Alan B wrote:You might need more resolution than the PWM has to control the gates. Also to get good current sharing it might be worthwhile to add some current balancing resistors. They can dissipate some of the power as well as reduce the voltage gain of the FETs and make control easier.
magudaman wrote:Programmable Constant Current
SamTexas wrote:magudaman wrote:Programmable Constant Current
If I were to build a discharger from scratch, I would go for "Programmable Constant POWER" instead. I think it's more useful and it ignores the constantly dropping voltage of the pack during discharge.
Samson wrote:Used in the linear region with DC the IRF4110 Maximum Safe Operating Area chart on the data sheet [fig. 8] indicates these devices will not work at more than an amp with 20 volts Vds!
I use Bipolars for my discharge circuit, the secondary breakdown of Bipolars looks similar to the MOSFet Maximum Safe Operating Area chart but there is more headroom typically.
magudaman wrote:SamTexas wrote:magudaman wrote:Programmable Constant Current
Well most bikes and motor controllers limit on amps not watts, so I would think that would be more relevant for our application. It would be cool just to have an option to switch between the two.Samson wrote:Used in the linear region with DC the IRF4110 Maximum Safe Operating Area chart on the data sheet [fig. 8] indicates these devices will not work at more than an amp with 20 volts Vds!
I'm looking over the data sheet but not finding what you are referring to. This unit by spec can dissipate 370W but I will only be running it at less than 200w. With its temp junction rating that shouldn't be a problem.
http://www.irf.com/product-info/datasheets/data/irfp4110pbf.pdf
Page 4 top right corner [fig 8] of the data sheet. You only get the big amps with fast pulses not DC operation.
Alan B wrote:For this linear application there is no advantage to a low RDSon FET unless you are going to test very low voltage sources (like a single cell). More important is the thermal resistance and power dissipation and low cost. Paralleling a bunch of cheap FETs might be the best choice. The balancing resistor, if chosen right, will dissipate a useful amount of power which relieves the FET of that part of the load.
Software can be used to get constant power, or current, or whatever. That's not hard to do. If you have good current and voltage measurements, and control over the variable load you can do many different algorithms.
amberwolf wrote:If you really want an easy way to create a high-power controllable load, then depending on the voltage needed, you may be able to use the carcas of an old late-1970s FET-based audio amplifier. Some of them used very large arrays of paralleled FETs already mounted on very nice heatsinks, the whole thing designed to be run in linear mode.Newer ones could also be used, too, but you may find some of these old things easily enough by advertising a want ad for them on Craigslist and the like. Maybe find newer types, too.
All you'd need to do is set up the gate-control-voltage source to drive the gate control of the amp, severing the connection from the audio input side of things.
If you find the FETs in it arent' suitable for your voltage range, you could probably replace them with modern versions that are.
magudaman wrote:They actually rate these ones to be able to do 2 amps @ 100v DC which is better than the IRL CBA units which don't even list the DC. I'm sure there is something I over looked in their spec
magudaman wrote:Alan B wrote:You might need more resolution than the PWM has to control the gates. Also to get good current sharing it might be worthwhile to add some current balancing resistors. They can dissipate some of the power as well as reduce the voltage gain of the FETs and make control easier.
Very True, that is a concern. Looking over the PWM info, it looks like it has 800 steps. Due to the linear voltage zone of the fets I will be dealing with less than 1/5 of that range so maybe 160 steps. I have read about balancing being an issue, but large resisters are the same cost as my FETs. For something like a .05 ohm 50w resistor I'm looking at almost $4 a resistor, but like you said may be a necessary part.
magudaman wrote:Samson wrote:Arg yah I see that, that is very interesting! Hmm, well that may be a problem. Yah when I contrast it to the Irl2910 which is the device they use in the CBA, the unit I chose does better at low voltage with current (only marginally) but doesn't make it to the upper voltage at all (comparing the 10ms). Damn. Well I got 9 of them left, I guess I'll see if I can sell those off and consider a different FET and a larger quantity. Nice spot though thank you. Less headache in the future then!
magudaman wrote:amberwolf wrote:So I am looking in to a FET let me know what you guys all think. I guess I will run 10 of them:
http://www.nxp.com/documents/data_sheet/BUK95_9610_100B.pdf
They actually rate these ones to be able to do 2 amps @ 100v DC which is better than the IRL CBA units which don't even list the DC. I'm sure there is something I over looked in their spec![]()
.5c/w, should be good for around 100W a unit, has a 175C junction
Samson wrote:You might check out this MOSfet, designed for linear mode APL502B2. Very expensive though!
http://www2.microsemi.com/datasheets/APL502B2&L.pdf
I believe the specs only refer to the voltage (50V) and the current (10A) as separate, independent, maximums with the power limited by the cooling used for the FET. That document only mentions small loads so they weren't worried about the total power. We, of course, definitely are!Samson wrote:http://endless-sphere.com/forums/download/file.php?id=75624
The PDF file above could not possibly dissipate 50 V and 10 amps (500 Watts) as the write up suggests. The Max diss of the the IRF540 is 130 watts at 25C. I think they have misplaced a decimal!
magudaman wrote:I am also not exactly sure what I should be looking for with the resistors. They basically go in series with my connection to my FET right?
Battery negative -> Resistor leg -> other resistor leg -> fet source -> fet drain -> battery positive
There are some 35W .05 ohm units that would be dissipating 20 watts at 20 amps (required when doing 200a tests). They $2.60 a piece and are in a T0-220 package too!
magudaman wrote:So, I blew up my CBA recently and have found it to be rather undersized for sometime now so I figured it was time to build my own serious discharger.
Users browsing this forum: izeman, Kai, Melbourne, TheBeastie and 13 guests
