allroads wrote:for a Currie e1000 scooter motor ? or is it too much. Currently I have 36V 10ah SLA. Need more distance and time.
Brentis wrote:allroads wrote:for a Currie e1000 scooter motor ? or is it too much. Currently I have 36V 10ah SLA. Need more distance and time.
If the Currie e1000 is a brushed motor it should be ok @ 48v.
You will have to look @ the controller in the scoot.
It will have a label,hopefully describing upper/low limits, with all sorts of stats.
To see if it will be OK @ 48v.
Brushed controllers are relatively cheap. so you can buy a new one, if the original doesn't suffice.
With stock gearing the scoot will be about 25% faster & go 2x as far.![]()
Depending on the LiFe source, over 36v of sealed dead acid.
You will love it![]()
Where are you sourcing 48v15ah LiFePo?
Ykick wrote:allroads wrote:for a Currie e1000 scooter motor ? or is it too much. Currently I have 36V 10ah SLA. Need more distance and time.
Wh math - 36x10 = 360Wh, 48x15 = 720Wh. That's the battery energy available and in reality, SLA performs only about half rating so you're looking at 3-4 times current capacity. Of course if you use the higher voltage for higher speed you'll drain the battery faster.
Another often overlooked parameter is how long your motor will last operating at higher speed and significantly longer run time?
allroads wrote: I like to buy made in USA!
Return to E-Scooter and Motorcycle General Discussion
