The Tongxin Motor thread
Re: The Tongxin Motor thread
Postby amigafan2003 » Fri Feb 24, 2012 9:49 am
docnjoj wrote:Is there any place that these motors (Tongxin) can be purchased in the US?
Thanks in advance.
otherDoc
http://www.freedomebikes.com/
amigafan2003
Postby Erikjan » Fri Feb 24, 2012 10:44 am
I have this one:
100mm 190rpm motor in 26"wheel: $300
In Holland they are 250 euro.
I use it in 28" rim
Erikjan
Postby docnjoj » Fri Feb 24, 2012 4:09 pm
I looked at the Freedom site and they only have front motors. I ride a trike and would need a rear motor, probably the 260 rpm one for 16-20" wheels as mine are 20". I'm a glutton for punishment as the last Tongxin I had lasted 4.5 miles before the ring gear cracked. I do like light geared motors that don't make noise, however, and figure it would be worth another try at one.
otherDoc
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
Postby amberwolf » Fri Feb 24, 2012 6:38 pm
It's been suggested that a steel band around the ring could prevent the cracking. I'm assuming it would need to be interference-fit to make a difference.
The magnet issues coudl be prevented by applying high-temperature epoxy to them before use, I expect.
Heat issues coudl be mitigated by ventilation, with holes around the outer band between the spoke flanges, and a ring of holes on each side around the bearing area. Wouldn't be good in wet-weather or really dusty areas, though, because of the freewheel and planetary areas not being sealed against such, and getting contamination in the grease.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby Wurly » Mon Feb 27, 2012 4:25 pm
I machined up an aluminium ring to add some more strength after i broke a ring for a second time. You have to undercut it slightly to clear the cover. I then found out the next weak point was the hardened motor shaft which broke up probably because of the extra pressure exerted on it. It seemed like a good idea at the time but caused problems elsewhere.
So i rebuilt it again and left off the machined re-enforcing ring.
My bike has a 260rpm tongxin in a 26wheel, it's been my commuter for the last couple of years. It's very quiet but i know it could break at any moment.
My build - GT LTS
viewtopic.php?f=6&t=35298
Wurly
Postby The Stig » Tue Feb 28, 2012 11:09 am
oh man... anyway to strengthen the shaft?
The Stig
Postby Wurly » Tue Feb 28, 2012 4:50 pm
The Stig wrote:oh man... anyway to strengthen the shaft?
Nope, i don't think so. The best thing is to fit it and enjoy the motor for as long as you can. It may be 4000miles or 4miles, you can never tell.
My build - GT LTS
Wurly
Postby crossbreak » Wed Feb 29, 2012 11:06 am
here is a picture of the epicyclic drive from my tongxin middrive project, it has about 4000km on the clock as a front hubmotor. The axle was twisted after a little clush with a curbstone, so I decided to reuse it as middrive motor. I had no problems with a cracked ring or broken shaft yet.
My first hub conversion middrive (decommissioned): http://endless-sphere.com/forums/viewtopic.php?f=3&t=34146#p495887
. . . Why not, make something that lasts?
crossbreak
Postby Erikjan » Mon Mar 12, 2012 6:01 am
Today i recieved my motor.
The seller vfiets.nl fit a compleet new motor. Top service.
Hope this one last little longer.
Erikjan
Postby fabiograssi » Thu Apr 18, 2013 1:34 pm
What is the best(s) suited controller for this motor(s)??? Where I can get one?
fabiograssi
Postby leffex » Sun Apr 21, 2013 5:35 am
I have a sensorless motor something similar to this. Its same size and looking through one of the holes in on the side of the motor I can se copper winding. If its geared or not I dont know. When I first plugged in my motor with the phase wires it spun the motor but not the wheel. After I changed phase wires for another setting it spun the whole wheel like a normal motor do.
The motor was old stock like 2-3 years from now. 36v rated 6A or something inscription on motor cover.
I use it with 12s lipo and 15a controller. 20" wheel. No overheating just slow topping out at about 20 mph and takes any hill (15% for comparison goes at 15 mph).
:D
My old bike 300W. 2012-06- 2012-08
New bike Leaf 1000W, 54V,30A,10AH) commute 2012-11-
leffex
Postby amberwolf » Mon Apr 22, 2013 12:14 pm
leffex wrote: If its geared or not I dont know. When I first plugged in my motor with the phase wires it spun the motor but not the wheel. After I changed phase wires for another setting it spun the whole wheel like a normal motor do.
Then it is "geared" in that it has a freewheel/clutch inside it, and most likely a planetary setup using either gears or rollers. You'd have to open it up on the other side to see the gearing type, most likely.
If you use it with nearly three times it's rated current, you may melt it down if it bogs down at high load or run it very long at it's less efficient speeds. (the motor itself might nto melt, but if it is geared with plastic gears, they may heat up so mcuh they get soft and deform). Just speaking from experience with a similar but slightly larger Fusin geared hub. :oops:
amberwolf
Postby Ch00paKabrA » Mon Apr 22, 2013 7:06 pm
Are the Keyde motors Tongxin. I was planning on getting one since you have to keep a really low profile here in New jersey. The website that sells them sells a rear wheel w/ disc set up with the controller inside the hub. this is very tempting since with paniers, I doubt LEOs would be able to notice that I am running an electric motor.
If so does anyone have experience with Keyde?
Ch00paKabrA
Postby amberwolf » Tue Apr 23, 2013 12:17 am
amberwolf
Previous
Return to E-Bike Technical
Users browsing this forum: typ49 and 10 guests
