kiqnkf
I just fixed a slow leak in the rear tyre DAM!!! not a lot of fun to get off... Worth it though... Went for a local stealth mission around the neighbourhood arcing up the local doggies!!!
Re: the charger, can't you put a switch on the side,(switch a resistor) or just drill a hole in the case (using a plastic screwdriver, of course) to adjust voltage?
