Charger works like a charm!!! Used many times now and doesn't seem to come on anymore after charged
I have a 12s1p I use about 2.2 ah's (115wh) to work 3.7miles (cells are sitting around 3.85 from 4.15) maxing out on pull away at 24amps sitting at 19 amps at 27 mph, I charge outside when i get in takes about 35 mins at 6amps which is perfect
Everytime i plug this in i check at cell level, I only have two ballance leads to check which is easy, make sure they are all ballanced then plug it in
Starts off straight away at 6 amps then after about 25mins starts to drop off to about 2 amps and then 1 amp and then 5 mins and .5 of an amp just to top it off, Glad i did have this set to 50v now as after it hits 50.04v and the charger clicks off the cells start to settels to around 49.8 and all my cells sit happily at 4.15
These Turnigy's are sooo stable once ballanced I am yet to see them out
My ballance charger is now redundent and i doubt i will be using it for a while....
So that's me, I'm sorted, Just got to suss out where to store my bike with the battery, Kinda getting board of removing my pack and sticking it in the oven over night
Would put the bike and pack in the garage but i have a gas main in there
and lot's of crap, so was thinking for the summer months just covering it up and leaving in the middle of the garden, I'm happy if it did go for the bike to go too as it was second hand and much cheapness, and the batteries only cost me £70 and i have a spare hub
...But tbh with my simple pack 12s1p there isn't much there to go wrong and i religiuosly double check before anything, but don't worry i will not get complacent and view it it can go at anytime
