dozentrio wrote:My only question is, but WHERE does the heat go?
dozentrio wrote:My only question is, but WHERE does the heat go? (http://www.youtube.com/watch?v=wcFZIj96LwY#t=00m47s)
Seriously.
So does anyone know a car that has had reasonable production volume that has very small planetaries in the transmission that could be repurposed?
bigmoose wrote:I was able to talk with my gear expert friend yesterday and his off the cuff high efficiency reduction was planetaries. Now most have to be custom made which is cost prohibitive for us. So does anyone know a car that has had reasonable production volume that has very small planetaries in the transmission that could be repurposed?
fechter wrote:Ideally, you want the runniest oil you can get to minimize viscous drag. Maybe automotive brake fluid might be better than ATF? It dissolves paint, so may not be compatible.
teklektik wrote:Here's a little déjà vu from last month....Keyne's DH Comp Build - now with liquid cooled HX35!.
/doi/abs/10.1201/9781420003840.ch2]Handbook of Lubrication and Tribology[/url]. On the face of it, ATF looks like it may have been a good choice for this prototype.
andynogo wrote:I drilled a small hole (1mm ish) near the axle. I drilled from outside to inside, with the drill angled so that the hole goes from the axis towards the circumference. My logic was that when spinning, any oil that comes near the vent hole will be flung back inside the hub...seems to be working so far.
teklektik wrote:andynogo wrote:I drilled a small hole (1mm ish) near the axle. I drilled from outside to inside, with the drill angled so that the hole goes from the axis towards the circumference. My logic was that when spinning, any oil that comes near the vent hole will be flung back inside the hub...seems to be working so far.
If there's a bit of room on the inside of the cover, an oil slinger could be affixed to the cover surrounding the bearing with the vent hole under the slinger. This is basically a thin sheet metal disc that does what it sounds like to keep oil away from a bearing and seal.
andynogo wrote:...but I try to follow the KISS principle wherever possible!
andynogo wrote:The axle bearings should be sealed already but if they aren't you can replace the bearings with sealed ones, or even just use oil seals. You'd have to machine a recess in the covers so I guess it's a bit more complicated....unless you have a lathe in which case it's real easy....
andynogo wrote:As for the steel gear- yes that might work but I think the new grey gears for the MAC are plenty strong. The next weak link will be the clutch
..It was also very interesting to note that cruising at say ¾ throttle resulted in the temps going up- but as soon as I went to WOT at the same speed, the temperature started coming down again and quite rapidly.
Users browsing this forum: Beagle123, Hillhater and 8 guests
