Miles wrote:How about the following idea for connecting up the coils?
- Before assembly, crimp the ends of each coil strip around a gold-plated tube (bullet connector?).
- Use gold-plated copper wire to form the bridging links.
- Wire is a push fit into the ID of the tube (end could be tapered).
fechter wrote:On your rotors, it might be good if there was a small lip on the OD to help keep the magnets from flinging off at high speeds. I don't trust glue that much. Also, if the rotor hub was mild steel, it could help the back iron or replace the back iron.
Why would it be better?fechter wrote:I guess you're suggesting making the cores longer to fill the space. It would be better to move the rotors inward to shorten the gap.
Miles wrote:fechter wrote:On your rotors, it might be good if there was a small lip on the OD to help keep the magnets from flinging off at high speeds. I don't trust glue that much. Also, if the rotor hub was mild steel, it could help the back iron or replace the back iron.
Yes, I'm intending to put a lip on, possibly by milling shallow pockets for each magnet, which would also give the spacing.
I haven't modelled that part here, yet. It's something that came out of Thud's epic "MULE" thread: viewtopic.php?p=214408#p214408Kingfish wrote:On the connections between coils, it is apparent how the outer layers are wired though not obvious how the inner are connected with the flatness of the inside end-turns: How is this accomplished?
The original plan was to have a centrifugal fan doubling as the brace separating the two rotors. Now, I'm not sure that will be necessary....? It would be a continuous addition to the parasitic losses. The passive cooling from air flowing through the stator, around the large areas of exposed copper, should be pretty effective.Kingfish wrote:What is your plan for active cooling?
Yes. In fact I've just been contemplating this very point, as I'm starting to model itKingfish wrote:The only issue I can foresee is that one side of the coil will have more pull due to the double-back unless the begin & end terminations are on opposite sides of the coil – so that you have the same count of conductors on each side. Make sense?
Users browsing this forum: No registered users and 5 guests
