A-Lines Abound: Electric drive implosion
Postby MattyCiii » Sun Feb 26, 2012 7:57 pm
Call me late to the party, but I've joined the A-Line club. Here's my build:
A medium frame Norco A-Line, pedal powered on the right by legs through a NuVinci N360, electric power on the left via a Recumpense DaVinci drive.
Lots of pieces missing... The next to be installed will be the shock, a used Fox DHX 5.0. I'm installing it with a needle bearing kit from Real World Cycling (http://www.enduroforkseals.com/id275.html), I hear they're worth the cost.
Hopefully I'll have at least a pedal bike out of it soon, seat post and seat are on order but have not even purchased chain, chainring or cranks yet (I have some ISIS front freewheel trials cranks lying around, is there such a thing as thread-on front chainring adapter?)
Last edited by MattyCiii on Fri May 17, 2013 4:48 pm, edited 32 times in total. View post history.
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike.
MattyCiii
Re: A-Line's Abound: Another A-Line build...
Postby MattyCiii » Sun Feb 26, 2012 7:58 pm
The bike in its current form.
Updated 1 August 2012
MattyCiii
What's next:
1) Finding a place to mount the electric drive.
2) Fabricating brackets to hold the drive in that place.
3) Figuring out where to mount the batteries.
MattyCiii
Reserved
MattyCiii
Postby fractal » Sun Feb 26, 2012 8:04 pm
Love those wheels Matt!!!! Subscribed!!!
Norco A-line DH bike with :
«cromotor/hubzilla» from http://www.greyborg.com/
24s 3p Lipo (100v, 15ah)
Methods LVC/HVC cell level protection system http://www.methtek.com
24 fet infineon controller made by Lyen, heavily moded by Methods
8awg harness by Icecube57
17 inch moped rims with Michelin Gazelle tires by John Rob Holmes http://www.holmeshobbies.com
other stuff http://www.ebikes.ca
details
http://endless-sphere.com/forums/viewtopic.php?f=6&t=31850
fractal
Postby MattyCiii » Sun Feb 26, 2012 8:26 pm
Those are certifiable ES wheels:
Spokes by JRH,
Rims from the Recumpense 47mm wide, 406mm rim group buy.
The tires are Pirelli 16" x 2.5" moped tires. Something I never would have thought would fit a 406mm rim without the ES collective knowledge base.
Up front the hub is a Lefty (of course) hub custom machined by Project321 (http://www.project321.com/), who was incredibly helpful in getting me the right parts to fit a lefty fork to the Norco. Stopping power from a Hayes Prime Pro and 203mm disk.
Out back the wheel is laced to that NuVinci N360. I've removed my dropouts in anticipation of Magudaman's replacements http://endless-sphere.com/forums/viewtopic.php?f=3&t=35654&p=532410#p518345 coming hopefully in March.
I gotta thank MadRhino for the tip about Magura Gustav M brakes
Image, there's not a lot of room between the brake rotor and the drive sprocket.
MattyCiii
Postby ohzee » Sun Feb 26, 2012 8:39 pm
I do love those norco's.. sweet a$$ bike's that's for sure.
Look forward to the build.
ohzee
Postby Andje » Mon Feb 27, 2012 8:29 am
Welcome to the a-line build club. There are surely more of us building these bikes then riding them at the moment, so you're not late to the party yet! I'd say this summer will be owned by the A-lines :). You're the first using a Davinci drive though; the rest of us so far are doing hubbie builds. I wish you the best of luck!
Norco 125 Dirt Jumper
100v 15ah Lipo Backpack
lyens 18 fet, 100v 100 amps, R12 Regen
x5304- 95km/h
http://endless-sphere.com/forums/viewtopic.php?f=3&t=24594
Norco A-Line Park 2009
144v Kelly 300amp
5403/ future HS60
http://endless-sphere.com/forums/viewtopic.php?f=6&t=35652
Andje
Postby kfong » Mon Feb 27, 2012 9:08 am
Nice DH setup. Wheels look amazing.
kfong
Postby MattyCiii » Tue Feb 28, 2012 6:42 am
Not even 1/2 built and I'm already making changes. I'm using Magura Gustav M brakes on the rear because of the tiny, ~10mm clearance between the left hand chainring and the brake rotor. I got the Gustav as a pair of used brakes through Pinkbikes - I paid $250 for the pair, bleed kit, and a bunch of parts including rotors and pads to last me a long time.
Now I'm thinking - why use the Hayes on the front - why not go with Gustav front and rear? That way I can standardize on one type of brake, carry only one type of spare pad, and have all that Gustav stopping goodness on the front, where it'll do me some good. Of course, I don't have the correct mount to use the front on my fork, so I'll have to figure out which one is right for me and buy more parts...
