Those wheels look a lot better than they did in the video Andy
Whens the motor due? Whats your budget on bike cosmetics?
I am going to build 2 500w CC/CV PSU's into the tank, giving me full charge in 3 hours or so (for the proposed 40AH pack, currently just 20AH, or 2 hour charge). I need to perfect the BMS first though, since they will be mounted together ultimatly. The PSU's weigh about 1.5 KG, anything more powerfull seems to more than double that weight, and i'd rather have more batts instead:P (for that reason I'm glad then I didn't get the bigger controller too!)
Jozzbike made it to 70MPH today, in a dazzling standing start race against my friend Tony on a 1400CC Harley Davidson roadking
He barely kept up, giving it all he could before (thankfully) we ran out of road (or he would have eventually sped past at 100MPH!)
THe CA still isnt entirely accurate, the speed readings are bit screwy and I'm having to set the wheel size by guesswork, but I'm getting readings of 125wh/mile with hard use and constant acellerating/braking. Eventually i'll have to see quite how far it will go, but I'll need to be in a more sombre mood
Best of all, i I put on the G-Meter, and got 0-60 timed at 7.8 secs, 0-30 2.4 secs, and it confirmed the max speed on that run at 68MPH. I'll need to do lots of runs to confirm accuracy though, firstly these G-Meters get a bit confused on a bike, and secondly it was dark and I need to see what i'm doing, so I only made a couple of runs (grinning insanely as I held the throttle full on).
Ypedal, I'm beginning to like the workshop this way (actually, this is supposed to be the "lab", theres a big workshop on the other side of the door littered with bikes, M/C's, a sidecar and anything else I thought looked interesting!). I'm becoming fond of the system. No matter what you want, its always on the floor
Still working on the video side...trying to work out how to mount a cam, and how to bribe Tony's wife to sit on the back of his bike pointing a camera at me! Not to mention a nice sunny day..
More tomorrow!
Steve
Mazda MX-5. 300KW power. Soliton 1 controller, 11" Kostov motor, 20KW/H Turnigy Lipo for 60-100 miles range. 120mph top speed.
Hudson Kindred Spirit 3 wheeler. Twin Agni setup, 300KG 80KW. 100mph top speed (maybe more, but no-one has the guts to try!)
Aprilia RS125, Agni motor, 600A 96v Kelly controller, 6kw/h Turnigy pack.
www.Jozztek.com
