17 Inch Wheels *SOLD OUT*
Re: 17 Inch Wheels
Postby NeilP » Sun Jan 15, 2012 5:02 am
Don't know yet..was hoping they would.
I have 12 gauge in my 5304..thought they were a little slack..so hoped 10 would fit....but think it is the same size holes in teh 5404 as in the 5304..but do not know for sure.
Do you have any 10gauge spokes to check for me?
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
10 GW
10 GW
Re: 17 Inch Wheels
Postby Stevil_Knevil » Sun Jan 15, 2012 5:33 am
Sorry mate, not a single 10 gauge spoke or X5 in my collection of bits. Have you considered/tried installing brass washers at the flange end of the spokes?
Stevil_Knevil
Re: 17 Inch Wheels
Postby NeilP » Sun Jan 15, 2012 7:07 am
No, it is not the head of the spoke that is too small, that is fine, just the thickness of the spoke through the hole.
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Re: 17 Inch Wheels
Postby nicobie » Sun Jan 15, 2012 2:13 pm
Single cross looks like the way to go.
Do you know the spoke length for a setup like you pictured? What would a guy use to thread the ends. I have small taps in both metric and standard sizes. Would they work on 12g ?
Be sure to save me a pair of wheels. :wink:
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Re: 17 Inch Wheels
Postby Stevil_Knevil » Sun Jan 15, 2012 5:35 pm
No worries Nick, got a pair of wheels set aside for you :)
Spokes are kind of the final frontier in building ebikes, and bicycles in general. A spoke threading machine rolls a very tight thread pitch into the wire - whereas a die will cut material away -- so tight that I have never found a die with the same thread pitch.
This subject really deserves it's own thread ..hmmm :?
Sorry :oops: bad pun totally NOT intended..
Stevil_Knevil
Re: 17 Inch Wheels
Postby NeilP » Sun Jan 15, 2012 8:19 pm
nicobie wrote: What would a guy use to thread the ends.
Spoke rolling tool
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Re: 17 Inch Wheels
Postby Stevil_Knevil » Mon Jan 16, 2012 3:39 am
Great find Neil!
I spent half the day documenting modifications made to my Hozan spoke threading tool (they only offer tooling for 14/15 gauge spokes) to roll 12 gauge spokes :roll: Seems obsolete considering this Cyclo unit can be had with the proper 12 gauge thread rolling tool.
Cross 1 spoke length for an H-series rear motor built into one of these rims = 107mm. There is a slight dish, so add 1mm for the drive side spokes and subtract 1mm to the brake rotor side.
Edit: fixed
Stevil_Knevil
Re: 17 Inch Wheels
Postby NeilP » Mon Jan 16, 2012 5:47 am
What are the dimensions of the H series hub? flange diameter to the holes and spacing etc...so i cna compare to a 5 series
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Re: 17 Inch Wheels
Postby Stevil_Knevil » Mon Jan 16, 2012 2:01 pm
H-series rear motor:
Hub Flange Diameter = 233mm
Flange Spacing = 33mm
Spoke Hole Diameter = 3.15mm
FEMCO 1.20 X 17 rim:
Effective Rim Diameter = 418.5mm
Do you have one of those Cyclo spoke threaders, Neil? Could you measure the I.D. where the head attaches to the tool shaft?
http://weldtite.co.uk/products/detail/s ... g-head-12g
Stevil_Knevil
Re: 17 Inch Wheels
Postby NeilP » Mon Jan 16, 2012 2:10 pm
Afraid I don't
I may have one of the heads in a box of bits at the farm. I'll look tomorrow afternoon, so at least another 24 hrs before I can answer
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Re: 17 Inch Wheels
Postby nicobie » Mon Jan 16, 2012 2:15 pm
Great info here!
Thanks S
nicobie
Re: 17 Inch Wheels
Postby NeilP » Mon Jan 16, 2012 2:24 pm
Afraid I don't
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Re: 17 Inch Wheels
Postby Microbatman » Wed Jan 18, 2012 5:37 pm
What is the measurment in mm of the outside of the threaded axel?
I am trying to figure out if these are standard 9mm bike hubs.
I read that the standard quick realease axle fits but am worried that the outside diameter is too wide for standard 9mm fork dropouts.
