Internal resistance tester
Postby 999zip999 » Mon Jan 30, 2012 10:22 pm
I was looking for internal resistance tester. there was a thread about one but couldn't find it. If any one could help. i think it was 39.99usd . Thanks
999zip999
Re: Internal resistance tester
Postby neptronix » Mon Jan 30, 2012 10:51 pm
I'm thinking an expensive multimeter would work... am i right?
neptronix
Postby Spicerack » Mon Jan 30, 2012 10:59 pm
Maybe a real expensive multimeter- to measure the Ri it needs to send an AC pulse through the battery... most of the time it's a very expensive piece of equipment!
You can do a cheap and nasty test but it's not terribly accurate:
Norco Shore2
Was Cellman MAC rear oil cooled now 8x8 9C vented and temp probed
12 FET controller
62V 18650 home made battery pack
50 km/h
http://endless-sphere.com/forums/viewtopic.php?f=6&t=32769
Repair thread http://endless-sphere.com/forums/viewtopic.php?f=2&t=34806
Oil cooling the hubbie http://endless-sphere.com/forums/viewtopic.php?f=2&t=37972
Spicerack
Postby Ykick » Mon Jan 30, 2012 11:10 pm
Voltage drop and current will give you a ballpark but as Andy noted more accurate method uses pulses and another method with sine wave phase shift of V and I to determine resistance of single cells.
Ykick
Postby neptronix » Mon Jan 30, 2012 11:16 pm
Yeah, that will measure Ohm, but many lithium batteries will be in the mOhm range..
I know the iCharger and Hyperion chargers can do it; not the most accurate devices in the world, but they give you a general idea upon which to compare other batteries.
neptronix
Postby IBScootn » Mon Jan 30, 2012 11:57 pm
Check out the model 20R for around $50 out on eBay:
http://www.ebay.com/itm/20R-Internal-Ba ... 4636wt_922
I bought one to test out,
IBScootn
Postby 999zip999 » Tue Jan 31, 2012 12:32 am
Yes, I be scoot em. I think that be the one i'ave been thinking of. Does It work ? It has a kelvin 4 wire probe ? That one ? Thanks guys
999zip999
Postby neptronix » Tue Jan 31, 2012 12:39 am
Ya know.. you could get an iCharger 106b+ for $80.. then.. you'd have an iCharger b+ :P
Just sayin ;)
neptronix
Postby Doctorbass » Tue Jan 31, 2012 1:18 am
IBScootn wrote:Check out the model 20R for around $50 out on eBay:
Yeah.. I aproove, I bought many of those for me and friends.
They work pretty well and accurate.. but they dont tolerate reverse polarity :roll:
So i modified them in two way:
- 4 wire kelvin measurement probe with seperate spring loaded pins for the current sens and the bleed
-I installed a relay that allow to contduct the tested cell and the tester only when the polarity is ok.. simple, cheap and save you from having blown tester!
I paid like 90$ for 3
I will post my review about it ( the SM8124)in the next hour.
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby Doctorbass » Tue Jan 31, 2012 2:09 am
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby IBScootn » Tue Jan 31, 2012 1:33 pm
Thanks for the video doctorbass. Seems like it would be good to put this info into the ES wiki.
Could you also show how you made the modified test probe? I didn't see any dual pogo probes out on eBay, so assuming you just soldered the leads to the pogo pins and shrink-wrapped them up??
Mine is still on slow-boat from china - don't expect to see it anytime soon. But when I get it, I'll modify the leads to pogo; but sounds like I'll need to come up with another reverse polarity protection approach as I have lifepo cells. Dang, I hate products without reverse polarity protection. Anyways, thanks again for the heads-up.
Motorcycle: ZEV 6100, 77V, 40AH, 60+mph; CA, halogen head lights, and faster charger added
Cost to date: $1730, MSRP $6550 - $4120 tax credit - $1200 referrals + $500 mods
Big EV Grin. :)
IBScootn
Postby 999zip999 » Tue Jan 31, 2012 10:49 pm
Thank's Doc that on target need to see again.
