Ebike Project 72V HS3540 UK "build thread" +Videos!
Re: Ebike Project 72V HS3540 UK "build thread"
Postby Trackman417 » Fri Feb 10, 2012 11:58 pm
Damn, I don't think I would ever be able to live with myself if I had that much stuff on my handlebars. How's the motor holding up? Is it getting warm on trips? Are you pushing the full 72V 40amps into the motor yet? :evil:
K2 Sidewinder
H4065 36 mph
20s2p 10aH lipo battery pack
If it didn't kill you, it just built your character.
You know your bike is powerful when even you, the builder, can't control it.
Customer 00001 at our very own Bigmooses online store http://mtg-technologies.com/zencart/ Great guy, great products.
Trackman417
Postby rui_fujino » Sat Feb 11, 2012 12:12 am
Trackman417 wrote:Damn, I don't think I would ever be able to live with myself if I had that much stuff on my handlebars. How's the motor holding up? Is it getting warm on trips? Are you pushing the full 72V 40amps into the motor yet? :evil:
YOU ARE THE 100th POST! :mrgreen: lol
Yea its not too bad having that on my handlebar, but some of us in this forum do have insane amount of stuff on it :shock:
And yes I&ve run full 83v 50amps into the motor and since UK has been so cold my motor is doing perfect! :wink: Infact I can WOT for 5min and still dont get warm! but then the controller do get little warm :roll:
Project 1: Apollo slant hard tail MTB 52v lifepo4, conhismotor, 52T-11T gearing 39.6mph top speed (with pedal)
Project 2: Diamondback s:10 Full suspension 20s2p (83.5v 10ah Lipo), 35kg, HS3540 sensored (MethTek), 12FET lyen controller, Bulk 600w balance charger.
Top speed 45mph(72.4km/h)
Project 3: DOPPELGANGER d2 Visceral
Project 5 Specialized Epic20s2p (83.5v 10ah Lipo), 30kg,HS3540 sensored (MethTek), 12FET lyen @ 50A
rui_fujino
Postby Trackman417 » Sat Feb 11, 2012 8:12 am
Haha well that's good! And yeah that's true about some people having so much more stuff on the bike than you do.
That's really awesome the motor doesn't get hot WOT riding at that power. I was hearing so many stories about the HX motors over heating that I was getting concerned and I'm going to run 40 amps do that should make a big difference in heating as well 8)
K2 Sidewinder
H4065 36 mph
Trackman417
Postby rui_fujino » Mon Feb 13, 2012 7:46 am
Well, recently (last week) I had a problem with connectors getting wet by the snow and my mud guard being useless...so I bought these from eBay and hoping to prevent my connectors getting wet.
Does anyone know better ways of waterproofing connectors while still being able to connect and disconnect the wires?
rui_fujino
Postby rui_fujino » Wed Feb 15, 2012 9:28 pm
My multi Switch arrived today! so this is my plan, I'm going to swap green horn push switch to normal switch so that push and it will stay on.
I didnt realise horn switch is smaller than red switch,,,but little sanding and all perfect! now my switch can turn on off my lights and controller!
(haven't thought about what R/L switch should do yet...)
also my BMS charger that are broken; Im trying to fix it so I'll upload few pictures when I know the problem...
but mean while here is what they look like inside:
rui_fujino
Postby rui_fujino » Mon Feb 20, 2012 5:09 pm
I've been away over the weekend and didn't get to ride it due to something went wrong with my motor and it started to make vibrating sound and no power...I suspected water got into halls connectors while its been snowing.
I've checked all and finally when I was about to give up I saw this...
Rusting 5pin connector
(202.95 KiB) Downloaded 5 times
they are suppose to be waterproof as well as that, I put so many layers of heat shrink and all....I've cleaned them up and now its back and running :D
On other news, I couldn't figure out what went wrong with my BMS Charger 2 so I've decided to transplant broken parts from charger 2 to 1 and see if I can get one of them working...
rui_fujino
Postby rui_fujino » Mon Mar 05, 2012 8:00 pm
Its been quite a while since my last post but yet again, I made silly mistake...I accidentally shorted my battery for the second time. (Never charge when ur tired). I've checked the cells and they look fine (thank god!)
I haven't had time to make any upgrade or add switches but I'll do them soon.
Interesting news: my from speedometer has gone crazy when I hit 58mph going down the hill and it think it did 90mph!!
90mph?!?!
rui_fujino
Postby rui_fujino » Wed Mar 07, 2012 1:23 pm
Last night I took my shorted connectors and replaced with new sets and here is what I saw... :shock:
After KFF
I never thought those massive connectors could melt...
rui_fujino
Postby BATFINK » Wed Mar 07, 2012 5:21 pm
Nightmare Rio, electricity can melt a lot of things, I remember taking a factory apart and as I was disconnecting a wire from a live socket (some idiot was supposed to have shut it down) there was a big blue flash and the electricity melted the screwdriver, it actually cut the end clean off!!!
Sent using Endless-Sphere Mobile app
BATFINK
Sorry I meant Rui :-)
BATFINK
Postby electr0n » Wed Mar 07, 2012 5:26 pm
How did that happen to your connectors? Did positive touch negative?
electr0n
Postby rui_fujino » Wed Mar 07, 2012 7:24 pm
electr0n wrote:How did that happen to your connectors? Did positive touch negative?
I was balance charging four sets of 5s2p and I've accidentally plunged battery and battery together instead of battery to the charger.
rui_fujino
Postby rui_fujino » Tue Apr 03, 2012 9:01 am
Its been a LOOONG time since I updated! so here is whats going on!
