wow, i just read thru this who thread. amazing how similar the issues that pop up to mine, but i'm really wishing i had your power levels..
binlagin wrote:So I replaced the HALL sensors and the motor spins unloaded no problem.
I took the bike for a ride but the motor begins to stutter under any amounts of load.
i'm not so sure about flipping halls.. from what i know, they've got a real particular order to the legs and the polarity matters. but maybe the cromotor is different. for my hs3540, the right leg is the signal, and the left two are positive and neg. if you have 5 halls going in, you'll see the positive and negative get split into threes to go to each hall, cause you've got 5 hall wires in and 9 legs... but again, cromotor may be different... i thought i saw a pcb inside once...
as for no load vs load, i've had this happen several times. i fix a hall, test the motor fine on the bench, only to hear it groan under weight, but i think the weight is irrelevant. the big difference i think is that there may be shorts in the hall wires, especially if your motor got as hot as you said it did - or was that just the controller? anyway, i'm still unclear about this but suspect a wiring/short that shows up only when the motor is installed, and not on the bench...
i need to get hall wires. gensem gave me the link once but i can't remember it now. it's in my thread. thin teflon coated stuff. good luck.
