Battery Medic - how to ID the REAL vs FAKE
Re: Battery Medic - how to ID the REAL vs FAKE
Postby methods » Fri Feb 10, 2012 1:32 am
Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
I sell stuff.... like little morsels of my integrity @ http://www.MethodsTechnology.com
methods
10 GW
10 GW
Postby parabellum » Fri Feb 10, 2012 1:57 am
methods wrote:I suggest setting them so that the resistor side is up. Even the slightest breeze in the room (ceiling fan) can make a huge difference.
-methods
FastDemise wrote:Don't forget to mention it's in your best interest to ensure the balancer is in a well ventilated area as they do get very hot if left running for a while.
This is how they look after longer discharge on 5s battery :D
The right green unit is HK MKS Propo, the casing seems to be made of better material, or temperatures are lower
(237.26 KiB) Downloaded 5 times
parabellum
Postby Jozzer » Fri Feb 10, 2012 9:59 am
Here's one I bought a few years back with a different layout. These units balance faster, but the resistors get pretty hot and melt the plastic unless you blow a fan over them. I've had 2 of these running, along with several of the SMD resistor type, running for over 2 years, 5 days a week 8 hours a day. Both of the through hole risistor type units eventually failed, the others keep running. I seem to recal that accuracy on these units was better than the SMD versions (though remember, they are all from a few years ago).
Just to further confuse things;)
Battery Doctor.jpg (69.29 KiB) Viewed 299 times
battery doctor1.jpg (102.94 KiB) Viewed 299 times
Mazda MX-5. 300KW power. Soliton 1 controller, 11" Kostov motor, 20KW/H Turnigy Lipo for 60-100 miles range. 120mph top speed.
Hudson Kindred Spirit 3 wheeler. Twin Agni setup, 300KG 80KW. 100mph top speed (maybe more, but no-one has the guts to try!)
Aprilia RS125, Agni motor, 600A 96v Kelly controller, 6kw/h Turnigy pack.
www.Jozztek.com
Jozzer
Postby Duc998 » Fri Feb 10, 2012 10:09 am
rui_fujino wrote:thanks alot! I got 4 from ebay (cheap! and turns out they have RED PCB! WIN!)
http://www.ebay.co.uk/itm/260753810568?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
This is where i got them from!
I ordered x2 off force hobby and I got green PCB guess I got unlucky :(
Giant DH Comp 03 build in progress 72v 18s3p 9C 9x7 12fet Infineon controller set 45amps
Duc998
Postby docnjoj » Fri Feb 10, 2012 2:04 pm
I need 2 of the good ones after you work your magic! Balance at 1/2 amp would be fine for me. I realize it means doing some resistor swaps but my suspicion is that that is what you are going to do anyways.
otherDoc
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
Postby rojitor » Fri Feb 10, 2012 2:15 pm
yay! That's the one i ordered
rojitor
Postby methods » Fri Feb 10, 2012 2:41 pm
Ok - the results are mixed after the overnight discharge.
The Good News:
When I went to bed all the packs had already balanced to 4.1V
So that is good....
The Bad News:
Letting them sit overnight actually *imbalances* the packs due to the quiescent current draw of the units. First they balance perfectly... then the draw to keep the LCD screen etc running runs things out.
4.083V
4.084V
4.083V
4.101V
Now to put it in perspective - that is not that bad of an imbalance. 4.101V - 4.083V = 18mV
That is nothing to be pleased with - but it is certainly a reasonable number. Those of us who have been running lipo for a few years (and abusing lipo...) know that it is pretty common to have a bank of cells out by 100mV or worse - especially after a few deep discharge cycles. If you told me my pack would never be outside of 20mV per bank - I would be totally satisfied with that.
Truth is - most guys don't even have equipment accurate enough to measure that type of difference with any sort of accuracy :| Many may think they do, but that is just because they have not actually calibrated their equipment against something that is truly accurate to 1mV or less.
The News to make you feel a little better:
To be fair, these were little 4S 5Ah packs. In reality you would be balancing a 10Ah or 15Ah pack so the "imbalance" would be a lot less... most likely in the 10mV range
The options:
A great option here would be to have a trickle supply set to 4.1V/cell.
For instance - with an 18S pack you might have a 73.8V 200mA supply.
This would keep the packs up.
This type of supply is actually quite easy to make and often looked over. Most people would never consider a bulk charger that works at only 100mA or 200ma.... but actually it makes a ton of sense for an application like this. There are many junk supplies out there that can put out 0V to 100V at low current.
At this point my plan is to just hook them up when I get off work and unhook them when I go to bed. That is a solid 5 hours - and if you do this for 2 or 3 days your pack will absolutely come into reasonable balance.
Now....
