rojitor wrote:Yes 1440w your maths are right. I pedal only at low speeds, in the middle of the traffic i pedal all the time and between towns i go fast so i don't pedal at all.
d8veh wrote:I wouldn't take too much notice of that 30A written on the controller. The only way to be sure is with a meter. I had a KU123 that gave 40amps and a 25A controller that only gave 14A.
Your main problem is that the motor gives maximum torque at low speed, which makes it difficult to control. Look at some of the threads about smoothing the throttle.
Haste wrote:casainho, what kind of battery are you using with the bpm?
Assuming the battery is located at the rear of the bike, you get a better weight distribution (as opposed to a typical front wheel drive).
Also, practically you get a two wheel drive (rear wheel pedaling and front wheel motor assistance). A two wheel drive is better for use on slippery surface because you get better handling (Just like a four wheel drive automobile). Another thing is that the front wheel motor assistance won't cause any unintended wheelies on sudden acceleration.
d8veh wrote:The KU93 is the controller you want - not the KU63. The KU63 is for a 250W motor and won't be powerful enough.
d8veh wrote:You can get a 11T free-wheel from Ebikes.ca. You can also get your torque arms from there.
http://www.ebikes.ca/store/store_ezee.php
casainho wrote:BMSBattery just started to sell torque arms
miuan wrote:casainho wrote:BMSBattery just started to sell torque arms
Wow. They have made some serious progress during recent 12 months. The price is great and the fact that these are specially made for 12mm axles is cool too. I hope they are at least 4mm stainless steel.
miuan wrote:I tried front/rear motor and rear battery. Even with worse balance, rear is still a winner. Just be careful not to wash the front wheel out in corners. Lean forward if you corner hard.
Haste wrote:Im lacing 210mm spokes to a 26" wheel using bafang bpm2. Can anyone post pics of their complete wheel...having hard time lacing it.
Haste wrote:... its kinda hard to lace a wheel without a truing stand. ....
miuan wrote:motomech: I'm afraid you've got it all the other way round. Reality is, the lower the code number, the higher the speed. Actually, I'm pretty confident to say the code means number of copper turns, so assuming similar motor size to the MACs, the code 10 will be as fast as the 10 turn MAC etc. In my applications this has proven correct as I own and ride both of these motors.
More on the topic can be seen here:
viewtopic.php?f=3&t=12582
The numbers don't exactly copy what BMSBattery indicates, but it's in the ballpark.
When purchasing from BMSBattery:
393 @ 36V = code 8
393 @ 48V = code 10 (mine does 40mph in 700c rim for short periods at 74V)
201 @ 36V = code 13 (a friend of mine runs it at 74V and 26in, does about 30mph)
201 @ 48V = code 17? (I've ordered this one for my dad, will be able to confirm soon)
I know BMSBattery could do a better explanation of different wind speeds, but most should get it easily. Hell, one year ago, they had no speeds indicated online, and I had to spend almost an hour to see which code designation is in stock. So it's a huge step forward (for the chinese fwiw).
Toby82 wrote:Hi Guys,
I just recieved my BPM motor from BMS Battery. I ordered the 36v 393 front motor. My motor code is 16(9). Having read this post prior to order I was expecting a code 8 motor. I emailed Bafang directly about the unloaded RPM of a code 16(9) motor and they responded with the following:
The unloaded RPM rating of motor code 16(9) at 36v is 330.
Any questions, please feel free to let me know.
I then emailed BMS battery to find out what their take on code 16(9) was and got the following response:
Hi sir,
The 393 is no-load RPM,and the 330 is normal RPM, thanks for your patronage.
I have now left the motor at my local bike mech to get laced into rim but when motor is returned I will test the unloaded RPM using a digital speed sensor I use at work for RPM calibration on test equipment. I'll then be able to confirm correct RPM rating.
Users browsing this forum: Bing [Bot], docnjoj, pradeepswain and 11 guests
