mineralvann wrote:Hello
I have a mountainbike that i would like to convert to electric. Ive been looking on the kits on ebay but after reading the faq i see that it is a gamble.
I live in norway where im restricted to a 250w motor as i understand.
ive looked at the faq and figured a befang at 36v is what i need as i would like to be able to use it as a ordinary bike and from the faq i found out i need freewheel for that and i primarily want it to help me with hills.
So far these are the components i found
Motor http://www.bmsbattery.com/hub-motor/42- ... ebike.html
Controller http://www.ebay.com/itm/Standard-Contro ... 803wt_1139
Throttle\brakes http://www.ebay.com/itm/Throttle-Grips- ... 256e1ab7c8
Pedelec sensor http://www.ebay.com/itm/Pedelec-Sensor- ... 35b67e9e26
battery 3s 11.1v 5000mah 25c battery from ebay(x3 or x6 not sure yet)
I want it stealth so im probably gonna put the controller and battery in the same bag\box on a frame connected to the seatbar.
The thing i hoped you could help me with is
1. Motor, where can i buy it with 201 rpm, 26" rim and as many gears as possible?
2. My bike has hydralic disc braked but all the brake handles ive found so far looks to be mechanical, but then i read that these handles are used for regenerativ braking and not for cutting power to the motor as i thought. Is this true? If so i can just use the ones already on my bike yes?
3. Should i look for a diffent controller? It doesnt look like the one ive linked to supports lipo so if you know a cheap a good one that does please tell
4. Anything i missed? Should/need to know?
I weigh about 85kg or 190 pounds, and my bike is 12kg or 26 punds.
motomech wrote:I would recommend the Cute Q100 36V/350watt "201" wind kit. It has a no-load rpm @ 36V of 230 or about 18 or 19 mph @36V. 48V would result in 21 or 22 mph.
motomech wrote:Not sure who makes the basic 350 watt kit controller[perhaps Shenzen], but it maxes out around 17A, has 63V caps and is non-programmable.
They are very tiny, around 100 m/m in length.
d8veh wrote:I used to use and recommend BMSBattery a lot, but if they make a mistake on your order, you won't get any help from them at all.
mineralvann wrote:Im looking for the most bang for my bucks. Dont really have budget, but the cheaper the better thats why im looking at ebay lipos as I image even the chinese c-rating would be more then sufficiant, but the waterbottle battery looks very nice. Also i know the controllers is not chemistry specific but i also know that lipos dont like to go below 3.2v per cell so it would be nice to have a controller with lvc.
So the stuff i read about the front fork not beeing able to handle the forces of beeing the drive wheel is not true? Thats why i havent even thought about frownt wheel drive.
And thanks for the link to the other forum, will try to read up more, this isent looking like its going to be as easy as i had hoped.
And if 42v dont kill the motor/controller i will go for 2x 5s battery as it would simplify the charging as you say.
I plan to use the motor just for assistance up hillsi would like it too be as lightweight as possible and from what i read the befang motor i linked to earlier is lighter then the q100, and more stealth in my opionion. But i cant seem to find any kits that use it.
About the brakes, this thread http://www.pedelecs.co.uk/forum/electri ... tions.html seems to suggest i dont need to do anything to the brakes as long as i have a pedelec sensor. Anyone want to chime in?
If i understand you guys right i will need to change the gears where the pedals are too? I just assumet i would loose a gear or two on the back because the motor needed the space but that i would get away without haveing to change the front ones. I already have 9 speeds on my rear wheel, if i go for the 9 speed freewheel and the q100 it still wont be plug and play?
Finally if i cant find a kit with the befang motor and and i decide the q100 is not for me, can i get the controller,throttle and pedec sensor at the same place\manufactorer and still use any brushless motor i want? Only experience i have with brushless comes from rc and there you can do that as long as you watch the amps but they have not been sensored.
Thanks for all the answers so far they have been very useful.
And motomech very nice bike, that looks exactly like what i would like to achieve but i really want the motor in the back as i fear my front fork\suspension will break and i will faceplant like a hero.
.... but the cheaper the better thats why im looking at ebay lipos as I image even the chinese c-rating would be more then sufficiant...
...the waterbottle battery looks very nice.
....but i also know that lipos dont like to go below 3.2v per cell so it would be nice to have a controller with lvc.
I plan to use the motor just for assistance up hills...
....i would like it too be as lightweight as possible and from what i read the befang motor i linked to earlier is lighter then the q100...
...and more stealth in my opionion.
...But i cant seem to find any kits that use it[Bafang].
... i understand you guys right i will need to change the gears where the pedals are too?
...but i really want the motor in the back as i fear my front fork\suspension will break and i will faceplant like a hero.
Users browsing this forum: dogman, Google [Bot], HAL9000v2.0, jbalat, kentlim26 and 10 guests
