Twin motored PK Ripper--A little over the top!
Re: Twin motored PK Ripper--A little over the top!
Postby recumpence » Tue Feb 28, 2012 8:46 am
The new 20 inch bike I am building will, indeed, use a radical new motor, but not the 4 inch Astro. There are a number of reasons for that. I will get deeper into that on a later thread.
Anyway, I am very focussed on small bike builds. I like the compact design for loading into a trunk, the lighter weight, and the additional strength afforded by the smaller wheels (large wheels tend to be weaker and give more load to the frame). Gear ratio is also easier to deal with for smaller wheels. Also, the fun factor is high on small bikes for bashing around town. :wink:
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
10 GW
10 GW
Location: On Earth right now. That can change at any time, though..........
Postby Wheazel » Tue Feb 28, 2012 8:59 am
Matt, did you settle for any personal favourite "sweetspot" wheelsize? Always a compromise between comfort+rollresistance and all the stuff you mentioned.
Wheazel
Postby recumpence » Tue Feb 28, 2012 10:13 am
I would love 22 inch tires. But, since there are none like that, I lean toward 20s for street and 24 for dirt.
Matt
recumpence
10 GW
10 GW
Postby Ypedal » Tue Feb 28, 2012 10:15 am
I like small nimble, powerfull bikes.. small bike big fun...
My 100v BMX is a riot, not intimidating to sit on, both feet flat on the ground with knees bent, light weight, but hit the throttle while not leaning forward and it's a hilarious outcome lol..
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby recumpence » Tue Feb 28, 2012 10:47 am
No doubt. It is cool lifting the front wheel while leaning over the bars.
Loads of fun........
Matt
recumpence
10 GW
10 GW
Postby Miles » Wed Feb 29, 2012 1:20 am
recumpence wrote:I would love 22 inch tires.
I'm with you on this, Matt.
There are a few narrow 451 rims available (Sun, Velocity et al) but not much choice in tyres for them...
This looks the most promising: http://www.kendausa.com/en/home/bicycle ... eight.aspx
Miles
Postby recumpence » Wed Feb 29, 2012 8:49 am
I know you can get Pireli moped tires that are 22 inch and fit 20 inch rims. They seem very well suited for ebike use, but are much heavier. For a true communter, those may be great. I like to really go light weight on my builds, though and freestyle tires are plenty capable on the road. Bicycle tires also respond better to pressure adjustment for ride quality due to their thinner sidewall.
Moped tires would last FOREVER on a bicycle, though. :D
Matt
recumpence
10 GW
10 GW
Postby Miles » Wed Feb 29, 2012 8:57 am
If one could get 2.0" section tyres for 451 size rims, that would be 22" :D
1 3/8" is the largest I've found.
Miles
Postby Byte » Thu Mar 01, 2012 3:58 am
Question; how did you mount the rear disc caliper to the bike? It looks like you didn't chance anything on the frame. Cause I thought BMX frames are only made for rim brakes?
And another one: Is the rear wheel 19" of 20"? Cause unicycles also use 19" tyres...
Bergli
Turnigy 80-100 130kv
10S 16Ah LiPo
Castle Creations HV 160
Byte
Previous
Users browsing this forum: Bing [Bot] and 18 guests
