CroBorg Commuter
Re: Greyborg Warp Build Planning
Postby zombiess » Mon Feb 27, 2012 8:32 pm
MattyCiii wrote:
chroot wrote:@gensem - Really, I'll check with zombies later after I meet up with ilia and Lyen in SF today.
Chroot,
Did you get to talk about price, or availability of the Speed Drive? Speed Drive seems like just the ticket for pedal-augmented e-power!
I've got one for my bike and will eventually have more in the future (don't ask now), but I need the tool to cut the bottom bracket so it will fit and I don't have that part yet. Supposedly one of the guys I know here in town has access to the tool so I'm going to try and get my race bike to him so I can get it installed.
Greyborg Hub Motor, Lyen 18FET, Customized full suspension kids MTB. Top Speed 61 MPH
9C 8x8, 24S2P LiPo, Lyen 12 FET, Diamondback Recoil Comp. Top Speed 42 MPH
GreyborgUSA Dealer
zombiess
Postby Alan B » Sat Mar 03, 2012 12:29 am
I received the chainring and bolts for my ATS Schlumpf drive.
Unfortunately the bent ear on the drive is not ye straight enough to take the bolt, and it causes the chainring to wobble. So I'll have to see if I can straighten it out better (or break it :( ). Wish me luck.
Alan B
1.21 GW
1.21 GW
Postby Alan B » Sat Mar 03, 2012 12:30 am
Also received the seatpost. But it won't fit into the frame tube. Have to look into that more carefully. Hopefully it can be coaxed in without a lot of trouble.
Alan B
1.21 GW
1.21 GW
Postby Philistine » Sat Mar 03, 2012 1:36 am
I had to sand inside the seat tube a bit for the post to fit. It ended up being such a tight fit, that I don't have a clamp on my post (it just stays stuck), and I wouldn't be able to move it without a lot of trouble. That was because I didn't sand all the way through the seat tube (very hard to do that), so be aware that the suggested tube is a very tight fit.
Philistine
Postby Cicada » Sun Mar 04, 2012 11:31 pm
I went trough this same issue:)
Easy fix (30 minutes), drill a screw (hexagonal head is best)into a shorted piece of broom handle,
cover the piece of wood with enough sand paper to make it spin (hold with tape at the extremities)
and rub the inner seat post tube with a drill.
Easier than what you think.
"Try again. Fail again. Fail better"
Greyborg Warp 80v A123, 18fet controller, Greyborg Hubzilla
http://evlab.co.nz/2012/greyborg-build-awesome/
http://vimeo.com/51900545
Cicada
Postby Alan B » Mon Mar 05, 2012 12:26 am
Thanks for the tips. I will give them a try.
Alan B
1.21 GW
1.21 GW
Postby motorino magnet » Thu Mar 08, 2012 3:44 pm
Philistine wrote:I had to sand inside the seat tube a bit for the post to fit. It ended up being such a tight fit, that I don't have a clamp on my post (it just stays stuck), and I wouldn't be able to move it without a lot of trouble. That was because I didn't sand all the way through the seat tube (very hard to do that), so be aware that the suggested tube is a very tight fit.
no sexual innuendos....
motorino magnet
Postby BATFINK » Fri Mar 09, 2012 8:26 pm
Thanks for the photos, do you mind Giving a few cost details for such a build. Interested in price of frame mostly. Looks amazing. I visited greyborg site but his online shop seems to be offline
Sent using Endless-Sphere Mobile app
BATFINK
Postby Alan B » Fri Mar 09, 2012 8:40 pm
Probably best to get costs from Zombiess or Accountant. I don't have the numbers handy and things are changing.
Alan B
1.21 GW
1.21 GW
Postby Alan B » Fri Mar 09, 2012 9:03 pm
Received Pedals and Chain.
Need to package hubs (front and rear) for shipment to wheel builder.
Alan B
1.21 GW
1.21 GW
Postby cassschr1 » Sun Mar 11, 2012 9:38 am
Alan, what are you using for the rear freewheel.
cassschr1
Postby Alan B » Sun Mar 11, 2012 9:52 am
Haven't chosen one. The White is the best, but it appears that it won't screw all the way down. The Dicta has threads all the way through but reviews indicate it isn't as good quality. ACS also may have quality issues.
