Mudduck wrote:Yes but is my battery good enough?
Another and also cheaper option is to use a 6 fet Infineon and apply the same 120% speed setting to the MXUS for higher top speed, but the MXUS is not a power monster, so you would need to keep a check on the motor and go a bit gentle to avoid overheating or damaged gears. I don't see why you wouldn't see a similar 15-20% increase in max speed on the MXUS, the result should be close to what you might get running the motor on 48V.
neptronix wrote:If you added another motor, you'd have 12-14lbs worth of motor.
The total cost of both motors would be over a MAC motor.
The MAC motor only weighs 10lbs. and is more powerful than 2 MXUS motors combined
I've ran mine at 35-39mph constant for long periods of time.
It's likely that there will be no speed gain. More torque, yes. More speed? probably not.
So, bad idea
Users browsing this forum: jbelant, neptronix, pendragon8000, Rassy, rick-c and 12 guests
