gensem wrote:260c what nice friend you have... Hum?
You are probably right about silicone wires under extreme conditions... Btw do you know where to buy colored ones?
cassschr1 wrote:I think Doc knows him and he's being sarcastic for fun.
oatnet wrote:Has anyone gotten a 54xx with the axle for 150mm dropouts? I'm curious to see how that sorted out.
-JD
Edit: Hey, this is my 2000th post! After 5 years here!
Heck, I've seen some people rack up 2000 posts in a few months, then freely and widely offer advice, even though they haven't gotten their first ebike rolling yet.Just goes to show post count is not a good measure of experience and content contributed.
-JD
-JD
-JD
sabb wrote:Oatnet
The shaft is the same and we all got spacers to fit to a 150mm dropout
Stephen
John in CR wrote:Hey Doc, are you thinking about mashing the end copper down flat like Xlyte did on the old X5's? You could probably pick up another 5mm on each side.
Also, how easy is it to machine the axle, since whatever you cut off of the rotor ring the bearing will need to move toward the center by the same amount? Other than a bit of work on a soft 9C axle I've never worked on a hubbie axle, and I've really wanted to on a number of occasions.
ZOMGVTEK wrote:10kW into aluminum dropouts? Nice.
The motor sounds really quiet. Do you have any closer pics of how the wires are routed? I'm not that happy with how the wires exit the hub on mine, the plastic ring is prone to spinning and cutting the wires. I suppose if you had thin dropouts, it would be an issue, but my dropouts are supposed to be 5/8" of steel, so I might be OK.
Andje wrote:well that is interesting; on a 26 inch rim and 100v80amps I also get about 58mph exactly out of my 5304.
Deutch420 wrote:Andje wrote:well that is interesting; on a 26 inch rim and 100v80amps I also get about 58mph exactly out of my 5304.
I'm 52mph on flat ground with no wind on my 5304 @ 100v 80amps. About 700 miles on that setup. I have no idea how your seeing 58mph out of a 5304 100v flat ground. Are you sure you didn't mean 5303? Or maybe I have a bumm 5304? My numbers seem to match others..? Looks like I'm going to be forced to downgrade back to my 5304..
Users browsing this forum: kenkad and 1 guest
