Old School Marin Build
Re: Old School Marin Build
Postby geoff57 » Sat Feb 05, 2011 6:32 pm
Hi
Just read through your build that's one mice job you done there.
I do have one thing to say about your batteries and BMS, you are using headways that have a high output on them but if I am not mistaken you are Using a ping BMS with them the BMS should be great for charging the headways I am putting a "48V" battery pack out of LiFePO4 from hobby king equally high output, with a ping BMS for charging the pack. Unless ping have made a radical improvement in how they make their BMS they will have a amp limiting circuit on the BMS Alongside the LVC circuit, this will probably limit you from getting the best out of your headways you may find that the BMS cuts power from the battery if you try to draw too many amps it ust to be 40A for the big 20aH packs ping made that may have improved now, if you do find that the pack is cutting out on you when you are drawing high amps say on a hill or at the traffic lights let me know.
I have an alternative way of using the batteries with a ping BMS, I have fitted 2 of my 8 channel LVC boards to my pack they work just like the LVC/HVC boars that gary sells but only have the LVC circuit I hope it will be ideal for use in your situation and for the test pack I have just finished building for my wife, you get the LVC protection you need when ridding the bike with the ease of charging that a ping BMS gives you.
You would need 2 of my boards plus probably 4 silicone covered balance wires I am bound to have them in stock.
See if the setup you have gives the amperage output you want and so the speed you want if not and you want mor power than the ping BMS will give you come have a word with me I willshow you how to take the amperage limit out of the ping BMS equation.
Geoff
geoff57
Postby billsy » Sun Feb 06, 2011 5:09 am
Hi Geoff
Thanks for your comments and suggestion's. The Ping BMS I'm using is the high rate version. IIRC it is good for 60A continuous and upto 100A for a couple of seconds. I think it should be fine.
Where abouts in Blighty are you Geoff?
Thanks again
Chris
billsy
Postby geoff57 » Sun Feb 06, 2011 5:33 am
billsy wrote:Hi Geoff
Thanks again
Chris
Hi
Yes that BMS looks like it will do the job my last ping battery was several years ago and things have progressed for the better since then, my idea is still good for those out there that started with a ping a few years ago and their BMS survived when the cells would not hold a charge, this is what I have done I did not buy a new one just new cells.
I'm in Nottinghamshire about 250 miles from you, but if I book in advance about £30 away on the train with my train folder for decimate and my mountain folder if I am lucky.
Geoff
geoff57
Postby billsy » Wed Feb 16, 2011 5:42 am
I put some 'Marzocchi Drop Off Triple' forks on the bike at the weekend. I'm well happy with them. However, went for a test ride, ended up on a road I havnt been down before and hit an object in the road and ruined the rear rim :evil:
So I could do with a little help if possible, I need to find an identical rim so that I can re-use the spokes that 9C supplied. Typicaly this rim (Samson Champion) is impossible to find in the Uk so I'm looking for a 26" rim with a cross section height of 25mm. I think this is the same as a ERD of 530. Can anyone sugest a rim that meets this criteria? I am in hospital waiting to have a shoulder op as i type and so will have plenty of time to ponder my options but won't be touching the bike for several weeks. :(
Cheers Chris
billsy
Postby chroot » Wed Feb 16, 2011 6:39 am
HI-
Your ebike is great!! You might want contact Johnrobholmes for the highly quality rim and spokes. I learned from GCinDC's review on his new rear rim and spokes. he sent his 9C motor to Johnrobholmes and He put best high quality rim and spokes and GCinDC tested stress and abuse on new rim showed high strength and stronger!! Excellent service :)
Here the link you might want check. [viewtopic.php?f=31&t=16218
chroot
Postby billsy » Wed Feb 16, 2011 8:08 am
chroot wrote:HI-
Here the link you might want check. [url=http://endless-sphere.com/forums/viewtopic.php?f=31&t=16218][viewtopic.php?f=31&t=16218/url]
Thanks Chroot I have sent him a PM.
billsy
Postby chroot » Wed Feb 16, 2011 1:21 pm
Welcome, I plan have him replace stronger rim and spokes when I have enough money to buy a xlyte x5303 hub motor and I would rather have everything beef up to handle the nasty monstrous torque and speed demon by xlyte x5303.
I just killed my 9C 9x7 hub motor *sighs* :lol:
Your battery box hang on top on the frame. It gives you great balance and this similar Rebelpilot's ebike. It made me want relocation my 20s2p to front as similar yours.
keep it up! :)
PS. I see you upgrade full length front suspension fork. I am curious how much cost the full length suspension fork and I seems cant find these full length fork anywhere. Is your full suspension comfortable like plush soak the bumps?
chroot
Postby billsy » Thu Feb 17, 2011 7:34 am
chroot wrote:Welcome, I plan have him replace stronger rim and spokes when I have enough money to buy a xlyte x5303 hub motor and I would rather have everything beef up to handle the nasty monstrous torque and speed demon by xlyte x5303.
keep it up! :)
The new forks are amazing actually. They soak up the bumps really well. Problem is, the rear shock (Fox Float RL) now feels a bit cheapo in comparison. I paid £125 ($200) on ebay. They are in great condition. I managed to find a used DH wheel with 20mm thru axle hub to suit the forks for £15 from a local shop so I'm well happy.
