biohazardman wrote:
Lithium grease/most any automotive grease works fine as does anti-seize. You don't need much. Get some oil in your freewheel and put more in now and then if you want it to last. Thicker stuff i.e. SAE30 or 20-50 ect lasts longer and if you get enough in it can quiet things down a bit. See that your axle nuts fit flat on the dropouts when things are tightened. Mine did not so got better quality stainless nut and lock washer. Nylock/aircraft nuts werq also pay lots of attention to this area for awhile loose nuts trash your bike. It's the little details that make things run smooth and last for awhile.
shock wrote:On another battery related note, I picked up a Hyperion 1420i charger yesterday, so I can charge 14 cells at once saftely. Tried it out using a fully charged marine battery and it works great! I need to find a good 24v 20 amp power supply now so I can charge my bank fast. Now to parallel the balance taps.
Users browsing this forum: Bing [Bot], Google [Bot], mabman, parajared, Trailblazer and 10 guests