My laptop died(7years old) so I decided to clean it up and upgrade to new HDD plus installed ubuntu(no virus) :mrgreen: ...then I've got my self chain cleaning tool from ebay>>>
http://www.finishlineusa.com/products/chain-cleaner.htm
It is super effective! I really do recommend you guys to get this :wink:
Here is state on my ebike>
Clean bike!
Currently no change other than cleaner chain, disk brakes and a new side mirror :)
I do recommend using "white lightning Clean Streak" it removes all the dirt/oil/lube with strong degreaser spray and at the same time the liquid evapurates so no need to wipe them after! disk is now soo much stronger without squeaking! :D i've used it for chain cleaning as well!
Almost forgot, BMSBattery are doing sale at moment any all the charger has reduced price! since I am still struggling to fix mine I've got myself 400w charger for only $40!!
rui_fujino
Postby Trackman417 » Tue Apr 03, 2012 11:55 am
Looks good! However one thing that is concerning me ought now is where u placed ur lock. I mean sure it's a good place to put it, but if it some how gets caught in the spokes and you are at speed, you could get thrown off the handlebars. :cry:
I hope this helps!
K2 Sidewinder
H4065 36 mph
Trackman417
Postby rui_fujino » Tue Apr 03, 2012 2:15 pm
Trackman417 wrote:Looks good! However one thing that is concerning me ought now is where u placed ur lock. I mean sure it's a good place to put it, but if it some how gets caught in the spokes and you are at speed, you could get thrown off the handlebars. :cry:
I hope this helps!
Hahahaha funny how ur the first person to mention that :lol: , I've actually already had this problem but what happened was my lock just got ripped off the mount and nothing was seriously damaged :P but If you can think of better placement I would love to hear about it!
rui_fujino
Postby Trackman417 » Tue Apr 03, 2012 7:26 pm
How about rotating it so the lock is facing the other way? So when it bounces into the spokes the spokes will spit the cables out.
K2 Sidewinder
H4065 36 mph
Trackman417
Postby rui_fujino » Thu Apr 19, 2012 7:37 am
Finally, I bought another BMS charger (this time is 400w) cos it was cheap....I can finally charge bulk again! :mrgreen:
I didnt notice before but 400w charger is inch smaller than 600w ones...which is quite handy for the size!
BMS Charger
Also another good news, Doc's torque plates has arrived so i can now officially use regen setting on my bike! :D
Doc's torque arms
rui_fujino
Postby rui_fujino » Thu Apr 19, 2012 2:13 pm
Bad news...Yet again by BMS charger let me down :evil: charged my battery half way and capacitor seem to have blown up :roll:
Im going to make the complain and might as well try nd replace the cap...but I think from now on i'll use Original KP charger fromhttp://www.evassemble.com they are better quality then BMSbattery so if anyone planning to get them...DONT!
Edit:
here is the picture of what seems to have gone wrong...
(131.46 KiB) Downloaded 6 times
(127.32 KiB) Downloaded 6 times
rui_fujino
Postby Trackman417 » Thu Apr 19, 2012 7:31 pm
Yeah I think you should stop buying chargers from BMS lol
Just my $.02
K2 Sidewinder
H4065 36 mph
Trackman417
Postby rui_fujino » Tue Apr 24, 2012 8:53 pm
Trackman417 wrote:Yeah I think you should stop buying chargers from BMS lol
Just my $.02
well I agree with you on that. but since my complaint seem to have gone through. they told me they'll send me a new one asap! :mrgreen:
But then I didnt want 400w so I asked them if you could send me a 600w ones..then they said no problem! :shock: So! I will wait and see how that'll treat me...
I have looked around for alternative ones and I think this is the best you can buy!
http://www.evassemble.com/index.php?main_page=index&cPath=3&sort=20a&page=2
Ev assemble looks like the original source of alloy shell but they are much better and they do offer warranties :wink:
rui_fujino
Postby pchen92 » Wed Apr 25, 2012 8:47 am
Did you modify the charger so it can charge your lipo up to 4,15V/cell ? Or do you use it @ 83,6V ?
pchen92
Postby rui_fujino » Wed Apr 25, 2012 9:03 am
pchen92 wrote:Did you modify the charger so it can charge your lipo up to 4,15V/cell ? Or do you use it @ 83,6V ?
I didnt make any modification so yes they are just charge to 83.6v...but in case your wondering about the individual cell then I've got battery medics to balance them while bulk charging :wink:
rui_fujino
Postby pchen92 » Wed Apr 25, 2012 11:39 am
And you plug the battery medic everytime you use the batteries ? ie when charging and discharging them ?
How many of them are you using ? 4 ?
What's your range ?
thanks
pchen92
Postby rui_fujino » Wed Apr 25, 2012 11:45 am
pchen92 wrote:And you plug the battery medic everytime you use the batteries ? ie when charging and discharging them ?
What's your range ?
thanks
yea i use them once in few charges not all the time. ( I've never discharged my batteries lol)
yea i've got 4 of them so that i use one per 5s2p.
I've got 10Ah but I use only 8Ah, since I pedal quite alot and I dont go WOT so i get range of about 20~30miles
rui_fujino
Postby pchen92 » Wed Apr 25, 2012 11:55 am
Ok thanks you. I'm gonna make a Giant DH Team w/ HS3540 @ 74V 45A (max but in town I'll set it to 25-30A) w/ 20S2P of lipo on a 24" wheel.
pchen92
PreviousNext
Users browsing this forum: chrashing, Google [Bot], ioputielmomo, Rassy, zerogee and 5 guests