What happened to your 9C hub?
billsy
Postby chroot » Thu Feb 17, 2011 12:21 pm
That's cheap you got excellent 200mm travel suspension fork and I gotta start hunt similar your fork for my MTB.
Killed 9C hub motor, I really don't know how did the 9C hub motor died and I even tested volt meter each wires I.E. throttle, controller, ebrake, hall sensor and phase wires. It seems show just fine and I am in process sending my 9C hub motor to Edward Lyen to inspection and repair my 9C hub motor.
In meantime, I ordered 10H aka ampedbikes DD hub motor thru Terry at Hightekbike, The 10H gives little beef up than old version 9C hub motor and they should be here sometime by next monday. Once 10H gets here and same time send my 9C to Edward Lyen to inspection and repair.
Perfect timing for me give a review on 10H hub motor vs 9C hub motor comparison.
I spoke with Danny Ray at ampedbikes to get the tech info difference between 9C and 10H. Here his comment.
We actually designed the 9C 9x7 windings in 2007.( It was actually Jerry one of our local dealers that designs brush-less motors for RC airplanes) We worked with 9C at the time and they only had the 8x8 windings available as they mostly sold in Europe.
We have re-designed the our DD motor 3 times since then.
1. We are using 9x7 windings.
2. We increased the thickness of the internal wiring. (this allows for higher voltages and higher torque due to no heat loss)
3. We use higher end hall sensors.
4. We changed the outer ring that holds the magnets from aluminum to steel. (this gives us about 5% more torque and 5% easier freewheeling)
5. We changed the thickness of the spokes as well as the way they are laced..
6. We redesigned all kits to have the ability to install ISO standard disk brakes (simply swap yours over from your rim)
7. We centered the axle so that dishing is no longer required.
Overall it weighs about 1/2 lb heavier.
Thank you for contacting us!.
Danny L. Ray II
http://www.AmpedBikes.com
chroot
Postby billsy » Thu Feb 17, 2011 4:36 pm
Sounds like you've had a nightmare with your 9C. Hope you have better luck with the 10h it sounds like that bad boy should stand up to some abuse.
Cheers
billsy
Postby gwhy! » Thu Feb 17, 2011 5:31 pm
Hi Billsy,
un-lucky about your rim mate. I have had a quick look on tartbikes and the only rim that I could see that is remotely close to ERD of 530 is a EDR of 532 and that is one hell of a wide rim as well 4.2cm!, tartybikes do a very good range of ( sizes ) a very good quality spoke ( may be worth going for a different rim ) . I also like the forks you have now as well :D , I have managed to get a nice set of tripples for my bike now also 8) . I also bought a, what have turned out to be a very nice rear shock ( for my new FS build ) new from a supplier £34.00 +pp , a absolute bargain (190mm i2i) , its not the lightest shock but do appear very strong and well made and fully adjustable as well ( very smooth and progressive ).
Good luck with the op.
gwhy!
Postby billsy » Mon Feb 21, 2011 10:49 am
gwhy! wrote:Hi Billsy,
The op went well thanks Kevin. Just got to keep the sling on for at least four weeks which is a bit sh1t. :roll:
Thanks for the Tartybikes heads up, they got some very nice stuff. I did manage to find an almost identical rim that is sold by various companies in the UK. It’s a Rigida Matrixx. I now I now, it’s a cheapo rim but the bike will mainly be used for commuting so should be good enough. I am assured that the 36 hole pattern is evenly spaced even though the images on every web site I've seen it on show a grouped pattern. I also ordered some chainsaw files in case I need to file out the eyelets (thanks Ypedal).
What forks did you end up with? Also have you got more info for the rear shock or a link?
Cheers
Chris
billsy
Postby gwhy! » Tue Feb 22, 2011 4:05 pm
Cheers
Chris
Hi Chris, Im pleased the op went well and 4 weeks will fly past ( weather will be better, lighter evenings and warmer .. Riding weather :wink: ) .
I managed to get what is called strata front forks, they have 35mm stantions and are built like a brick sh!thouse ( but one leg is leaking :cry: ) I know very little about push-bike suspension components to be honest ( being a motorcycle person ) but I dont think these forks will let me down and they do feel very smooth with a lot of travel ( even thou they are about 20 years old :!: ) , the trees have a small crack but I have a replacement set of trees that fit so all is good :mrgreen: , the rear shock that I have, is called a tough shock FDR http://www.apro-tek.com/ss/WEB/images/FDR.htm it appears to be a copy of the fox shock , and as long as the seals hold up I am well happy ( I was looking for a coil over oil shock, these seem to be getting pretty rare ) a air shock will be now where near upto the abuse that I intend to put it through :mrgreen: but only time will tell as to the whole suspenssion setup that I now have to how well it lasts ( The whole lot front and rear with spare trees all came to just under £100 ). I got the rear shock from a ebay seller 7diamondmd He do not continually list these shocks but I think he must list them as he gets them, he also sells another make ( but I cant remember what it is off hand ) which was £3 cheaper but they did look identical.
gwhy!
