I'm with you on limiting the fun . I assume you have a CA-RC and thats how you are limiting your current. If so didnt you get the supplied 2 little shunts? My understanding of going over a shunts current range means it becomes hot and starts to act like a fuse?
Wow, what process did the use to drill all those holes. The fact that it ran the length of the can was really impressive machining.
Time to uprade to a 3220, piss the gears off and start pulling power monos
motomoto wrote:I think Astro Flight will send me a 3220 4t towards the end of the week, thanks to Matt.
By that time I will have the shunts and new wiring done and some nano techs. I want to do
a new 'run through the gears' video with the bigger motor and the amps turned up.
motomoto wrote:I just got home a few minutes ago and there was a FedEx sticker on my door. It is for my 3220 4t from Astro Flight.
I should have things running this weekend and do a video. All I have ever run are 3210s. The 3220
should be double the power. It will be amazing if it is. I'm like a little kid and it's Christmas.
Users browsing this forum: Bing [Bot], bowlofsalad, rodgah and 10 guests