MattyCiii
Postby sn0wchyld » Tue Feb 28, 2012 8:03 am
HA were breeding like rabbits it seems!
Andje wrote:Welcome to the a-line build club. There are surely more of us building these bikes then riding them at the moment, so you're not late to the party yet! I'd say this summer will be owned by the A-lines :). You're the first using a Davinci drive though; the rest of us so far are doing hubbie builds. I wish you the best of luck!
Andje, your comment got me thinking... am I the only one atm with a running aline? I saw one short vid where someone (cant remember who) had extended the wheelbase by like 1.5 feet :shock: , but dont know if that was just prototyping...
mattyc how are you dealing with the BB height given your running effectively ~22" wheels front and back? I'm striking all the time unless I'm going straight, and even then only when it's pretty flat! mine's a 26" front, 22.6" rear (mX rim/tyre)
LOVE the lefty. It still amazes me that they can be built strong enough to withstand all the abuse DH/XC brings, but that one looks beefy enough for sure!
what motor are you using? Have you given any thought to putting it just infront of the rear wheel, in the space created by the smaller wheel + extended drop-outs?
I think I'll be joining you in the non-hub aline club by years end... the HT works well, but I do miss the nimble rear end/suspension...
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby MattyCiii » Tue Feb 28, 2012 8:51 am
sn0wchyld wrote:mattyc how are you dealing with the BB height given your running effectively ~22" wheels front and back? I'm striking all the time unless I'm going straight, and even then only when it's pretty flat! mine's a 26" front, 22.6" rear (mX rim/tyre)
Good question. I definitely want to pedal this bike a lot - though it will be a beast. I'll have to get short little crank arms. I'll also have to specify a "lowering" of the dropouts when it comes time to commission replacements. I want to go 2" to the rear already. For every 1" down, that's like adding 2" in wheel diameter, right? Maybe I'll have to go 2" down, 2" back. A longer shock would help too, wouldn't it?
sn0wchyld wrote:LOVE the lefty. It still amazes me that they can be built strong enough to withstand all the abuse DH/XC brings, but that one looks beefy enough for sure!
I love how there are as many genres of bikes as there are breeds of dog. Beach cruisers, trials bikes, BMX, I can tell these apart. But I can't tell between some of the close cousins - what makes a DH bike different than a FS mountain bike?
When I was talking to Project321 about putting a Lefty on the Norco, they warned me a Lefty is not tough enough for DH use. That's fine with me, at age 44 I don't think I'm in the shape, nor frame of mind, to take up DH cycling. This build is more along the lines of Fractal's A-Line... a way overbuilt commuter bike where I don't have to swerve around potholes or blink when taking curbs. I'm sure the Lefty will handle that!
sn0wchyld wrote:what motor are you using?
I'll be using a low KV Astro 3220 run through a Recumpense DaVinci drive. The Astro is on order.
sn0wchyld wrote:Have you given any thought to putting it just infront of the rear wheel, in the space created by the smaller wheel + extended drop-outs?
That's my plan! DaVinci drive will be very light compared to those monster motors people are putting on these bikes. And forward in the triangle mitigates its unsprung weight even more. Hell, maybe I won't even need a chain tensioner on the left side - we'll see.
MattyCiii
Postby sn0wchyld » Tue Feb 28, 2012 9:30 am
sounds right to me
MattyCiii wrote:I'll be using a low KV Astro 3220 run through a Recumpense DaVinci drive. The Astro is on order.
Great! Exactly what I was thinking for mine too! except using a 80100 rewound for about 55kv, running on about 60-70 volts and a 2 speed dogbox if I can get it all to fit.
Any thoughts to battery placement? I'm buying some new lipo so I can squeze 24s8ah into a box that'll go on the handlebars.
ps
where 'bouts are you from?
My builds:
sn0wchyld
Postby MattyCiii » Tue Feb 28, 2012 9:54 am
sn0wchyld wrote:Any thoughts to battery placement? I'm buying some new lipo so I can squeze 24s8ah into a box that'll go on the handlebars.
Well with the Lefty, I'll have to be creative with placing batteries up front. That is Plan A though. Plan B is to always ride wearing cargo pants...
sn0wchyld wrote:ps
Boston Mass. I just updated my profile. There's a chance I'll cross paths with ES member Gestalt tonight at a bicycling event here in Bean Town.
MattyCiii
Postby gestalt » Wed Feb 29, 2012 1:06 am
MattyCiii wrote:There's a chance I'll cross paths with ES member Gestalt tonight at a bicycling event here in Bean Town.
Damn straight, now I've met two ES members in person.
That Aline is looking sweet. With a davinci drive, astro and a bunch of lipo you'll be rockin the baddest ebike in Boston. Not a lot of competition for that title, but none the less.