Postby D-Man » Sun Feb 27, 2011 10:12 am
Looks good. How much does that Ping BMS cost?
408 front hub
11000+ miles on sla's.
Michelin pilot sport 2.3
Miles 50
Flats 0
Quality posts will not be sold.
D-Man
Postby billsy » Sun Feb 27, 2011 4:42 pm
D-Man wrote:Looks good. How much does that Ping BMS cost?
D-Man the Ping high rate BMS was $72 direct from ping.
Cheers
billsy
Postby billsy » Thu Jan 19, 2012 6:21 am
nogono wrote:I'm definitely feeling a tugging to attend the Great Commission School this upcoming summer of 2012. I'm curious, will it be module 3?
Ex squeeze me? Baking powder? :lol: :shock: :roll:
billsy
Postby billsy » Fri Mar 02, 2012 7:56 am
billsy wrote:Thanks Knoxie.
I have a question for the collective. I've been thinking that it might be a good idea to rig up some kind of ebrake switch to at least one of my hydraulic brakes. I've read quite a bit on here about reed switches and the mounting thereof and couldn't help thinking there must be an easier option. So I've been scouring the net for a Pressure Switch that I can add to the hydraulic line of my brakes. The only two that I managed to find are linked below but they are meant for cars/motorbike so I assume the activation pressure will be too high and they will be a pig to integrate.
Has this been done before on an ebike?
Can anyone point me to a more suitable pressure switch or more user friendly electrical switch setup?
http://www.surpluscenter.com/item.asp?item=11-2400&catname=electric
http://helperformance.com/store/product_info.php?products_id=3158
Many thanks guys and please don't hesitate to coment on this one.
Chris
Thought I'd do a little update on the above question. It turns out that there is an eBike version of the very brakes that I'm using on the Marin. They are called "Tektro Auriga E-Sub". According to the Tektro site, they are OEM only but a quick Google finds them for CAD$110 not to bad :D
http://www.tektro.com/_english/01_products/01_prodetail.php?pid=131&sortname=Disc&sort=1&fid=1
http://cyclepath.ca/shop/product_info.p ... 1cee582b6a
Also here http://ebikessf.com/tektro-ecomp
I Also just stumbled across this post which discusses a pressure switch that can be added to existing hoses
http://endless-sphere.com/forums/viewtopic.php?f=2&t=30376&p=446570#p446570
Last edited by billsy on Sun Apr 14, 2013 3:58 pm, edited 1 time in total. View post history.
billsy
Postby BATFINK » Fri Mar 02, 2012 9:14 am
That brake switch looks great. Just what I need. Can you buy jut the brake lever or switch on its own and connect it to any hydraulic brake line as it looks like that is the price for the whole brake set?
Sent using Endless-Sphere Mobile app
BATFINK
Postby billsy » Fri Mar 02, 2012 9:52 am
BATFINK wrote:That brake switch looks great. Just what I need. Can you buy jut the brake lever or switch on its own and connect it to any hydraulic brake line as it looks like that is the price for the whole brake set?
I would imagine the lever and calliper are supplied plumbed together. It'd be worth dropping them a line tho. However if you are just buying the lever this will mean you'll be plumbing it in, in which case you may as well just buy the in-line sensor/switch and plumb that in.
Cheers
billsy
Postby Brentis » Fri Mar 02, 2012 9:56 am
Just fabulous work there.
I missed most of this thread.
Before I worked up the courage to post I guess :roll: )
Of particular beauty to me are
Billys' TorqueArmFitted1.jpg (61.36 KiB) Viewed 375 times
Billsy' Side saddle battery EX..jpg (95.39 KiB) Viewed 375 times
Top job. :wink:
Enjoy.
:mrgreen:
Ghetto Build 1.
ScootBike Build 2...
Strong Commuter Build 3...
Brentis
Postby billsy » Fri Mar 02, 2012 6:06 pm
Thanks for the kind words Brentis. I've put 1800 miles on it so far and it hasn't skipped a beat until last week when the power switch on the controller failed. I guess they're not weather proof. Anyway I've ordered one of these 3 way bar switches to replace the controller switch. This will also allow me to switch between hi and low power modes. Happy days.
http://www.ebay.co.uk/itm/HANDLEBAR-KILL-HEADLIGHT-SWITCH-MOTOCROSS-ENDURO-/250950049728?pt=UK_Motorcycle_Parts&hash=item3a6dc9dfc0
billsy
Postby Brentis » Fri Mar 02, 2012 6:14 pm
:mrgreen:
Are you running a front fender?
I see one in one of the pics.
Might help with weatherproofing.
Ghetto Build 1.
Brentis
Postby billsy » Sat Mar 03, 2012 5:57 am
Brentis wrote::mrgreen:
Yes I have a nice big rear fender on the front as shown in this pic. I take it off when going off road. The lower rear fender is actually the front one from the set. They keep the crud off of my equipment :wink: :D
billsy
Previous
Users browsing this forum: kent1956 and 13 guests
