No brainer bike purchase
Postby dogman » Fri Feb 17, 2012 6:01 pm
When's it a no brainer to buy a broken down used ebike?
Think bike.jpg (57.6 KiB) Viewed 526 times
When it's a THINK, and it's only 40 bucks. And it's virtually unridden. Seriously, casting flash still on the original tires. Man, the original controller must have lasted about 5 min. :lol: No battery, which I considers a definite plus. Who wants another lead doorstop?
16 bucks shipped for a new 350 watt brushed controller, a few minuites stripping useless crapola off the bike, and presto good as new.
Gone is pedelec, and a dumb computer that gave battery level, and told you when to shift up or down and original throttle. Now it's got an old but functional WE thumb throttle and nice clean handlebars. Runs on 24v, so I can use my lawnmower pack, or some nicads I still have laying around like doorstops. I'll take it to work, and use it to get around the condo complex. Perfect for that, it's slow for sure.
Here it is naked.
Side view stripped.jpg (62.53 KiB) Viewed 525 times
Brushed motor and gearbox.
Motor and gearbox.jpg (55.57 KiB) Viewed 525 times
Battery tray
battery box.jpg (63.66 KiB) Viewed 525 times
Lipo in the box
6s 20 ah in battery box.jpg (67.06 KiB) Viewed 525 times
It's not a bad bike really. Goes about 15-16 mph I guess. No speedo on it now, so maybe faster but I doubt it. Nice to have a motor that runs through the gears. Both the motor and gearbox make noise, way louder than any planetary gearmotor. Pretty much sounds just like my worm drive skillsaw. Definitely loud enough to get noticed on the bike trail. But not quite dental drill loud like an EV global bike. Easy as pie to see why this one never caught on. Especially if they toast controllers before you can wear the nubs off the tires. :roll: Hopefully my 16 buck controller will last longer. I bet the controller problem had to do with all that crap I stripped off it. Everything had to go through that cheezy dashboard unit. Now it's just throttle, controller, and I kept the keyswitch.
Slow as hell will be perfect at the condos. It's nice looking at least. Hopefully it doesn't fall apart too fast, but the front fender didn't last a block. On the first bump, one leg of the fender support fell off and tangled in the spokes. :lol:
dogman
Re: No brainer bike purchase
Postby wineboyrider » Fri Feb 17, 2012 6:10 pm
I think I saw this on LC craigslist??? :P :P
ES IS SAVED! THANK YOU JUSTIN.
wineboyrider
Postby MadRhino » Fri Feb 17, 2012 6:17 pm
Sure a good deal.
How much Lipo did you fit in there?
I'd be looking to upgrade the performance. I suppose this motor could stand 36v, and eventually be replaced for a stronger one.
Norco A-Line, 50+ Mph dirt bike and winter commuter... sold
Specialized Demo 8 performance dirt bike
http://img715.imageshack.us/img715/5824/dsc03417ae.jpg
Santa Cruz Heckler, lightweight road racer
Santacruz V-10, performance dirt bike
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby rojitor » Fri Feb 17, 2012 6:24 pm
40 bucks? Wow you made your day! It's a great deal.
rojitor
Postby dogman » Fri Feb 17, 2012 6:24 pm
24v, 6s 20 ah, but more would fit. I was tempted to run it on 10s but I'll be riding it at work, were 15 mph is the speed limit.
Likely I'll run it on nicads though, I have two thrashed old Ebikes Ca 24v packs in the garage. May as well squeeze a few more cycles out of those.
dogman
Postby Jason27 » Fri Feb 17, 2012 7:21 pm
Good stuff! :D
My ebike:
Diamondback with 800 watt hub motor with AllCell 48V 12AH Lithium Manganese battery pack.
36v hobby king lipo as backup.
"Conquering the hills of SF"
Jason27
Postby nechaus » Fri Feb 17, 2012 10:29 pm
what a buy!!!!
keep us updated with it
Magic pie Dual Suspension
Peak 6kw Air cooled
Kelly controller (mini kbs series, smaller than a coke can, can do 80+ battery amps peak, Favorite small controller. Really punchy)
20s 16ah
60 kmh,
Safe, Beautiful handling.
nechaus
Postby veloman » Fri Feb 17, 2012 10:59 pm
It drives through the bottom bracket, just like Optibike. Surely you can get this thing to move....
