Arlo1 wrote:Hey lebowski. At low rpm can we program a max on time for both fets??? I am wondering how this all works... If the max on time was say 20uS then they both shit off for ~5 uS to cool down its not the same as the PWM of the one side... Maybe I need to studie the center aligned up down PWM control to understand this all better.
Lebowski wrote:Arlo1 wrote:Hey lebowski. At low rpm can we program a max on time for both fets??? I am wondering how this all works... If the max on time was say 20uS then they both shit off for ~5 uS to cool down its not the same as the PWM of the one side... Maybe I need to studie the center aligned up down PWM control to understand this all better.
The nasty bit is that the FET's don't determine the current, the inductors do. So you can shut off the FET's but then the current
will just take the path through the protection diodes, dissipating more than if you would have just kept the FET switched on.
So, to answer your question, no this option is not there as it does not make sense...
Lebowski wrote:the third sensor makes it possible to compensate for the common-mode voltage offset (which may be temperature
dependent)
c_a wrote:We need a quick solution because my 135-50 inrunner is on the way:
http://www.powerditto.de/monster.html
We will run it at 24s lipo @450amps = 40kW
c_a wrote:Is one enough or should I buy two?
http://www.mitsubishielectric.com/semic ... u-3a_e.pdf
c_a wrote:I trust in mitsubishi spec sheets, found them for 347€ each in germany. I really like the big blocks
bearing wrote:I wonder if every "transistor" is made of several chips in the "normal" power mosfet size, or if it's one giant chip per transistor.
bearing wrote:Lebowski wrote:the third sensor makes it possible to compensate for the common-mode voltage offset (which may be temperature
dependent)
These Allegro sensors (at least the bigger ones that I have been playing with) have a built in ferrite core. Remanence in the core makes the voltage at 0 amps differ from 0.5Vdd. If the last direction of magnetization was positive, sensor will output some mV in the positive direction at rest. This makes it hard, or maybe even impossible, to measure small currents. If you are integrating current over time (like I did) it will accumulate to a big error.
Alan B wrote:Phase currents are AC so compensating for DC offset should be possible.
Arlo1 wrote:Lebowski I was thinking I was going to put a current sensor in each phase wire anyway I just wanted them to be ballanced.
a] calibrate hall sensors
b] determine coil positions
c) PWM parameters
d) current settings
e) control loop parameters
f) throttle setup
g) running modes
h) CAN bus setup
z) store parameters in EEPROM for motor use
a) sensored or sensorless: SENSORED
b} sensorless startup: PUSH START
c} e-rpm limit sensorless self start: 999
d} e-rpm reached before transition: 89 %
e} minimum current push start: 0.9 A
f} push start current, error allowed: 20 %
g] erpm sensored to sensorless transition: 500
h] transition time sensored to sensorless: 249 milli-sec
i) return to motor start below 200 erpm
j) motor maximum: 6.99 k-erpm
k) motor standstill voltage threshold: 1.49 V
z) return to main menu
Arlo1 wrote:6.99k erpm max??? Thats only 699rpm for colossus....
Lebowski wrote:Arlo1 wrote:6.99k erpm max??? Thats only 699rpm for colossus....
These numbers are for my own motor, you can type whatever you want here. This
particular entry I think goes up to 255.99k and is not limited by the controller algorithm
but by the computation which takes the number you enter and transforms it into the
16 bits integer the algorithm uses. Is there a need to go higher than 256 k-erpm ?
Farfle wrote:The joby motors are some insane E-rpm iirc, but I cant find it.
