How's the 1200W charger going? My 900W version from BMS battery (looks almost the same) blew up yesterday for no apparent reason. In the process of trying to get a replacement now
I drilled holes in top cover of mine to gather access to all the important pots for voltage and current. I'm a lucky bastard, none of their chargers have gone puff on me so far. But some came with reversed polarity recently. Also their new 12 fets (KU123) came without thermal paste, I mean wtf...
keyne wrote:How's the 1200W charger going? My 900W version from BMS battery (looks almost the same) blew up yesterday for no apparent reason. In the process of trying to get a replacement now
Did you ever see what the voltage output range was ?
So if you turn it down to 50v it run 24amps = 1200w. That's charging at 24a. ?
Mine just arrived in the post, same success story, less than 3 weeks from ordering to arriving in the UK. Volts are spot on as requested and it came with andersons as requested but I'll swap those for bullets.
I've asked this elsewhere but never got a diffinitive answer, charing a 12s2p pack with this charger will mean that the charger is putting out 50V 24A (roughly), Trunigy Lipo is supposedly rated at 2C charge rate which would mean 20A maximum charge rate, am I going to shorten the life of the pack or risk puffing cells if I'm charging above 2C ?
nonlineartom wrote:
General rule from now on, how do you know when you've got a good charger? when you turn it on and the house lights go dim. Aw yeah.
Return to E-Bike Reviews & Testing
Users browsing this forum: Google [Bot], teklektik and 6 guests