Lets talk about getting a little more performance out of these.... :twisted:
-methods
P.S. None of my plastic was even close to being melted - though these were 4S packs to be fair. Those with melted plastic - try to measure the shunt power if you can.
methods
10 GW
10 GW
Postby methods » Fri Feb 10, 2012 3:04 pm
I am working on ordering 50 more pieces.
Now... I do enjoy making money off of you guys but I think it is more important to further the hobby - so I am not going to try and mask my source for these.
(not like you could not figure it out with a little foot work)
First let me say this: This seller is a really good guy. The English is not so great, but he is honest - and that is worth everything in this game.
Look how awesome this is - he sells two versions
$13.98 shipped (expect 1 month)
http://www.ebay.com/itm/RC-Lipo-Li-Fe-Battery-LCD-Voltage-Meter-Tester-Balancer-/180703582293?pt=LH_DefaultDomain_0&hash=item2a12c5d855#ht_2233wt_1110
$14.99 shipped (expect 1 month)
http://www.ebay.com/itm/LCD-RC-lipo-battery-Voltage-Meter-Balancer-Discharger-/180692663771?pt=LH_DefaultDomain_0&hash=item2a121f3ddb#shId
Yea - that is right
Nearly identical ads - different prices - totally different product.
IF you pay close attention you will realize that if you go to his store the "Good One" is listed under LIPO BATTERIES and the "Bad one" is buried down under "Other"
Let this be a lesson to you boys... if a Chinese vendor is selling what appears to be two identical products and one costs more... dont assume that he thinks you are stupid or that he has made a mistake. This just boils down to communication - and cultural shit - and ways of doing business. In the USA we like to bash inferior products and talk ours up... In China it seems like they just say that everything is "Very good" and it is up to the consumer to be savvy.
So anyway... I am not getting any sort of deal on them. Just trying to order larger amounts to offset faster shipping. Methods does not wait a month for ANYTHING... not even a date with Luke's mom. EMS, DHL, or Bust.
So - there you go.
For the cheap and patient... there is my source. Please treat him with patience and respect - it is very hard to find a good Chinese contact these days. We are working on importing some other stuff. I am preparing a list of the items I commonly import to see what he can do. At the moment I am more than a little pissed with the guys we commonly work with around here (eh HEM!)
-methods
methods
10 GW
10 GW
Postby amberwolf » Fri Feb 10, 2012 3:09 pm
Ypedal wrote:Not sure if this is documented somewhere ( I think i recall reading it at oen point.. ) , but anyone got a link to details for the non-engineer on how to install a on/off switch on these so they can remain hooked up to ballance leads without being a parisite ? will cutting the negative most wire in the ballance plug do it ( using a small switch ) ?
I dunno, but when you find it, make sure you start the Wiki article on it (and include as much of all this new info as you can, too. ;)).
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby methods » Fri Feb 10, 2012 4:08 pm
Ok - here is the first prototype - double the balance current
Factory resistors are 100 ohms and there are 10 of them.
That puts 10ohms across your 4.2V pack for a theoretical 420mA balance current
It is then duty-cycled to 70% to give you an average of 292mA (at 4.2V)
The average power per channel is about 864mW and each of those little resistors sees 86mW
I have some 20 ohm 1W resistors
Two of those in parallel makes 10 ohms
Putting 10 ohms in parallel with the existing 10ohms will double the balance current
Of course we calculate the power....
The new overall average channel power will be 1.73W. The existing resistors will see the same 86mW they were seeing and the new resistors will see about 430mW each. The new resistors are rated at 1W each and typically you cut the rated power in half - so that would be 1/2W... then I have them mounted up on end which will double the cooling surface area.
So we did our due diligence to make sure what we are doing makes sense.
Now lets try it!
But before we do....
6 channels x 1.73W = 10W !!!!!
So we know that is going to equal fail without modifying the case or adding some sort of forced cooling.
Easiest first thing to do is to just modify the cover. Holes... more holes
I suspect this will be too much heat - so I am already working on a second prototype
These are 5W 3.9ohm resistors.
Balance current would be about (4.2V / 3.9ohm) * 0.7 = 750mA :twisted:
These would poke way out of the case and burn the shit out of your hand if you touch them... so we will have to see how that works.
-methods
methods
10 GW
10 GW
Postby methods » Fri Feb 10, 2012 4:09 pm
P.S. We need to determine how hot the transistors/fets are getting that are turning the shunts on and off. That is an important piece of the puzzle once we start to go over 2X the current.
-methods
methods
10 GW
10 GW
Postby methods » Fri Feb 10, 2012 4:58 pm
Bah....
The surface mount resistors get up to about 150C. That is above where they can reliably run. Data sheet says they should be de-rated to about 5% at that temp :) That is only 50mW
Ok, on to try the next idea.
I suppose I should go search for all the stuff Gary did with this a few years back... but I am oh so lazy.
