Burties 'special apparatus' (RC dyno) lives
Postby Burtie » Wed Jan 04, 2012 1:52 pm
Dyno frame.jpg (154.03 KiB) Viewed 1122 times
Dyno display.jpg (47.99 KiB) Viewed 1122 times
http://www.youtube.com/watch?v=nFZ5Gnm9Dws
Burtie
Burtie
Re: Burties 'special apparatus' (RC dyno) lives
Postby Burtie » Wed Jan 04, 2012 1:53 pm
Hopefully I will be collecting some data from this apparatus soon.
I will then be able to bore the pants off you all with many, many, graphs and plots and theories etc...
:D
Burtie
Postby Burtie » Wed Jan 04, 2012 1:55 pm
I forgot to point out. one of the most important components, you might be wondering about;
The cardboard and paper structure in the background, is designed to prevent the generator from spraying grease all the way up the curtains.
Burtie
Postby Miles » Wed Jan 04, 2012 2:09 pm
8)
Miles
Postby Arlo1 » Wed Jan 04, 2012 2:28 pm
Very cool!
And Dave who has some good deals on STUF
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby Burtie » Mon Feb 13, 2012 5:50 pm
It is turning out to be quite of work to get this all functioning well, but it is all coming on slowly.
Dyno wth bulbs.jpg (247.32 KiB) Viewed 991 times
There are now two solutions for the electrical load on the generator:
1) I have added a 2nd controller to allow regeneration from the generator back into the power source. This seems to work ok, and we can recover about half the electrical energy we put into driving the motor.
So, for a 1kw input from the PSUs, I can drive the motor with 2kw.
The disadvantage is that the regen from this Xiechang controller is not variable except by reflashing the parameters, which is a hassle.
I am also concerned that this method may possibly introduce some unpredictable torque ripple, making the whole dyno run roughly.
2) I have built an array of 12v 50w halogen bulbs, which can be configured in several ways ( Delta or Wye, and 12v or 24v), to provide different loads for a given speed.
The whole array is capable of dissipating a maximum of about 2kw of electrical energy, and does a good job of heating my room during this cold weather :)
http://www.youtube.com/watch?v=xhPR8mAKgVk
Burtie
Burtie
Postby adrian_sm » Mon Feb 13, 2012 6:49 pm
This looks fantastic. I want one.
You mentioned you were decoding the display info to get data out of the watt meter. Jonas (Umejopa) reverse engineered the turnigy watt meter code. He modified it to act as a throttle interface between a hall throttle and a RC ESC, including amp limitting etc. So you might be able to tweak the code to your needs if you want. Note: I think the newer Watt Meter models have changed uP, so may only work on old models.
Here is a link to the first post he made publishing the code: memberlist.php?mode=viewprofile&u=16563
I have also noticed that the Amp readings are reported inaccurately at low amps, reporting too low a reading. So if this is your main power measurement, you may want to check calibration.
Keep up the outstanding work.
- Adrian
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Postby liveforphysics » Mon Feb 13, 2012 11:05 pm
I love your amazing work Burtie!!! This is awesome!
More data!
liveforphysics
Postby acuteaero » Mon Feb 13, 2012 11:48 pm
Very cool. This is the killer tool for developing and testing motor control hardware!
Looks like the load cell you're using is one of the cheap ones from eBay seller scale_bargains . Is it? That's what I was thinking about using on my project over here http://endless-sphere.com/forums/viewtopic.php?f=30&t=36803
I'm guessing you're not using their A/D USB board- are you using one of their little amplifier/exciter boards? Or how otherwise are you managing the excitiation/signal conditioning?
Thanks! And again- awesome project!
acuteaero
Postby Doctorbass » Tue Feb 14, 2012 12:12 am
Awsome!..
and for those who would like a great ebike front lamp.. think about it :lol:
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby johnrobholmes » Tue Feb 14, 2012 12:19 am
Very cool, love the torque arm setup!
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
10 GW
10 GW
Postby Burtie » Tue Feb 14, 2012 3:59 pm
Thanks guys, glad you like it.
Adrian, thanks for the tips on the Turnigy watt meter. I will be sure to check the calibration of the sensors before I take any of the readings too seriously.
Acuteaero, Yes the load cell stuff comes from the cheap source on ebay (search for 'load cell kit' ). It uses parts from the 25lb kit.
The microprocessor, and usb link of the kit are not useable for this job, because the firmware wont output any readings unless the load on the cell is absolutely constant (which it never will be on an operating dyno).