As for me, I need about 20 feet of some 1 1/2" chromolly to bend a new frame out of on the 'ol fire escape. Oh...and my tax return.
- be seeing you
gestalt
Postby recumpence » Wed Feb 29, 2012 8:41 am
Looks good.
There are a number of us working on downhill bikes with 20 inch wheels right now. I have two full suspension freeride frames (not quite as beefy as a downhill frame, but with longer suspension than a cross country FS bike) that I am looking at. As for bottom bracket hight, yes, you will want to do something about that. I am making a custom rear suspension linkage on my Diamondback X6 frame to accomplish this. One thing about raising the rear end is that the headtube angle increases as you raise the rear. However, a downhill frame already has a relaxed headtube angle. So, increasing it slightly may not make that much difference. I do like the longer wheelbase that a 26 inch bike with 20 inch wheels appears to have. It looks more like a motorcycle. 26 (or even worse, 29) inch bikes have a distinct bicycle look to them, while a 26 inch frame/20 inch wheel setup definately looks more motorcycle.
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
10 GW
10 GW
Location: On Earth right now. That can change at any time, though..........
Postby zombiess » Wed Feb 29, 2012 2:48 pm
ZombieSS like 20" wheels on A-Line :D Check's bank account... nope, not happening for a while, too many other projects.
Greyborg Hub Motor, Lyen 18FET, Customized full suspension kids MTB. Top Speed 61 MPH
9C 8x8, 24S2P LiPo, Lyen 12 FET, Diamondback Recoil Comp. Top Speed 42 MPH
GreyborgUSA Dealer
zombiess
Postby MattyCiii » Wed Feb 29, 2012 6:45 pm
Here are some pictures of the tires/wheels. I took them to cross/post with this post http://endless-sphere.com/forums/viewtopic.php?f=28&t=29888&start=60#p542254, but also to show the wheel in relation to a close cousin: 406mm bike tires on a more standard bike rim.
Both front and rear are 406mm x 47mm rims (from the Recumpense group buy) with Pirelli moped tires:
Here's the whole thing, laced into a NuVinci N360. Mmmmmmm, beefy!
Here it is next to another 406mm wheel from my "daily driver" Dahon folding bike.
The Schwalbe is a 20x1.6 inch tire. Here it is alone:
And here they are stacked.
MattyCiii
Postby rojitor » Wed Feb 29, 2012 6:58 pm
So those are the rims of the group buy, those wheels make most motorcycles feel jealous :)
rojitor
Postby etard » Wed Feb 29, 2012 9:37 pm
That's the perfect setup for high powered ebike for the streets, I can't wait to get my spokes in to lace this up! Those dropouts are sick too man. About the BB clearance on 20's, just put some 150mm crank arms on and you'll have a nice low bike and still have pedal clearance on turns. :twisted:
Hey can you put your calipers around those tires? I'm wondering if the wider rim profile flattens out the tire face at all.
etard
Postby MattyCiii » Wed Feb 29, 2012 9:53 pm
etard wrote:Hey can you put your calipers around those tires? I'm wondering if the wider rim profile flattens out the tire face at all.
67mm.
I have about 4mm clearance between the Lefty and the tire up front!
MattyCiii
Postby Byte » Thu Mar 01, 2012 10:47 am
Nice! Will follow this one! :)
Bergli
Turnigy 80-100 130kv
10S 16Ah LiPo
Castle Creations HV 160
Byte
Postby zombiess » Thu Mar 01, 2012 1:35 pm
It looks like it does flatten it out a little compared to my front on a 20x1.75 BMX wheel, here are some pics I have a 16"x 2.75" ML75 on a standard 20x1.75 BMX wheel on the rear, sorry I don't have pics of the front. The 2.75" and 2.5" are pretty close in profile, not much difference. I wanted a more rounded sidewall for cornering grip. The 2.75" wide might be a better match for the wheel. I really like the way that rim looks, especially if you can fit a 3.0" tire on it.
GreyborgUSA Dealer
zombiess
Postby MattyCiii » Thu Mar 01, 2012 4:23 pm
Damn! That's one helluva rear swing arm extension!
MattyCiii
Postby MattyCiii » Thu Mar 01, 2012 4:35 pm
Suspension:
I'm going to replace the rear shock's bushings with a needle bearing kit from Real World Cycling. First I have to press out the bushing:
Don't need special tools to complete the task. Just some appropriately sized sockets, and a vice. The smaller socket presses against the bushing and bushing collar/spacer, and the large socket will be on the other side against the shock's shoulder.
I'll swing by a friend's place this weekend and use his vice.
Here's what will be installed in its place:
Not a lot of work, but without a vice I can't move forward and install the shock.
MattyCiii
Next
Users browsing this forum: Drunkskunk, rusty67, warrah and 11 guests
