cohberg wrote:def not cutting off due to lvc (67V or higher when controller was acting up), its clearly sagging more at wot (65V) but no choppy behavior there.
i would like to see 24s on an rc motor though![]()
mauimart, any updates on the choppiness? also what happens if you use wot right from the start?
mauimart wrote:I modded my controller over the weekend by decreasing the resistance of the current shunt. It seems to have smoothed out the jerkyness a bit but at the same time it has accentuated the power surge at roughly 25% throttle input. Low rpm starts are smooth but once you hit that 25% threshold the controller commands a rather violent surge in power that will throw you off the back of the bike if you are not ready for it. I did do a run where the controller peaked at about 3000W input power and it seems to handle 2000W continuous without much heat output. Still not bad for the price if it could only be tamed![]()
The Mighty Volt wrote:Is this just because we've got a change over from the "normal" hub to the outrunner with the added sensors??
The Mighty Volt wrote:Cheers Cohberg- one of MauiMarts excellent youtube videos shows him running the motor and losing synchronization at the very very high RPM.
Here it is
Maybe another re-wind down again might help??
mauimart wrote: If only I could find an extension cord long enough for my scope so that I can probe the hall sensors while riding the bike under load...![]()
Gordo wrote:mauimart wrote: If only I could find an extension cord long enough for my scope so that I can probe the hall sensors while riding the bike under load...![]()
That is where having Arlo1 with his dyno, just down the road comes in handy.
Nooooo, I want to see the video of him duct taping a big ole Tektronix to his bike and go WOT until the cord bungies him back...
cohberg wrote:
Something more practical would be to use one of those bicycle trainer (modulating the load to simulate real life scenarios) to confirm good hall sensor resolution and that the hua tong's control algorithm is just lousy.
You mean something like this?
Skippic wrote:Has anyone actually made this controller work in sensorless mode?
There are all types of statements, like this one:
viewtopic.php?f=9&t=35848&p=520563&hilit=sensorless+hua+tong#p521310
But I haven't found a thread where someone actually made it work in sensorless.
XLR8 wrote:Does anyone know if it is possible to modify this 72 volt controller to run on a 64 volt LiFePO ( 20s) battery or is there a controller that is a similiar price with the same attributes?
Users browsing this forum: cal3thousand and 10 guests
