Ypedal wrote:Welcome aboard.... bike looks the part !..![]()
Is the rear axle 10mm ?. most hub motors are but some higher end bikes have larger dropout slots.. 12mm+.. .. worth checking before going too deep.
If you want to push well over 1000w, go with a Direct Drive motor ..
The geared motors, BMC/ MAC , are ok if you play nice, on roads... but if you go bashing around with high power non-geared is the only way to go.
Brentis wrote:+1
Almost everyone will warn you against rear rack mount.
lester12483 wrote:I disagree, rear racks work fine.
Brentis wrote:35, But I feel like Im 16 most days.![]()
Brentis wrote:+1
To downtube placement.
That would ruin the handling of such a fine machine.![]()
If you can cut&paste&heat, you could fab. up something for the downtube.
MadRhino wrote:For off road, fitting batteries under the down tube is risky and would need a strong enclosure and skid plate, that would add a lot of weight. I prefer mounting them on the fork, where they are not likely to take a hit and help retaining the original balance of the bike. The 18 fet controller fits in the triangle, where it has good protection and air flow.
LegendLength wrote:Take note the batteries need at least 1/2 inch of room between each other for the cabling, although you could run it down the sides to reduce that to like 1/4 inch.
Personally for that frame I'd go down the 'tiling' route, where you use smaller batteries tiled on each side of the frame rather than the larger 6s batteries. You end up with more cabling but you get a better look. Depends on how much you value aesthetics over quick-build i guess.
Users browsing this forum: Bing [Bot] and 12 guests
