grindz145 wrote:That's some serious current for sensored operation. Be careful if you lose sync! Get off the throttle quick, or else bye bye mosfet
grindz145 wrote:Greg, that current is fine with Halls, but once you "loose sync" on a sensorless controller, I would worry, very different scenario.
O wait is EB212 sensorless? I'm confused...
I missed it, who is sailorboy?
Skippic wrote:I'm charging my battery to 4.3V
GCinDC wrote:...unscrewing each spoke (on the right side, that's laced on the rotor inside), bend the spoke enough to yank it out, and re-insert from outside of rotor, and tighten back up in nipple...?![]()
sn0wchyld wrote:it does have a pretty notable warming effect... ive got my regen on a separate switch for that reason... so if i'm racing round i can just heat up the brakes, but if im on a long downhill or riding for range then the regens available when needed.
I use a micro switch, ziptied to the break leaver. that way, I can pull on the regen, and then pull a bit harder to add in the disk brake, or just pull the disk brake on its own. works like a charm.
gensem wrote:have you tested strong vs weak regen?
Whats the efficiency on regen, 75%?
Skippic wrote:Forget regen, just get good brakes.
Duc998 wrote:you running any lights GC? I'm interested in the one from ebay 24-90v 12w and hoping I can tap into the aux of my CA-DP.
GCinDC wrote:the obvious challenge with this wheel build is securing 12g (2.6mm) spokes with (5.5mm) butt ends in giant 8mm wheel holes:
dbaker accomplished it here with two washers, both of which bent to the shape of the hole:
i have no idea where he got the oval ones.
knoxie wrote:broken side cover disc mount
Lenk42602 wrote:JRH had some custom spoke nipples manufactured from Sapim that threaded into 12&13 guage spokes,
GCinDC wrote:first off, i was able to salvage the disk adapter - no idea where dbaker got it... i'm thinking i will thread on and jb weld to side cover.
GCinDC wrote:i'm definitely not crazy about using washers. i never even rode in the rain, and can see some rust starting. what's ironic is that i got the wheel hoping it would be indestructible, but because of dish issue ended up constantly adjusting it and doing more maintenance than a 26 rim!
i wish it weren't so expensive to ship these motors/wheels around because i'd much rather have them built by a pro. might be worth it next time.
Users browsing this forum: Dlogic, panurge, runonpre, zombiess and 7 guests
