This is my first OP, and my first ebike video. Here's a big THANK YOU to my Dad, for sharing his experience, time, tools, and toys!
I would also like to thank all of you, for freely giving your time and knowledge...especially Justin for keeping us alive!
Most of the info is in the video and youtube description. I have re-posted the bike specs here, below the video.
The first climb has a 13% average grade, and a section of 30% maximum! Average speed on the first climb was 32 mph, top speed on the downhill was 53mph!
I recommend you either mute the video, or turn the volume down, because of wind noise.
Clown Bike specs:
-Steel, full-suspension BMX frame, with custom clamping rear dropouts.
-Konion V Cell battery pack, 20s12p configuration, 18 Ah, 1332 Wh.
-18fet 4130 Controller, shunt modded to 60A, ventilated with a centrifugal PC fan.
-Scooter hub motor from China, stator dimensions 200mm D x 40mm W. Drum brake. Custom ventilation capitalizes on centifugal effect, and works like a charm - motor is always cool. It creates some noticeable drag, though.
-Motocycle 14" rear rim, spokes, tubeless tire. Front 20" bike wheel.
-Cycle Analyst from ebikes.ca (it rocks.)
-Front hydraulic disc brake, rear drum brake.
-Half-twist throttle, motorcycle kickstand, wide gel seat, custom tail rack.
-Top Speed, flat ground: 50mph... tied for the slowest ebike at our house.
-Max Power Drawn on this trip: 4403 W.
-Bike Weight: 75 lbs, my weight: 175 lbs.
-Range: 20 miles at 40 mph
The GPS elevation profile for this route is here: http://endless-sphere.com/forums/viewtopic.php?f=2&t=36153&p=525312#p525311
Clown bike is getting a controller and battery upgrade soon, so the next video should be more exciting!