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby DervAtl » Fri Feb 17, 2012 11:51 pm
Nice find, Dogman! You'll have to keep us updated on how it runs out.
Darryl
__________________________
Specialized Globe Carmel with rear BMC V2
22amp Crystalyte Analog Controller & Cycle Analyst
SFbikes 10ah LiFePo
DervAtl
Postby dogman » Sat Feb 18, 2012 9:10 am
Little cheaper than an optibike, or even a martin. It would be interesting some day, to find a 2000w brushless motor that fit on the tranny. Hardtail makes it useless to me to ride further than 5-6 miles, so not much point in doing anything much with it. The condos at work are just big enough to cost time to walk it. We have two schwinn trikes there, and now I'll use the think to get around the place faster than walking, but not too fast.
dogman
Postby knoxie » Sat Feb 18, 2012 9:16 am
Hey Dog great purchase, its not all about speed you know :D whats wrong with range? you might need earplugs though or your mp3 player ha ha, I like the goofy look of it too, nice spot and so cheap that is doesnt really matter.
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby Drunkskunk » Sat Feb 18, 2012 10:27 am
Wow! Nice find. If you're going to use it at work, you could buy a nice Ping for it, and write it off as a buisness expense. :D
Drunkskunk
10 GW
10 GW
Postby Ykick » Sat Feb 18, 2012 10:58 am
Nice find to dabble with a BB drive. Interesting rear section design? Room for fat tires?
Ykick
Postby dogman » Sat Feb 18, 2012 1:22 pm
Bike would go the distance, my crushed lumbar disks wouldn't. it's why I require FS for a 30 mile ride. It's not a buisness, but I'm tempted to put some 6s lipo on the work credit card. No big deal if my nicads revive enough.
It could at least go balloon cruiser tires for sure. Wide rims on it too.
dogman
Postby blueb0ttle2 » Sat Feb 18, 2012 3:26 pm
Man I'm jelly.
You folks are right, that should get pretty peppy if you are running through the drivetrain.
"I'm not the smartest fellow in the world, but I can sure pick smart colleagues."
-Franklin D. Roosevelt
blueb0ttle2
Postby dogman » Sun Feb 19, 2012 7:29 am
Still a brushed motor. You know what those do when overvolted much. If I'd had a 36v controller around though, I'd have likely just run it on 36v.
Finally rode it some yesterday. My tired old nicads are pretty tired. Got about 4 miles range from an 8 ah 24v pack. Too see what would happen, I tried to start from the stop sign in the highest gear. Woah, talk about a spike. Voltage sagged about 6v. I'm so used to lipo now, so these half used up nicads sure don't do great.
It's definitely sensitve to what gear you are in. Have to downshift for every stop, at least to the middle gears. Quite a pain in the rear after years of riding hubmotors that leave a stop sign fine. Down at the condos, it will just stay in the low gears all the time so still a good bike if you just ride sub 10 mph.
dogman
Postby amberwolf » Mon Feb 20, 2012 1:07 am
dogman wrote:dumb computer that gave battery level, and told you when to shift up or down and original throttle.
Save that thing...depending on how it outputs that up/down indication, it could be used to activate autoshifting on a chain drive or other gear-shiftable drive. :)
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby dogman » Mon Feb 20, 2012 8:12 am
It's not tossed, you can have it sometime. Not sure if I'll be heading west anytime soon though. Cheap enough to ship to you.
the tranny has a sensor on it too, so that was how it was done.
dogman
Postby amberwolf » Sat Feb 25, 2012 2:24 am
Actually I was thinking that if you ever wanted to do another bike with a middrive, you could use it to do the gearshifting. ;) Or even reinstall it on that bike, and set up a motor to do the shifting part.
But eventually I could probably use it once I worked out a method for motorizing the shifting of the gears. I'm sure eventually we'll run into each other at a Death Race or something, once you're feeling better enough and I am able to get away from work and dogs long enough. :)
amberwolf
Users browsing this forum: badhorsie, dl1955, docnjoj, Drunkskunk, Observator, Racer_X, spinningmagnets and 17 guests
