Nice bike light on ebay 24-90V 12w 29.99U$
Re: Nice bike light on ebay 24-90V 12w 29.99U$
Postby lazarus2405 » Mon Feb 27, 2012 10:11 pm
www.recumbents.com wrote:I just received my 12-90V light today. It looks like a resistor inside the light, but it is really a thermal switch (labeled ZH KSD-9700, 250V 10A 65 degrees C). That's 150 degrees F. I think the in-line DC-DC converter is performing the current limiting duties. Mine did not even have a back on the light, so the thermal switch is in plain view. I'll post some test results later.
-Warren.
Thanks, that makes a lot more sense. So the driver is an actual CC LED driver - it just has a wide input range. That also means that you really can't run the light off a 12v source without the driver module.
If anyone can tell more specifically which actual LED emitters are in this thing, I'd be interested. Close-up pictures might help. Thanks.
lazarus2405
Postby stinkler » Mon Feb 27, 2012 10:26 pm
best I can do with my crap camera.
stinkler
Postby miuan » Tue Feb 28, 2012 7:13 am
I've only ridden about 100km with mine so far due to bad weather. I like it and would recommend it for any bike. Get two for 35+ mph. The driver is a switched supply with current limiter and gets quite warm but not hot. The casing gets hot with no air flow, but stays cool during the ride.
miuan
Postby parabellum » Tue Feb 28, 2012 8:34 am
-Warren.
I suppose you guys are right about CC led driver, just noticed it is not doing any CV function, I have full input voltage on the output if not connected to leds, so 12v on LED side is just coincidence and will change with temperature of led chips. Sorry for misinforming everyone.
parabellum
Postby www.recumbents.com » Tue Feb 28, 2012 1:13 pm
Though I haven't actually looked at the flamethrower end of the light while it is on, it appears to have smaller LEDs between each large LED, can anyone confirm that those light up too?
-Warren.
www.recumbents.com
Postby parabellum » Tue Feb 28, 2012 6:11 pm
www.recumbents.com wrote:Though I haven't actually looked at the flamethrower end of the light while it is on, it appears to have smaller LEDs between each large LED, can anyone confirm that those light up too?
-Warren.
Those are kind of pins on the lens holding led pcb in place.
parabellum
Postby www.recumbents.com » Sun Mar 04, 2012 4:11 pm
You get what you pay for, so the included mounting brackets were pretty useless and I had to make my own. Also the wires between the light and the driver are heat shrinked, but not soldered. Here it is installed on the bike.
-Warren.
Last edited by www.recumbents.com on Sun Mar 25, 2012 8:48 am, edited 1 time in total.
www.recumbents.com
Postby NeilP » Sun Mar 25, 2012 3:42 am
Do you recon one of these can be rigged directly to the CA power pads from the battery in the same way as the e-bikes.ca Cycle Luminator is?
The GF does not want a bright light on her bike...yea, weird I know, but I fitted my 1200 lumen lamp to her bike a while ago, and she did not like it..she want to see less..women eh?
So any idea what sort of current these (as listed in the topic title) draw
At this price I may even order two
Neil
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
10 GW
10 GW
Postby Alan B » Sun Mar 25, 2012 10:24 am
I wonder what the difference is between the 24-90V and the 12-90V models. The regulator must be different. They have all gone up a few dollars, and the wider range regulator is 35$ compared to 33$ for the 24-90. But it might be more useful in some situations.
These regulators are switching, Neil, so they will draw constant power, more or less. So the current will = 24 Watts / ?? Volts, just like the Cycle Lumenator. So the current should be pretty low if your voltage is high.
Might have to put a pair of these on the 'Borg... :)
Alan B
1.21 GW
1.21 GW
Postby NeilP » Sun Mar 25, 2012 10:47 am
Not a massively high voltage..just a 12s pack on the gf's bike so only 50volts...so it will be half an amp or so in that case.
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby johnrobholmes » Sun Mar 25, 2012 11:18 am
Here is a light I saw on another moped forum. DX special http://www.dealextreme.com/p/10w-800-lu ... 26v-101461
I hear the beam is funky and square, but for that price it is hard to beat.
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
10 GW
10 GW
Postby NeilP » Sun Mar 25, 2012 11:27 am
Yes, that is a nice little lamp, but to run that on the gf's bike I would need to run a dc-dc.., like the Cycle Luminator has
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby Alan B » Sun Mar 25, 2012 8:57 pm
johnrobholmes wrote:Here is a light I saw on another moped forum. DX special http://www.dealextreme.com/p/10w-800-lu ... 26v-101461
The optic is focussing the LED die into the pattern. That type of design is usually low in efficiency due to the lost beam coming from the LED at angles wider than the optic. Their quoted output is probably die lumens, the actual output will likely be far less.
