frodus wrote:always overdesignThat's my motto!
<snip>
and BTW, thanks for the help John. We were considering load resistors too, but ended up going with driving them in their dissipative mode.
Nice Travis! Glad I could help.
<snip>
Alan B wrote:Binary weighted resistors and switching FETs are another way to go. Simple control and gives a good range of loads with 8 banks. Don't need ammeter readout, just voltage and known resistance values is enough if the resistors are stable.
Alan B wrote:You could also combine the two techniques. A small adjustable linear load, and a number of binary weighted resistor banks to switch digitally in or out. The resistors can operate at much higher temperatures than FETs, and the FETs are in switchmode on/off so they have little heat. Up to about 15 amps no heatsink even needed for a good FET. The 4110's the OP has are suitable for this.
Here's my BAD (Big Ass Discharger)..... working on the gate driver and controll circuitry right now, but the mechanical side of it is done....
Designing for ~200A per module, and there's 6 of em..... still need to find some decent fans, these get hot! Each pair of modules protected with a contactor and fuse and each unit has it's own shunt. I know it's overkill, but we plan on testing some serious loads.
CamLight wrote:You're right about the possible power handling of that sink! It looks like you'll be able to hit around 1000W if you bring the FETs up to their absolute max operating temperature. Probably about 770W if you derate the max temp to 80% for reliability.
The AOT410L looks like a decent FET to use. The thermal resistance is about 0.85C/W (0.35 theta-jc + 0.50 theta-cs) and that's good, lower than the typical 1.0C/W or so for most TO-220 FETs.
I've lost track...are the TO-220 resistors going to be the current sense resistors or drain resistors to take some of the power dissipation away from the FETs? I'm only asking because if they're current sense resistors, you'll have to subtract the power they'll dissipate from what the MOSFETs could handle (if resistors and FETs share the same sink).
Looks good! Anxious to hear about how the testing goes.
magudaman wrote:So it looks like at 100c these and all other through hole resistors are really only rated at 40%. So I think I may drop down the .02 Ohm for final design so more heat will be coming out of the FETS but still around 100W.
Anyways its still moving forward. I'll play some more tomorrow.
CamLight wrote:magudaman wrote:So it looks like at 100c these and all other through hole resistors are really only rated at 40%. So I think I may drop down the .02 Ohm for final design so more heat will be coming out of the FETS but still around 100W.
Congratulations on that successful smoke test!
I may be misunderstanding your post but one big advantage to using thru-hole resistors, versus using TO-220 resistors on the same sink as the FETs, is that the ambient temperature for them is 25C or so. That's allow them to run at 100% power (which isn't recommended for any resistor, but you can do it). Only resistors being mounted to the same sink as the FET will have an elevated ambient temperature, which will severely limit their power handling.
magudaman wrote:Well I feel silly but I didn't check it and it turns out the FET died! That is why the resistors blew too! It failed in a short. So that is no promising either
CamLight wrote:Ouch! Sorry you're having to deal with that. I had practically a jarful of dead FETs by the time I was done.
While you're replacing the FET, shorten all wires as much as you possible can and mount the FET gate resistors directly to the gate pin. That can help to reduce any oscillations that can fry the FET (even at very low power levels).
If you're still having problems after that (or to try everything you can now)...
- Have the op-amp's power/GND leads connect to the protoboard near the op-amp.
- Decouple the power/GND leads with a big cap (10uF min, 100uF is good), with short leads, before having short power/GND jumpers going to the op-amp.
- Add a decoupling cap (ceramic, 0.1uF or so) with short leads across the GND/VCC pins of the op-amp.
- Add 0.1uF and 1uF-10uF caps to the non-inverting pins of the op-amp (to GND near the op-amp's GND pin) to swallow any noise on those lines.
- Shorten the leads of all the resistors as much as possible and mount everything as close to the op-amp as possible. Really, really close. 1/8W resistors are great for this. The 1/4W ones can go vertical though.
- Power the circuit with a battery pack (short leads!) instead of a switching power supply and power the fan (if used) from the switcher. Join the switcher's GND lead to the pack's GND at the battery pack, not near the protoboard.
- Keep any fans, switcher power supplies, and other devices away from the protoboard and heat sink.
Alan B wrote:A CBA schematic is available somewhere on Candlepower Forums. Probably a hand reverse engineered version. There is a lot of CBA experience over there. The hotwire guys run some pretty amazing power levels in their flashlights, and various lithium battery packs. Not quite ebike levels, but more than you'd probably expect. My hotwire regulator is good up to about 15 amps and 40 volts and they wanted higher voltage upgrades for it.
Alan B wrote:You might check batchpcb.com, they have good pricing and are Eagle friendly. They collect a bunch of boards onto a larger panel and send it out so it takes slightly longer but the quality and pricing is good. Looks like your suggestion has better pricing, don't know much about them though.
Eagle is common but a painful program to learn and use and expensive to do anything commercial with, so I keep looking for other choices.
Users browsing this forum: Bing [Bot] and 11 guests
