Warren builds a chopper
Re: Warren builds a chopper - strike that, it's a bobber
Postby teklektik » Mon Mar 19, 2012 9:37 am
Harley with sidewinder Chevy V8.
teklektik
Postby www.recumbents.com » Mon Apr 02, 2012 12:51 pm
The Bobber is now painted and pretty much completed. It makes a fun commuter bike. Here's a picture of it on the patio by where I work.
-Warren.
www.recumbents.com
Postby RallySTX » Thu Apr 05, 2012 12:40 am
Looks like pics don't do it justice. You can certainly be proud of it, I would be. Is that a generator front hub, or a drum brake? Very happy to see it works well for you.
Brian L.
Brian Larson CST. KC9DAK.
Janesville WI.
2005 Schwinn Stingray Spoiler
2004 Schwinn Stingray OCC. The Stripper.
Build thread
viewtopic.php?f=2&t=22134&p=322312
Web. http://www.wix.com/brian_larson/rallystx128hhj
RallySTX
Postby www.recumbents.com » Thu Apr 05, 2012 5:57 pm
Hi Brian,
That's a drum brake front hub. Here it is from a side view:
My wife says I look "funny" on it. I think it's because my arms are stretched out and I'm all hunched over, but that is typical chopper position.
I tried to make a wiggle 3D GIF, but I think I took the two pictures from too far apart and it looked spastic. I'll try again later. Sick now. Bleh.
-Warren.
www.recumbents.com
Postby RallySTX » Thu Apr 05, 2012 9:03 pm
Get well soon Warren.
Brian L.
Janesville WI.
Build thread
RallySTX
Postby www.recumbents.com » Sun Jun 10, 2012 8:35 pm
The dual bike stands were a good idea, but I never could figure out a way to make them stay in the up or down position without too much of a PITA factor. I ended up using Velcro straps to keep them from rotating down when I went over the railroad tracks. That would probably make me crash.
I decided I needed a heavy duty kickstand for this heavy duty bike. Instead of dinking around for 5 minutes to raise or lower the stand, I'll be able to just kick it up or down.This bike weighs 75 lbs, so a standard bike kickstand is not strong enough.
Here is the kickstand after brazing the mounting tube onto the left side of the rear subframe. I made the kickstand from 1/2" steel rod.
In this picture you can also see the tail light (red LED flashlight bolted to the bike).
It's a bit hard to tell what's going on here with all the flat black paint, but it's cool, just trust me...
-Warren.
www.recumbents.com
Postby www.recumbents.com » Sun Oct 07, 2012 7:40 am
I have used this bike for commuting this year, whenever I forget to charge my main commuter e-bike It handles well and has a cushy ride. I have heard concerns that the head tube is too steep. It did turn out steeper than I had intended.
Here's what the bike would look like if I change the head tube to 60 degrees, the same as on all Harleys. Also I 'shopped in a tractor seat because I hate the saddle.
Winter is coming, and I have a hacksaw. Hacking off the head tube this weekend. :twisted:
I'd like to change this bike over from the Ping pack to LiPos, but the Ping pack refuses to die.
-Warrenn
Last edited by www.recumbents.com on Tue Oct 09, 2012 1:04 pm, edited 1 time in total.
www.recumbents.com
Postby RallySTX » Sun Oct 07, 2012 9:17 am
Glad to see you're still arround, and pluging away at it Warren. Nice job on the kickstand.
Brian L.
Janesville WI.
Build thread
RallySTX
Postby www.recumbents.com » Tue Oct 09, 2012 1:02 pm
After several hours of hacking, grinding, and brazing, it's beginning to look like a bike again. I'm still contemplating the tractor seat. It's BIG.
You may need to right click on the image and open it in a new window to see the whole thing.
-Warren.
www.recumbents.com
Postby AussieJester » Wed Oct 10, 2012 10:28 pm
Head angle looks much better imo Warren should be more stable at speed but reduce the
low speed stability... :wink:
KiM
AussieJester
Postby www.recumbents.com » Sun Oct 28, 2012 8:36 pm
I finished the brazing, cleaned it up, painted it and re-installed the fork and handlebars. It does look much better.
The obligatory test ride went well, I think that low speed handling is better now. We'll see about the high speed handling once the electric parts are re-installed.
-Warren.
www.recumbents.com
Postby www.recumbents.com » Sun Nov 04, 2012 10:48 am
Re-soldered and taped the connectors for the throttle, Cycle Analyst, and headlight to the "snake" cable that goes to the battery box. The extension cable is made from an analog computer. These cable have about 14 individual low powered wires in them. video cable I found some "cold seal" tape at the car parts store to wrap up and de-uglify the wires and cables that go from the front of the bike to the back. This rubbery tape is cool stuff because it sticks to itself, but not anything else, so you can tightly wrap up the wires without worry of them getting all sticky with tape goo.
