $7,000 for innitial design, fixturing, debugging, testing, and other design work. Then I have somewhere in the neighborhood of 50 hours of time from my own schedule doing design work. Next I have to do testing and spend around 20 hours making instructions. On top of all that, I need to part with around $10,000 in manufacturing for these various parts. See how difficult this is? And, the only reason this is even within the realm of possibility is because I already developed (or at least have accumulated knowledge that I can apply) my other drives and can use that knowledge here. There is a huge risk in this, still, however.
Anyway, I am not looking for sympathy, just understanding and patience. :)
Oh, the freewheeling crank programming and prototyping is ordered. That is my next hurdle. I think I have all the bugs figured out, though.
Matt
recumpence
10 GW
10 GW
Postby Steven57 » Fri Jan 13, 2012 6:23 pm
Matt,
Will this bolt to a triple ring crankset? Or a Schlumpf drive? What do you anticipate weight being minus batteries?
Steven57
Postby ultima » Fri Jan 13, 2012 6:58 pm
Hi Matt,
I have been lurking here for a while, and this may be the system to finally switch me from my gas-assist bike :) Like Steven57, I am curious whether this kit will utilize a 3 chainring front derailer as per my current Bimoto crank system? Also, since I already have a 10S LiFePO4 A123 20Ah waiting to be hooked up to something, will the controller you have in mind be suitable?
Sorry for the newbie questions, and please keep up the impressive work!
ultima
Postby recumpence » Fri Jan 13, 2012 8:16 pm
The crank will have a standard 130mm BCD bolt patern. So, the smallest chainring would be 39 tooth. I could add holes for 110mm BCD as well if I get requests for that. 3 chainrings can fit (remember, one chainring is for the electric drive). With freewheeling cranks, most people use one chainring for the rear drive and one for the motor. So, a dual drive hub system is best for more than 9 speeds. But, again, 3 chainrings is possible. As for Schlumpf drive, no, that uses its own crank. My system requires a freewheeling crank. Of course, you could choose not to use a freewheeling crank. But, then the cranks will be driven when the motor is running.
Matt
recumpence
10 GW
10 GW
Postby Steven57 » Fri Jan 13, 2012 9:42 pm
So one chainring for electric freewheeling and 2 left for pedaling at 39+ and bigger ring?
Steven57
Postby j3tch1u » Fri Jan 13, 2012 10:50 pm
recumpence wrote:The crank will have a standard 130mm BCD bolt patern. So, the smallest chainring would be 39 tooth. I could add holes for 110mm BCD as well if I get requests for that.
Matt
yes, 110mm BCD plleeeasse (i need to run a 32T)!
j3tch1u
Postby veloman » Fri Jan 13, 2012 11:33 pm
recumpence wrote:My system requires a freewheeling crank. Of course, you could choose not to use a freewheeling crank. But, then the cranks will be driven when the motor is running.
Matt
And I've done a build like that. It takes some getting use to, but eventually you remember to let off the throttle 2 seconds before you might need to stop pedaling. It certainly can and will knock you off the bike if you aren't careful though. I'd highly recommend the freewheel cranks because coasting is one of the beauties of ebikes.
veloman
Postby recumpence » Sat Jan 14, 2012 8:57 am
Matt
I will see what I can do.........
There is room on the adaptor for it.
Matt
recumpence
10 GW
10 GW
Postby johnrobholmes » Sat Jan 14, 2012 9:39 am
Another vote for 110 bcd, I want to offroad!
Volt up, gear down!
johnrobholmes
10 GW
10 GW
Postby Steven57 » Sat Jan 14, 2012 1:14 pm
I'll ask a different way. With this setup will there only be one sprocket for electric and one for pedal?
Steven57
Postby johnrobholmes » Sat Jan 14, 2012 1:37 pm
That was matt's original plan I gather, but it sounds like there may be a way to have two pedal sprockets.
Volt up, gear down!
johnrobholmes
10 GW
10 GW
Postby recumpence » Sat Jan 14, 2012 2:04 pm
Yes, at this point, I am looking at changing the drawings to accomodate two 130mm BCD chainrings and one 110mm ring. That would allow two pedal and one electric ring. I think this would be perfect. The larger pedal ring would be good for road riding and the smaller ring for lower ratio off-roading.
Matt
recumpence
10 GW
10 GW
Postby johnrobholmes » Sat Jan 14, 2012 2:09 pm
If this adapter is 3d already, you could machine the 110bcd on another plane to avoid using spacers for the other rings. Thoughts?
Volt up, gear down!
johnrobholmes
10 GW
10 GW
Postby recumpence » Sat Jan 14, 2012 3:55 pm
There are no spacers. The electric ring is on the outside of the adaptor "Spokes" and one pedal ring is on the inside. They are spaced apart by the thickness of those spokes. Those are 130mm BCD, then one ring will be attached to a stepped area on the inside of those spokes.
Matt
recumpence
10 GW
10 GW
Postby johnrobholmes » Sat Jan 14, 2012 3:57 pm
You are ahead of my thinking already!
Volt up, gear down!
johnrobholmes
10 GW
10 GW
Postby ultima » Sat Jan 14, 2012 4:13 pm
recumpence wrote:Yes, at this point, I am looking at changing the drawings to accomodate two 130mm BCD chainrings and one 110mm ring. That would allow two pedal and one electric ring. I think this would be perfect. The larger pedal ring would be good for road riding and the smaller ring for lower ratio off-roading.
Matt
Perfect! Where do I sign up? ...The small ring for off-roading was precisely the reason I was after multi ratio cranks. Any info on controller at this stage?
Regards,
Ben
ultima
Postby Steven57 » Sat Jan 14, 2012 4:53 pm
So, electric ring is all the way inboard? or outboard?
Steven57
Postby recumpence » Sat Jan 14, 2012 6:03 pm
I am most likely going to use a 6S Castle Creations controller.
The electric ring will be on the outside. That is actually dictated by the large diameter (56 tooth). You cannot run a ring that big on the inside.
Matt
recumpence
10 GW
10 GW
PreviousNext
Users browsing this forum: kifukarider and 7 guests