-methods
methods
10 GW
10 GW
Postby FastDemise » Fri Feb 10, 2012 5:08 pm
He just removed the surface mount stuff then just had a single 3.9ohm in its place. It is what I did and I just modified the case to hold the resistors outside the case for proper space to cool. Works great. I'll post pictures after class. It's nothing pretty but stays dramatically cooler.
21" Hardtail, Docs Torque Arm, Lipo 20s2p, ebikes.ca 9C 8x8 and Lyen 6fet (both Mineral Oil cooled)
FastDemise
Postby methods » Fri Feb 10, 2012 5:20 pm
When you guys say "remove the surface mount resistors" are you guys actually doing all that work or are you just strategically cutting the traces?
Ok - doing the big ceramic mod.
-methods
methods
10 GW
10 GW
Postby FastDemise » Fri Feb 10, 2012 5:50 pm
I did all the work and removed them. Be curious if it runs cooler and therefore more accurately as well.
FastDemise
Postby methods » Fri Feb 10, 2012 6:07 pm
Here is another epic fail in the making.
3.9ohm
5W
Notice how there is a nice air gap between the resistors and the board. Nearly all of the resistor body is outside the case. These would be secured with a bead of silicone. My V3.0 BMS worked on these - never had a problem
They are a just a tiny bit too wide - had to cheese the last one.
4.2V / 3.9ohms = ~1A
70% Duty cycle = ~ 750mA
I like three quarter amp shunt current....
.75^2 * 3.9 = ~2.2W
Again - about 50% of the power rating. NEVER run a power resistor anywhere near its power rating without active cooling. Always look up the de-rating chart to see how much power it can run **@ temperature**
The way a power resistor is rated -> they tell you how many watts it can dissipate IF you were to hold it at room temperature (magically). But once it heats up to 100C or 200C its rating goes way down.
hmm... thinking back... I had a huge computer fan blasting these last time I used them :mrgreen:
-methods
methods
10 GW
10 GW
Postby methods » Fri Feb 10, 2012 7:00 pm
Works good - gets up too about 120C balancing a 10Ah 6S pack down to 4.0V
Yea... those would work... but now I am thinking about some axial resistors outside the case.
I don't really want more than 500mA - anything over that just gets more complicated and hotter than it needs to be. Double the performance is good.
-methods
methods
10 GW
10 GW
Postby amberwolf » Fri Feb 10, 2012 7:17 pm
I guess it would take (per channel!) somethign the size of the whole unit (or even the size of a 6s pack!) to balance at the same rate that a good charger could output current at. Like, 1C-2C for the pack. :lol:
amberwolf
Postby methods » Fri Feb 10, 2012 7:29 pm
If you wanted to just radiate - yes.
But Fans are amazing... with a fan you can fit 10X the power in the same package.
Working on a radial version right now. Found some 6.8ohm resistors that I probably got for a Gary project back in the day.
-methods
methods
10 GW
10 GW
Postby parabellum » Fri Feb 10, 2012 7:32 pm
methods wrote:I don't really want more than 500mA - anything over that just gets more complicated and hotter than it needs to be. Double the performance is good.
How many current can the transistor take?
parabellum
Postby methods » Fri Feb 10, 2012 8:01 pm
Its a surprise :P
We will know when the smoke comes out.
-methods
methods
10 GW
10 GW
Postby methods » Fri Feb 10, 2012 8:05 pm
Ok - here is prototype number 3
6.8ohm axial resistors
in parallel with stock resistors
4.2ohms total impedance
700mA balance current (after duty cycle)
1W developed on the external resistors
Good air space in there - though it can only be worse than in the factory configuration.
Give er a test now...
-methods
methods
10 GW
10 GW
Postby bigmoose » Fri Feb 10, 2012 8:07 pm
methods wrote:
parabellum wrote:...How many current can the transistor take?
...We will know when the smoke comes out.
-methods
I love the thought of electronics being tortured! :twisted: "Turn it up," I say... "Turn it way up!!"
bigMoose's electronic pieces & parts (GENUINE IRFB4110Pbf's, Nomex 410, AntiCorrosion Grease, Current Sensors) available HERE.
Thanks to Justin ebikes.ca for securing the board then setting us FREE! Tech Tips in the WiKi: http://endless-sphere.com/w
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
bigmoose
Postby Ypedal » Fri Feb 10, 2012 8:37 pm
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby methods » Fri Feb 10, 2012 8:45 pm
The Axial resistors resistors seem to work the best so far but they are butt ugly.
They get hot, but not so hot that it takes your skin off. 100C
Thinking about drilling the board so that we can plug them in like thru-hole real fast.
Let me know if anyone has any ideas. I will take them... and make money off of them... with no credit for you :mrgreen:
-methods
methods
10 GW
10 GW
PreviousNext
Return to Battery Technology
Users browsing this forum: andrew.box, dnmun, Eascen, Electric Junk, hillyterrain and 5 guests
