http://search.digikey.com/us/en/product ... ND/1630102
It's rated 80VDC 100A (IE Series Magnetic Breaker). And it's only 1.68x2x0.75" (43x51x19mm).
advancedelectricbikes wrote:Class T fuses are probably the smallest form factor for overcurrent protection. However, they are very fast-acting. Consequently, if you have branch or feeder loads with overcurrent protection other than Class T downstream (in series) with a Class T fuse, a downstream fault will open the Class T fuse and leave the downstream overcurrent protection closed. A short circuit and overcurrent coordination study should be done to spot potential conflicts.
liveforphysics wrote:advancedelectricbikes wrote:Class T fuses are probably the smallest form factor for overcurrent protection. However, they are very fast-acting. Consequently, if you have branch or feeder loads with overcurrent protection other than Class T downstream (in series) with a Class T fuse, a downstream fault will open the Class T fuse and leave the downstream overcurrent protection closed. A short circuit and overcurrent coordination study should be done to spot potential conflicts.
Just as an FYI, the 400amp 160v classT took 6 seconds of 4,000amps to blow.
They are not over-current protection at all. They are cabling/battery fire protection.
DrkAngel wrote:Couple possibilities.
Bussmann ACK-200 Fuse. 200 Amp, 72 VDC, Dual Element.
ANL!
Typically used in, up to, 48VDC applications.(Golf Carts etc.)
Cheap enough to experiment with, individual fuses are about $2!
ANL FUSE HOLDER 0 2 4 GAUGE WITH 100A - 300A Gold Plate - US $9.95
DrkAngel wrote:Buss (Bussmann) makes a 80VDC - 125VAC, 200amp model, w/fuse function.
Buss 200 Amp ANN Fuse Limiter ANN-200 ANN200 - $11.99
$4.99 shipping - $1 each additional
fechter wrote:I wonder if you could stick a strong magnet to one of those automotive fuses to make a magnetic blow out?
Return to E-Vehicles General Discussion
Users browsing this forum: kfong and 2 guests