The front end of the kit uses an Avia HX711 chip which is a combined instumentation amp and autonomous 24 bit ADC. You can find a summary data sheet for it on the internet:
http://www.aviaic.com/UpLoadFile/hx711_brief_en.pdf
If you look at the kit pcb, you can find two tracks carrying clock and serial data going from this chip (pin 11 +12) to the processor.
You will need to connect your own microprocessor to these clock and data lines to capture the 24bit data which is transmitted 11 times a second.
You will then need to write your own filtering and scaling/calibration functions.
Burtie
PS I like your approach of using a car alternator as the generator and varying the field current to change the load, -very neat :wink:
Burtie
Postby E-racer » Sun Mar 18, 2012 4:39 pm
This thing rocks! i just noticed it. Any clue what the peak power rpm is for a 6 turn delta 80-100?
Kona Stinky: custom swing arm w/ batteries
-13s3p Turnigy Li-po
-Turnigy 80-100 rewound 130kv (Burtie's optical board)
-Kelly KBL 48201
-Nuvinci Dev Kit
http://endless-sphere.com/forums/viewtopic.php?f=28&t=35341
Goped ESR750
-12s2p Turnigy Li-po
-Turnigy 80-100 HXT w/halls
-Kelly KBL 48201
http://endless-sphere.com/forums/viewtopic.php?f=35&t=20732
E-racer
Postby Burtie » Sun Mar 18, 2012 8:59 pm
E-racer wrote:This thing rocks! i just noticed it. Any clue what the peak power rpm is for a 6 turn delta 80-100?
Surely the faster it spins, the more power you can make, all else being equal ?
Burtie
Postby E-racer » Sun Mar 18, 2012 9:59 pm
I've found that is not the case when running a NV cvt. If i set the transmission to hold 5000 rpm my bike is slower than if i set it to 4000. My butt dyno says that 4000rpm +/-500rpm seems to feel about the same. I'd love to really know where all the power is.
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby Arlo1 » Mon Mar 19, 2012 1:07 am
I think I read someware there dont like over 10000 rpm so I would think 8-9000 will be where the peak power is. I think with optimal voltage any 80-100 is ~7kw peak!
Arlo1
Postby Burtie » Mon Mar 19, 2012 5:24 am
Yes, I guess when considering the whole system, taking into account the system battery voltage, and the controller limits and controller limiting mechanisms, there will be an optimum rpm for maximum power output.
For this question, I think it is needed to consider the whole system rather than the motor in isolation.
Burtie
Postby Green Machine » Sat Apr 28, 2012 1:46 pm
So i was at the astro flight motor factory the other day and i noticed they had built a similar dyno to test their motors. It was the coolest machine i saw in the whole factory.
However they were using a water brake on theirs, and a torque sensing unit. I think Burtie's design is probably better and much cheaper to build.
I really want to build one of these dynos so that i can test different motor set ups for climbing up pikes...also for testing efficiency of different motors, and getting real data on how reliable and efficient each motor is..even hub motors.
http://www.electricbike.com Between the wish and the thing the world lies waiting.
Green Machine
Postby acuteaero » Sat Apr 28, 2012 2:01 pm
Green Machine wrote:I really want to build one of these dynos
Hey Eric- don't know if you saw the thread I started a while back- viewtopic.php?f=30&t=36803 I wrote a bit about the different types of dynos (waterbrake, etc) there. I am going to finish my dyno up in the next few weeks-ish... in order to do some RC motor testing primarily to get PaulD's bike running reliably. I'm right in your neighborhood- if you're interested you'd certainly be invited to check it out when I get it going. I have some 80100 motors, some 6364 motors and an Astro 3210 to run tests with... Burtie also supplied some details about his software/hardware setup in that thread. Speaking of which...
Sorry for the little thread-jacking there...
acuteaero
Postby Burtie » Sat Apr 28, 2012 2:16 pm
Green Machine wrote:Burtie, is that custom software you are using to get those torque and efficiency readings?
Yes, the Electrcal power in, RPM and Torque data from the various sensors, is all read by a PIC18 u-processor, running custom firmware.
The data from the sensors is filtered and sent out on a serial link.
There is a custom c# application running on the PC that reads the serial data and displays it. This application also calculates efficiency figures and averages, and provides the user with the facilities to calibrate/scale the sensors.
Unfortunately some of the hardware is cobbled together with odd bits from my electronics junk box, so it would not be easy to replicate exactly.
(This is the particular processor board I used: http://www.futurlec.com/ET-PIC_Stamp.shtml )
Burtie
Burtie
Return to E-Bike Technical
Users browsing this forum: No registered users and 10 guests