One concern I have is if the freewheel fails the pedals will start spinning. That would create a major problem at speed.
So I have not decided. I would like to use the White Brothers unit. To get it all the way down might require shortening the threads on the motor. The fully threaded freewheel is the easiest route.
Shortening the 24FET controller
My 24FET controller is about 1/8" too long. The extrusion is longer than it needs to be, so my plan is to shorten it. I was wondering how I was going to clamp it in my small mill to shorten it. Recently I got a 120 tooth 12 inch non ferrous blade for my chop saw. It cuts aluminum like butter. So I think I will use that on the controller extrusion. I'll work up some clamping, but with this blade there is no vibration or noise cutting aluminum. So that's the plan at the moment.
Alan B
1.21 GW
1.21 GW
Postby cassschr1 » Sun Mar 11, 2012 9:58 am
can a regular free wheel be disasembled and used ?
cassschr1
Postby Alan B » Sun Mar 11, 2012 10:06 am
I've never tried to disassemble one. I think they are not easy to take apart, and we need a small cog and narrow width, so the design is likely different.
Alan B
1.21 GW
1.21 GW
Postby cassschr1 » Sun Mar 11, 2012 12:12 pm
Do you know if 20a pouch cells fit in the frame....how many?
cassschr1
Postby Alan B » Sun Mar 11, 2012 12:27 pm
I have not looked into the dimensions of pouch cells.
Alan B
1.21 GW
1.21 GW
Postby gensem » Sun Mar 11, 2012 12:45 pm
If you a carefull you can fit like 24-28 (depending on the clearance you want front the side cover) 20ah a123 pouchs, but be aware that you ll have to bent the cells a little.
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
gensem
Postby Alan B » Sun Mar 11, 2012 1:18 pm
gensem wrote:If you a carefull you can fit like 24-28 (depending on the clearance you want front the side cover) 20ah a123 pouchs, but be aware that you ll have to bent the cells a little.
That is about 1.5 kwh of A123. Nice. :)
Is that using both battery storage areas on the frame?
Alan B
1.21 GW
1.21 GW
Postby chroot » Sun Mar 11, 2012 2:14 pm
You can ask Luke or ilia, I think they have dud or dead A123 pouch 20Ah and ask them if they could donate you so you can test the fitting measure inside the frame. 8)
chroot
Postby gensem » Sun Mar 11, 2012 2:41 pm
Yes, I did some research on that subject a while ago, but decided to test the cromotor before ordering battery for the warp frame.
gensem
Postby markobetti » Sun Mar 11, 2012 5:10 pm
you can fit 48 hewadways inside ..without bending ....still 1.5 kw
markobetti
Postby cassschr1 » Sun Mar 11, 2012 7:46 pm
Markobetti,can the bending of the cells be avoided by using the wider side covers. Cass
cassschr1
Postby Alan B » Mon Mar 12, 2012 4:33 pm
Decided to go with White Industries 16 tooth ENO freewheel. Ordered.
Will have to deal with the thread depth.
Less costly freewheels are probably fine.
The White product is clearly the best in class.
Freewheel failures are not too common but can result in crashes.
Alan B
1.21 GW
1.21 GW
Postby Alan B » Sun Apr 15, 2012 12:25 pm
Looking at brakes
The Greyborg standard forks have dual disc capability. So what dual mirrored calipers are available?
Looks like only two. The Gatorbrake 8 pot, and the Magura BIG Twins. Any others??
Freewheels Again
Received the White Industries. It will take an 8mm spacer to avoid having it bottom out on the motor threads. The motor threads are wide. Not sure if this is a problem until the swingarm is together and more measurements are made.
Alan B
1.21 GW
1.21 GW
Postby zombiess » Sun Apr 15, 2012 1:29 pm
Alan B wrote:Looking at brakes
Greyborg told me Hygia does duals that work. I've been wanting to order some Hygia brakes to test them out but have been holding off until I get my own frame and fork because I want the dual fronts. From what I've read the Hygia brakes look pretty nice and are reasonably priced for complete setups. If someone buys them I hope they do a review. I really want to buy a set myself right now just to test them out on my race bike which currently has Hayes Strokers on it, but it's not in my current budget right now.
GreyborgUSA Dealer
zombiess
PreviousNext
Users browsing this forum: animal, Bing [Bot], Google [Bot], Grey beard and 10 guests
