We started talking about internal temperature cut outs over the the stealth owners thread HERE but it was getting off topic so I'm starting another thread here.
Obviously there's a few solutions, the ideal one being fitting an internal temp sensor that sets off an external warning or better still dials back the current through a CA or limits the throttle or what ever. What I'm aiming to do is have a safety cut out that's strictly inside the motor, the main reason being that the axles are often already cramped and don't allow room for additional wiring or if it does it's a fair undertaking.
What I'm looking at is interrupting the 5v supply to the halls using a thermostat or thermistor.
The negative arguement for this is that it could be dangerous to suddenly cut the power but my view is if you melt a phase wire or cook a winding etc the failure is going to be just as abrupt and then you're in for a long push home.
Aaanyway, the 1 option I've tested is a normally closed thermostat switch that goes open when the desired temperate is reached.
The downside to these is the reset temperature is often quite a bit lower than the trip temperature, so if you have to wait for the temperature to drop 20 degrees inside the motor that'd be a pain.
The other option is a thermistor wired in series with the 5v hall line. These are smaller and could be mounted direct to the windings and I've just done some tests which look like they'd work well.
I wired a 1k pot into the 5v hall supply from the controller
Voltage to the halls at rest is 4.3v
Increasing the resistance to 130 ohms causes a slight and consistent audible vibration. The motor maintains speed but if you were riding you'd certainly detect it.
Increasing to to 150 ohms and above causes harsh stuttering that quickly brings the motor to a stop
The voltage drop required to cause the vibration is 3.5v and it has a spack attack when it hits 3.4v. So it's probably not going to be possible using the output of a thermisor to get this mild vibration as an early warning. The increased resistance will cause a sudden shut of - which is all I was expecting anyway.
The second the resistance decreases and the voltage comes back up the motor continues to work as normal, so there's no need reset the controller (to answer your question full throttle
Here's a quick video showing the test - further discussion and comments welcome
