jkbrigman wrote:Rollodo - I can't pull what you mean from your words. LiPo charging cautions have already been put to you by hjins in your thread:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=32252&start=60
I'll post pics of multiple batteries when I get the harnesses built and the entire unit charging when I get that built too.
How's your build coming - have you found a donor bike yet?
Rollodo wrote: Yes, I remember those important aspects about LiPo that were pointed out in that thread; I simply wanted you to be aware of the dangers LiPos pose, that's all.
Allex wrote:What about auto balancing during a ride?
If you have a balance harness connected to all cells, should't all of the cells connected in parallel keep the same voltage?
Maybe the principle is the same when charging?
Kin wrote:Allex wrote:What about auto balancing during a ride?
Heya, I just want to do a quick comment on this. It's been partly answered. But I want to make sure that you don't connect the parallel leads between two different 6s packs that are in series, together. Because that would represent a short. .... and ...Different chemistries also have different charging profiles......
Hobbit wrote:Ah perfect, I'm right at the point of ordering/building my first lipo pack. Excellent timing, I know there's loads of info on this forum already but a "lipo for dummies" thread is awesome.
Alan B wrote:Hi James. Charging at 2A into a 5AH battery is 2/5 C or 0.4C
5 amps would be the recommended 1C. Of course as more batteries are paralleled the charge rate can go way up.![]()
I think my Turnigy recommends 2C max, so 1C max is a good limit. I don't like to push things to their max, they set those max ratings for RC use where folks are in a hurry and don't expect their batteries to last as long. 20C is the discharge rate.
theprince wrote:nomad85 wrote:Nice photos![]()
If you run a discharge cycle how many mah do you get out of that turnigy?
20C *5Ah=100A
jkbrigman wrote:theprince wrote:nomad85 wrote:Nice photos![]()
20C *5Ah=100A
Hello "theprince"! welcome to Basic LiPo Thread:
The answer to nomad85's question would not be in Amperes, but in "Ampere-hours" (he says "mah", same thing). To get that number, you would multiply time by Ah.
I'll make ya'all a deal: I'll do some LiPo discharge in the next few days and post the data by this weekend. It would be useful to provide that information in this thread on the Turnigy 6S 20C 5000mA packs, as I'll need that data myself anyway to plan a battery build.
nomad85 wrote: Sounds good. I only get approx. 4130 mAh from my never used zippy 20c 5Ah battery when I run a discharge cycle.
jkbrigman wrote:Here's what the harness looks like when finished. (I didn't use the butt splices, but they can be used later to make other harnesses.) Total cost for this harness came to just under 8 bucks. For what I've spent so far, I have enough bullet connectors and crimp splices that I can make several more cables for an additional cost of about $2 for the cable (more $1.97 extension cords) and whatever I can buy the banana plugs for.
There's no reason the harness has to be for only three - you can make it four, five or six parallel bricks and the 16 gauge stranded copper cable should be able to carry as much current as the little 250W charger can put out. (The cable is rated for about 1300 watts total, at 125V)
I took photos at each step of the way, will start another thread if anyone asks.
Hobbit wrote: That looks like a piece of cake to do.... is there soldering involved or are the wires/connectors just crimped/mashed together?
Kinni420 wrote:built my charging harness today exactly like yours...my soldering looks like someone puked on the wires but works great at .07 ohms lol notice the wire marking for polarization. dont be a nub and cross stuff. camera sux for close ups.
