Crystalyte Controller Tech Specs Location?
Postby kudos » Fri Feb 24, 2012 5:52 am
Hi,
Is there anywhere that has the real world voltage & current range for the Crystalyte digital sensorless controllers?
I'm confused because I see different values in a lot of places.
I have the 36 - 48V 40A controller. On the back it says low voltage 29V, I asked Crystalyte Europe for max voltage and they said 55V.
...and yet on ebikessf.com they list the two sensorless controllers as having the range 36 - 60V & 65 - 89V.
On Crystalyte.com they range from 24V 25A to 72V 48A
From Jimbo's thread, he says he has the 72V 45A controller (and yet on the xylte europe site it says 72V 40A?) but seemingly has run it at 84V and 50A ( i didn't think you were supposed to push the current past the rated limit???)
So confused, what are the real world ranges?
Kudos
Build 1A Gary Fisher Wahoo Hardtail : Crystalyte HS3540 40A 49V : 31mph
Build 1B Gary Fisher Wahoo Hardtail : Mac 10T 30A 49V : 27mph
Build 1C Gary Fisher Wahoo Hardtail : Crystalyte HS3540 40A 82V :
Build 2 Mountain Cycle Fury FS : Mac 10T 30A 49V : in progress
kudos
Re: Crystalyte Controller Tech Specs Location?
Postby nebriancent » Fri Feb 24, 2012 6:32 am
the real world limits are the same as any controler
find out what mosfets and caps are installed subtract 10% for a saftey margin and thier you go thats the controller voltage limit
differand sellers will have differant caps and mosfets installed in the same controler modle to get diferant max voltage and amperage limmits and this is not uncomen
as for the low voltage cutout it can be adjusted by swaping out a resotor on the pcb
so if you want "real world specks" aske the seller what his are set up as
so..... in conclution all the answers you ba e recived up till now are most likly right
diferant seller diferant setup diferand max values
if at first you don't succeed...dont force it just grab a bigger hammer
back to my gm 901 for now 26"
modified infineon ebikes.ca 40-100a 36-72v controller w/ cruise http://endless-sphere.com/forums/viewtopic.php?f=2&t=37068
4s 14p liMn (doc makita pack) and headway 2p 10s in serries
cycle anylist 2.3
top end on flat is about 48kmh hot off the charge
range >40km
best distance in a single charge about 75km
xvision front light. led marker light rear w/ limiting resistor for tail/stop operation
nebriancent
Postby kudos » Fri Feb 24, 2012 7:34 am
I wasn't aware that suppliers actually physically altered the controllers, i thought they were standard.
Right then, thanks for that. I'll just ask the supplier in future.....
kudos
Postby nebriancent » Fri Feb 24, 2012 1:06 pm
not a problem
cycle anylist 2.3
range >40km
nebriancent
Postby docnjoj » Fri Feb 24, 2012 3:49 pm
Changing out the power resistors on any so-called Infineon is really easy to do. I had to when I was running 54 volts to keep the 12 power chip happy. Dnmun gave me the formula for the values and it was quite simple to actually do. Perhaps he can chime in if he remembers those numbers. I think the pictures were destroyed by one of the outages. The new values also seem to work at 36 volts also, like I run now.
otherDoc
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
Postby JanicekTrnecka » Tue Mar 27, 2012 9:24 am
Hi,
I am also little confused about Crystalyte controllers, there is no manual, only wiring schematics( yeah, sometimes this is enough) . And as I searched through this forum I discovered there is some connection between CLYTE and Infineon controllers.
From local dealer I got infomration that programming is possible only from CLYTE display.
Could somebody brighten it up a little for me?
I am about to decide between those two:
Crystalyte 36-48V/40 A
Crystalyte 72V/45 h - is it possible to make it work wit for eg. 4 SLA 12V batteries ? Just for starters before I manage to get 60V pack?
What about lo-voltage cutoff? Is there any usb/rs232 programming and interface available ? Thx.
EDIT after munching some more pages of this forum, crystalyte arent programmable by anything else than their "display"
Last edited by JanicekTrnecka on Tue Mar 27, 2012 11:09 am, edited 2 times in total.
JanicekTrnecka
Postby kudos » Tue Mar 27, 2012 9:36 am
What do you need to know about the controllers?
I have the 36-48V 40A which I got from Crystalyte Europe, they tell me max voltage is 55V.
I have the 72V 40A coming in the post to me right now from ebikessff which has a voltage range of 65 - 89V
Crystalyte Europe do a 72V 45A which has a max voltage of 99V.
I have the Crystalyte APM Display unit which allows you to 'program' the contoller. You can set LVC on this as well as current etc.
4 x 12V sla batteries gives you 48V nominal, however it will be more than this freshly charged. As long as the total voltage in not above 55V for the 36-48V controller you should be fine.
Kudos
kudos
Return to E-Bike Technical
Users browsing this forum: fluid2150, Google [Bot], Observator, Peter Sternersson, zappy and 9 guests