MotorCrystalyte X5304 20 Inch Rear Wheel DISC Brake Controller Crystalyte 48A72V4110MOSFETS
Batteries A123 24s2p
Charger Mastech 5020
Frame Azonic Steelhead
Grateful/fortunate/blessed to have the resources and family support to enjoy my ebike hobby
Microbatman
Re: 17 Inch Wheels
Postby Stevil_Knevil » Wed Jan 18, 2012 10:40 pm
A 5mm O.D. Quick Release (QR) skewer fits in the front hub, which is 100mm wide ..totally standard bikey stuff.
Where are you getting that 9mm measurement, axle O.D.? Does your front wheel bolt in?
Edit: fixed
Stevil_Knevil
Re: 17 Inch Wheels
Postby Stevil_Knevil » Thu Jan 19, 2012 4:30 pm
Microbatman wrote:What is the measurment in mm of the outside of the threaded axel?
OK, your terminology had me a bit confused, but I get it now. Yes, 9mm is the O.D. of the axle shaft that extends ~4mm from either side of the hub. The skewer fits inside the axle shaft. The picture that you referenced is a peak at the Japanese cartridge bearing under the dust/water cover - which would be the part that fits between your fork's dropouts.
Hope I am explaining it well enough ..did that make sense?
Stevil_Knevil
Re: 17 Inch Wheels
Postby nicobie » Tue Jan 24, 2012 4:24 pm
Hi Steve,
The wheels came in and they look great? You did an excellent packing job. You did a good job with the spokes too. Nice threads! Also thank you for labeling the different length spokes (long go to freewheel side).
Did you ever get a chance to try those 3" gazelles on one of these rims?
Thanks again and see you at the next race.
Nick
nicobie
Re: 17 Inch Wheels
Postby Stevil_Knevil » Fri Feb 17, 2012 3:30 pm
nicobie wrote:Did you ever get a chance to try those 3" gazelles on one of these rims?
Hey Nick, glad to hear everything showed up in good condition and to your liking :)
I just finished the mod's to my HT motor, mounted the 3.0 Gazelle rubber, then a 2.5 to the front ..and my 'Borg assimilated them :twisted: These wheels look and perform great!!
See you at the track! -S
Stevil_Knevil
Re: 17 Inch Wheels
Postby drewjet » Fri Feb 17, 2012 4:37 pm
I am loving my 2.5 gazzelles. Those 3's must be sweeet riding.
How many rims do you have left? I may want another set.
ImageSuzuki SP200, Mars Brushless, 300 Amp Kelly Controller,(18S12P) http://www.evalbum.com/1511
3220 Mountain Bike viewtopic.php?f=28&t=16705&p=244317#p244317
Suzuki Lipo Upgrade viewtopic.php?f=10&t=23088&p=335986#p335986
Race Bike viewtopic.php?f=3&t=32486
drewjet
Re: 17 Inch Wheels
Postby Stevil_Knevil » Fri Feb 17, 2012 10:17 pm
Hey Drew, I sort of expected that mounting the 3.0 Gazelle on this rim would make the tire a little 'poochy' and have a peaky crown, but I was happily disappointed to discover that it actually ended up having a nice profile :)
The combo of this + the 2.5 Gazelle out front feels well planted and rolls into turns predictably ..confidence inspiring.. at my local parking lot GP practice course, I can lean further and carry more speed through sweeping turns than any bicycle wheel/tire I have tried in the past.
There are 4 sets left.
Stevil_Knevil
Re: 17 Inch Wheels
Postby nicobie » Sat Feb 18, 2012 2:06 pm
As Thud likes to say,
"get some"
:mrgreen:
nicobie
Re: 17 Inch Wheels
Postby NeilP » Sat Feb 18, 2012 2:29 pm
Stevil_Knevil wrote:H-series rear motor:
I Steve
Well as it happens, i have been lent one of these tools..but not got around to measuring anything on it yet. I can tell you they do not do 11 g heads for them though...which is a pain...my hub has 1 g spokes...the tool I have, has a 10 gauge head...if I think about it, i'll measure what you ask sometime soon...but poke me via PM if I forget
Neil
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Re: 17 Inch Wheels *SOLD OUT*
Postby Stevil_Knevil » Sat Mar 31, 2012 6:06 pm
SOLD OUT :D
Long live the sphere!!
Mods, please lock this thread.
Stevil_Knevil
Previous
Users browsing this forum: migueralliart and 3 guests
