FS: A123 ANR26650M1A cells NEW PRICE 6$ cell shipped
Postby migueralliart » Mon Feb 06, 2012 6:27 pm
At last I am ready to offer these to the forum at a great price!
Previous thread
viewtopic.php?f=9&t=34318
Guys these are Brand new they have a PCB mounted on top of each 3 cell pack which I've tested to max 9 amps. That won't stop you from disassembling this pack and making whatever you want from it. Price is fixed @ 6$ a cell shipped with a minimum of 12. Whatever total you order it has to be in quantities of 3 cause I don't want to break up these packs. Ive cycled twice a hundred now and shipped 17 packs already. Got 600 more packs at my storage safely secure. PM me if you are interested. Right now I am only shipping to the USA for free.
These are 2.3Ah Btw
Couple of pics describing what you'll get
EDIT! February 13, 2012
Just a sample discharge graph of these puppies without the bms and a 3S harness attached.
discharge ~7amps
Last edited by migueralliart on Sun Mar 18, 2012 8:53 pm, edited 2 times in total.
migueralliart
Re: FS: A123 ANR26650M1A cells NEW 6.5$ cell shipped
Postby methods » Tue Feb 07, 2012 5:31 pm
If you have those little BMS boards in 4S I am looking for 20 or so
-methods
32,768 Tests are worth a Billion^0xFFFF opinions
Thanks Fechter... you have displayed an even hand at every turn
methods
10 GW
10 GW
Postby Haste » Tue Feb 07, 2012 7:52 pm
could you help me put together a pack? I want a 48v pack...do these handle 25-30 amps fine?
1997 Marin Hill Hawk. Bafang BPM 2 10T. KU123 30 amp controller. 12s LiPo.=32mph
Haste
Postby migueralliart » Tue Feb 07, 2012 8:15 pm
Haste wrote:could you help me put together a pack? I want a 48v pack...do these handle 25-30 amps fine?
At the moment I am not putting together packs. These cells are for people who want to build their own packs. I believe the max continuous discharge is 70 amps according to the specs
http://www.google.com/url?sa=t&source=w ... z_bE9Gi73A
However if I was to build a pack I'd probably do at least a 2 parallel configuration that way the cells wont get beaten.
For a 48v pack u will need at least 15 cells. But for an easier configuration u could do a 16s put 8s balance connectors to balance the cells everyonce in a while. For a 4.6ah battery you will need 32 cells.
I guess it comes down to your controller and motor? If you share your setup there is probably an easier approach.
migueralliart
methods wrote:If you have those little BMS boards in 4S I am looking for 20 or so
-methods
I only have 3s pcbs attached to the packs :( no 4s.
migueralliart
Postby sangesf » Tue Feb 07, 2012 8:33 pm
So is that $6.50 a cell or $6.50 per 3Cell pack?
sangesf
Postby migueralliart » Tue Feb 07, 2012 8:41 pm
sangesf wrote:So is that $6.50 a cell or $6.50 per 3Cell pack?
That's per cell.
migueralliart
Postby sangesf » Tue Feb 07, 2012 9:06 pm
So, if I wanted to make a 12s/36v (4-3s in series) 4p/9.2Ah pack it would be 48 cells total?
Total of $312?
What does the PCB's do? Are they both charge and discharge cutoffs?
And if so, to what voltages?
Thank you.
P.S. I read the other thread and the PCB question I'm asking now, wasn't addressed in there so I figured I'd ask here..
sangesf
Postby migueralliart » Tue Feb 07, 2012 9:32 pm
sangesf wrote:So, if I wanted to make a 12s/36v (4-3s in series) 4p/9.2Ah pack it would be 48 cells total?
Total of $312?
Thank you.
Yes you'll need 48 cells. The pcb just does hvc and lvc plus a temp cable. I have not checked the specs of the pcb but that's what I've noticed with my icharger. Also I believe 9 amps is the discharge limit on the pcb. So if you actually connect them in parallel you will get 36 amps top whoch would not require u to do any modification to the packs :)
migueralliart
Postby sangesf » Tue Feb 07, 2012 10:04 pm
That's what I figured.. Which is pretty nice because then, there's no need for a BMS.. Although I'm sure the temp sensor wire will need to be "handled" in some way..
sangesf
Postby migueralliart » Wed Feb 08, 2012 7:46 am
Got 30 packs (90 cells) left ready to go guys. I better start prepping the next 100 packs.
migueralliart
Postby migueralliart » Wed Feb 08, 2012 8:08 pm
26packs left
migueralliart
Postby migueralliart » Thu Feb 09, 2012 9:19 pm
22 packs left .... and occasional bump Btw
PS: I'll probably have 50 packs more during the weekend, it takes a bit of time to cycle them and then leave then at nominal
migueralliart
Postby TonyReynolds » Fri Feb 10, 2012 11:57 pm
PM sent...
Third Build: 2012 Marin Muirwoods 4130 Cromoly, 7 speed 11/32 with 500/1000W MAC geared rear motor, 48V System, 52V, 11.5Ah 16s5p A123 lifepo4 triangle battery, DP CA; 20-30+ MPH... GRIN! Build Thread: http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=33819
cell_man... Supplier of A123 Cells and MAC Hub Motors: http://www.emissions-free.com/id47.html
TonyReynolds
Postby migueralliart » Sat Feb 11, 2012 12:15 am
TonyReynolds wrote:PM sent...
2 packs left with pcbs and 3 without em. Total of 15cells left.
Started cycling some more packs for the next batch, I hope my icharger doesn't quit on me.
migueralliart
Postby migueralliart » Mon Feb 13, 2012 11:22 am
Got started on the second batch will probably have 100 packs by the end of the week....
Anybody interested just PM me I respond fast and ship fast as well.
migueralliart
Postby sangesf » Mon Feb 13, 2012 4:19 pm
Could ya respond to my PM?
sangesf
Postby migueralliart » Mon Feb 13, 2012 4:33 pm
sangesf wrote:Could ya respond to my PM?
I just checked my pms there is nothing new there.
migueralliart
Postby methods » Mon Feb 13, 2012 6:29 pm
Check your outbox - some times the server gets reset and things disappear.
If it is in your outbox - it is unread and in his inbox
If it is in your sentbox - it was read
If it is not there, it was lost
-methods
methods
10 GW
10 GW
Postby migueralliart » Mon Feb 13, 2012 6:35 pm
-methods
Good to know!
and free bump btw
migueralliart
Postby sangesf » Mon Feb 13, 2012 6:52 pm
Sent another PM so it's sitting in the outbox (unread)...
Apparently he lives near me as he's seen my test-bed bike "The Beast", at Starbucks near my house..
P.S. Another free bump.. LOL
sangesf
Postby migueralliart » Mon Feb 13, 2012 9:07 pm
discharge ~7amps
(86.09 KiB) Downloaded 9 times
migueralliart
Postby sangesf » Mon Feb 13, 2012 9:10 pm
Sent the email, with THREE pics..
sangesf
Postby migueralliart » Wed Feb 15, 2012 12:16 pm
Got these ready to go as well 24 cells..
migueralliart
Postby migueralliart » Thu Feb 16, 2012 12:13 am
To the top!!!
BUMP!
migueralliart
Next
Users browsing this forum: easyryder, jimbo_bubbles, litespeed and 9 guests