The TIR optics on the Lumenator, or the lamp that is the subject of this thread are generally more efficient as they capture all the output from the LED and reflect it internally very efficiently. Also the high voltage converters on these lights are helpful if you don't have 12V available on the bike.
It would be interesting to see a side by side beamshot to verify this.
Alan B
1.21 GW
1.21 GW
Postby NeilP » Sun Mar 25, 2012 11:12 pm
Well I just ordered two of the ones in the subject of the thread
If I ever remember. I will at least try and post a beam shot of these against a know lamp
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby NeezyDeezy » Mon Mar 26, 2012 2:24 pm
FYI geoman gear has the 1000 lm magic shine on sale this month -- it's better IMO because it ships from the US.
NeezyDeezy
Postby bobale » Mon Mar 26, 2012 4:13 pm
NeilP wrote:I will at least try and post a beam shot of these against a know lamp
That's a good idea, can't wait this light to be properly compared to other known lamps. It's still not warm enough here to ride during the night, but soon it will be, and I'm very interested to see how this light stacks up against single LED P7 and XM-Ls.
RWD 2807 9Continent rolling on Kenda Flame 26x2.125
12S3P out of Turnigy 4S Hardcase 20C (600Wh)
35A 9FET Infineon Controller (Regen, Cruise control, Speed limit)
Top Speed 27mph (31mph@120%)
bobale
Postby curious » Mon Mar 26, 2012 6:23 pm
NeezyDeezy wrote:FYI geoman gear has the 1000 lm magic shine on sale this month -- it's better IMO because it ships from the US.
Do you know if it will work with a remote switch or you always have to cycle the button on the light itself ? Also, what are the power requirements ?
bike1: hardtail frame, 5304 rear, 850wh a123 66v/33v switchable, Kelly KEB72601, proportional regen;
bike2: bikeE FX recumbent, sensored bafang front on a 16" rim, 16s a123;
bike3: work in progress (slow), long range SWB touring recumbent, >1.5kwh pack TBD, Kelly KBS72101, likely HT35 hub, proportional regen.
curious
Postby NeezyDeezy » Mon Mar 26, 2012 6:40 pm
When it's plugged in it by default comes on high, without buttons, so depending on what you want to do a switch would work. I think it takes about 15w, but don't quote me on that. I have one, and now a second on the way.
NeezyDeezy
Postby curious » Mon Mar 26, 2012 7:01 pm
NeezyDeezy wrote:When it's plugged in it by default comes on high, without buttons, so depending on what you want to do a switch would work.
Good, since I have a remote switch on my recumbent bike. One more question - is it relatively white or has the bluish tint ?
curious
Postby NeezyDeezy » Wed Mar 28, 2012 4:42 pm
It's white without the blue tint.
NeezyDeezy
Postby iovaykind » Wed Mar 28, 2012 5:21 pm
It's definitely white, but there is a bluish hue to it.. not cool white, definitely not warm white.
Winter needs to end already!
iovaykind
Postby curious » Tue Apr 03, 2012 4:41 pm
Not sure we are talking about the same light. I just got the MJ-808E XML head from geomangear and it does not "remember" the power setting and always comes in the "off" state when plugged in. The remote switch is not an option.
Few notes for those considering it:
- It takes 0.8A on full at 12.5V, there are 3 levels of brightness and no blinker.
- It has a clearly defined round spot (a bit small to my taste, I am used to flood beam) and rather weak flood area.
- The color in the spot is a pleasant white (warmer than my trailtech HID) with no blue tint (if anything there is a very slight greenish tint to it). There is some blue tint in the flood area but not in the spot.
- Mounting may be a problem for some, the light does not pivot and sits very close to the handlebar (uses rubber rings instead of a usual clamp). It may interfere with the cabling because of proximity to the handlebar (it does on our bikeE recumbent had to move things around to mount it).
curious
Postby auraslip » Tue Apr 03, 2012 10:42 pm
So do one of these lights start in the ON position? I have my current halogen lights and tail lights rigged up with a simple spst switch to my 12v dc-dc. I like this simplicity.
auraslip
1.21 GW
1.21 GW
Postby parabellum » Tue Apr 03, 2012 11:58 pm
auraslip wrote:So do one of these lights start in the ON position? I have my current halogen lights and tail lights rigged up with a simple spst switch to my 12v dc-dc. I like this simplicity.
Yes, the subject of this tread does.
parabellum
Postby auraslip » Wed Apr 04, 2012 4:11 am
Awesome. I ordered one. I was going to run two, but decided it might be over kill.
auraslip
1.21 GW
1.21 GW
PreviousNext
Users browsing this forum: dendy, Eric, will_newton and 5 guests