999zip999
Postby 999zip999 » Tue Jan 31, 2012 11:42 pm
Shippiing march 1. Couldn't find a faster way ? On ebay ?
999zip999
Postby amberwolf » Wed Feb 01, 2012 12:47 am
They probably sell first, then when they have enough sold they manufacture them. (or order them from some other company).
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby sangesf » Wed Feb 01, 2012 1:26 pm
Doctorbass wrote:
Doc
Where can I get one of those impotence meters?
LOL.. Gotta love yer accent.. That made my day..
sangesf
Postby cassschr1 » Wed Feb 01, 2012 1:58 pm
Doc , when hooked up with reverse polarity just 1 time, say on 4.2 cell does it still blow?
What are the results...like does other functions still work, or does the screen go blank? I have one of these and about a year ago I thought something wasn't right,but didn't know what.
cassschr1
Postby Doctorbass » Wed Feb 01, 2012 4:04 pm
cassschr1 wrote:Doc , when hooked up with reverse polarity just 1 time, say on 4.2 cell does it still blow?
Yes it blow with low voltage too.
The result are that the reading on the LCD make non sense and the measured value is variating and not way from the real value.
no blank display.. just wront displayed value
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby 999zip999 » Wed Feb 01, 2012 9:11 pm
O.k. IBScootingn I order one to wonder if they come on the same boat as amberwolf quessed. Tell me when you get yours and i will tell you when i get mine. Ha Ha . Same boat ?
999zip999
Postby Kin » Thu Feb 02, 2012 11:44 am
Hmm, so is this tester using some more accurate process than the "two resistors in parallel w/known load voltage drop" calculation?
Just wondering, because right now $40 seems like a substantial price to drop for it, if its not going to offer some sort of long term quality.
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Postby SamTexas » Thu Feb 02, 2012 12:42 pm
andynogo wrote:Maybe a real expensive multimeter- to measure the Ri it needs to send an AC pulse through the battery... most of the time it's a very expensive piece of equipment!
Thanks andynogo for the video. One question: What exactly is that cyclindrical blue load device you used?
SamTexas
Postby 999zip999 » Thu Feb 02, 2012 9:33 pm
It's a coil of some kind of wire for resistance. But what kind and for how long ? Yes ?
999zip999
Postby Spicerack » Thu Feb 02, 2012 11:24 pm
Aaah sorree you misunderstanddeee!
Not my video. Shamelessly stolen from youtube, so no idea what value the load is. It's most likely enamelled winding wire. I'm not sure about his resistance value though- I hope he calibrated the multimeter first as quite often they will show about 4ohms just across the test leads....
A better way if you use this method would be to use a proper resistor with a low tolerance.
Norco Shore2
12 FET controller
50 km/h
Spicerack
Postby IBScootn » Wed Feb 08, 2012 6:02 pm
999zip999, my ship came in (ie 20R IR meter arrived today). Shipped Jan29, arrived Feb 8.
Seems to work fine, but need to install the pogo pins as it's too hard to get a good contact with standard probes. But with a little effort, I was able to verify my two new GBS 40AH cells were 2.5mOhms. Once I buy the pogos (yes I forgot to), and get them installed it will be interesting to see if my older 24 cells show any IR increase.
Big EV Grin. :)
IBScootn
Postby IBScootn » Thu Feb 09, 2012 1:21 am
Doctorbass or anyone,
What pogo tips should I buy for the IR meter? I now remember why I didn't buy them earlier - too many choices: P50, P75, P100, pin only or pin & receptacle, etc. Can someone recommend an item off eBay to buy.
Big EV Grin. :)
IBScootn
Postby Doctorbass » Mon Feb 13, 2012 12:34 am
IBScootn wrote:Doctorbass or anyone,
These one seem perfect!
http://www.ebay.com/itm/10pcs-P75-E2-Dia-1-02mm-100g-Spring-Test-Probe-Pogo-Pin-/370580184485?pt=LH_DefaultDomain_0&hash=item56484cdda5#ht_2079wt_1396
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Next
Return to Battery Technology
Users browsing this forum: No registered users and 9 guests