Also reconnected the rear brake and derailleur cables and re-attached the battery box. I'm happy I made it so easy to install and remove.
Time for an e-powered test ride!
-Warren.
Last edited by www.recumbents.com on Sun Nov 04, 2012 10:51 am, edited 1 time in total. View post history.
www.recumbents.com
Postby www.recumbents.com » Mon Nov 05, 2012 10:17 am
It's all back together now. I'll try to get a new picture during the test ride. Probably it will be a picture in the dark, since it's dark when I get home from work anyway. That will show off the lights anyway...
www.recumbents.com
Postby www.recumbents.com » Mon Nov 12, 2012 1:11 pm
Took a better picture of the bike outside.
This bike is now almost done. I still don't like the seat and am thinking about building a motorcycle style seat.
-Warren.
www.recumbents.com
Postby Chalo » Mon Nov 12, 2012 2:19 pm
If I used a bicycle seat on something like that, I'd want one with more "swayback" to help position me and hold me in place. The cruiser seat I go for is the Electra "cruiser with elastomers" seat, even though I don't have a wholesale hookup for it and I have to pay full price:
This one is the kind that has metal springs instead of rubber bumpers, but you can get a better idea of its shape from this photo:
You can buy one directly from the Electra online store if you don't have a local Electra dealer. There is a similar design called "Ergo" in an XL size that might be even better for your application.
Chalo
Last edited by Chalo on Tue Nov 13, 2012 1:07 am, edited 1 time in total. View post history.
Chalo
Postby www.recumbents.com » Mon Nov 12, 2012 3:07 pm
www.recumbents.com
Postby www.recumbents.com » Wed Nov 21, 2012 12:02 pm
The Dirty Bucket seat arrived yesterday and I had to take it for a test ride. It is much more comfy than the Planet Bike "comfort" seat I was using before, and has a bit more attitude.
I have a small seat back cushion with more spiffy chrome studs on order from Taiwan. $10 with free shipping. Amazing.
-Warren.
Last edited by www.recumbents.com on Wed Nov 21, 2012 12:05 pm, edited 1 time in total. View post history.
www.recumbents.com
Postby RallySTX » Wed Nov 21, 2012 3:30 pm
Lookingt forward to seeing that rear support. That's a lot of bike there, kudo's for a distinctive home built ride. I hope it serves you well.
Brian L.
Janesville WI.
Build thread
RallySTX
Postby www.recumbents.com » Sun Dec 09, 2012 3:16 pm
To attach the seat back I need to build another bracket. I have built Soooo many brackets over the years. I took a look in the box of short tubes & small brackets and found all these brackets. One of these surely has to be the correct size, right?
Well yes and no. One was the right size but used metric hardware and I have been using 1/4x20 cap heat screws on my clamps for this bike.
Here's the seat back mounted on the bike, I'll take another picture when I have weather / daylight cooperation.
It officially has recumbent seat now, albeit a minimalistic one.
-Warren.
www.recumbents.com
Postby chisixer6 » Thu Dec 13, 2012 5:45 pm
Warren;
Looks great.....Are you going to be at Terry's party next Saturday 12/22/12? If possible, would be great to see it in person.
Our annual Christmas/biker/friends/relatives party will be held at the Terry Lee's place on December 22nd approximately 6:30pm Hope to see all you party revelers again for some great food and cheer.
If you can RSVP so we can have a head count for plates and glasses (we always have enough food) that would be great.
I just cut off my head tube on my sort of Tour Easy clone too, it had a very shallow angle and got wheel flop when standing still, its a little steeper now. Also went from 1" headtube to 1 1/8" and is now disc compat. It is still being reconstructed.
Jerry
Last edited by chisixer6 on Fri Dec 14, 2012 5:44 am, edited 1 time in total. View post history.
Motobecane ..bafang front driver.. 42v
24" girls bike ..ebikekit 20" fwd..75v
24" Schweinn 9c 20"rwd 75v
26" Schweinn Yescomusa 48v 800watt dd
Easy Racer clone LWB.....24" rear e-bikekit 48v ..ready for testing
Hooligan clone , longer rear chain stay.. twin 20"...
fun bike...twin 16" wheels. small rear motor... ready for testing
convert my CLWB recumbent to a front bafung@48v..ongoing
chisixer6
Postby www.recumbents.com » Sat Dec 15, 2012 4:29 pm
Hi Jerry,
Unfortunately I have a conflict this year. I will miss seeing you all.
I'll be interested to see the TE - E bike!
-Warren.
Last edited by www.recumbents.com on Sat Dec 15, 2012 4:30 pm, edited 1 time in total. View post history.
www.recumbents.com
Postby chisixer6 » Tue Dec 18, 2012 1:34 am
Warren;
Oh, well, next time then.
tour Easy clone still under construction....currently using my e-bmx.....
chisixer6
Previous
Users browsing this forum: Bing [Bot], Ian, pradeepswain and 11 guests
