The Unofficial 'CroMotor' Owners Tech-Tips Thread
Re: The Unofficial 'CroMotor' Owners Tech-Tips Thread
Postby shorza » Thu Apr 05, 2012 6:49 pm
Can anyone please tell me the length to the axle on these?
It must have an axle length 205-210mm for me to be able to get the nuts on outside my 140mm dropouts and torque arms.
shorza
Postby Alan B » Fri Apr 06, 2012 12:44 am
The Cromotor freewheel threads are too long for the White Brothers freewheel. What is the best remedy?
Alan B
1.21 GW
1.21 GW
Postby cassschr1 » Sat Apr 07, 2012 11:48 am
I don't see why thats a problem. Is the motor to wide now?
cassschr1
Postby Alan B » Sat Apr 07, 2012 9:25 pm
If I use a spacer on the freewheel it will require extra dropout width. I need to get some numbers.
Alan B
1.21 GW
1.21 GW
Postby alex77roma » Mon May 21, 2012 7:26 am
I have the avid rotor and already made the same modify, but I don't find the Magura Gustav.
Are there any alternative silm rear disc brake to Magura Gustav for fitting the cromotor in a 135 hub with?
andreym wrote:If you have only 135mm of dropouts and still want to fit some torque arms inside, you can use the following disk rotor adapter mod:
-remove original adapter,
-get avid g2c2 203mm rotor
-get magura gustav M rear brake for enough clearance
-dremel a bit of avid rotor to make it fit and screw it up INSTEAD of original adapter
here is your additional ~5mm clearance for torque arms with CroMotor and 135mm of dropouts!
and some pics:
alex77roma
Postby GCinDC » Mon May 21, 2012 7:40 pm
alex77roma wrote:I have the avid rotor and already made the same modify, but I don't find the Magura Gustav.
from here.
gregborgusa.com wrote:...Like many rear hub motors you can run into caliper clearance issues, but I managed to get a Hayes Stroker Ryde on the back of my custom bicycle by using a 203mm rear disc. This larger disc allows the caliper to stick up high enough to not rub on anything but it’s a tight fit due to this particular caliper being very wide compared to others such as the Avid Juicy brakes I’ve run.
i wonder if the magura mt2, mt4, etc would be good. i believe kepler said they've got 17mm of clearance from disc to edge.
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1.21 GW
1.21 GW
Postby Olly3012 » Tue May 22, 2012 4:00 am
I have just purchased a croMotor and was wondering what the ultimate controller available for this I have 30S2P lipos 111V-126V with 30C cells, I don't care about mileage at all just want maximum power any suggestions cheers.
Olly3012
Postby Emoto » Wed Jul 18, 2012 8:18 am
and some pics:
Andreym Good to see this mod, are you using regen, how long have you been using it like this.any problems yet
Just a quick flight http://vimeo.com/30385026
#1 The long road viewtopic.php?f=6&t=50752
Emoto
Postby Alan B » Wed Jul 18, 2012 8:22 am
Nice technique! May have to do that myself.
Alan B
1.21 GW
1.21 GW
Postby binlagin » Wed Jul 18, 2012 8:25 am
Unfortunatly I snapped my Cromotor axle yesterday after a heavy acceleration from a dead stop. I had made some room for larger phase wires... but apparently I shaved to much down :(.
Now I have to figure out if it's even possible to replace. I have no idea where I can source a replacement axle and/or how to install it.
Greyborg Motor, 18-FET Lyen Controller
Turnigy 20C @ 30S x 2P
Giant Team DH Bike, Kiwi Dropout adapters
100km/h+
binlagin
Postby fractal » Wed Jul 18, 2012 8:56 am
binlagin wrote:Unfortunatly I snapped my Cromotor axle yesterday after a heavy acceleration from a dead stop. I had made some room for larger phase wires... but apparently I shaved to much down :(.
That sucks! Could you weld it back together? Finding a replacement that fits could be a challenge!
Norco A-line DH bike with :
«cromotor/hubzilla» from http://www.greyborg.com/
24s 3p Lipo (100v, 15ah)
Methods LVC/HVC cell level protection system http://www.methtek.com
24 fet infineon controller made by Lyen, heavily moded by Methods
8awg harness by Icecube57
17 inch moped rims with Michelin Gazelle tires by John Rob Holmes http://www.holmeshobbies.com
other stuff http://www.ebikes.ca
details
http://endless-sphere.com/forums/viewtopic.php?f=6&t=31850
fractal
Postby Doctorbass » Wed Jul 18, 2012 8:56 am
did you used single or DUAL strong torque plate? ( one on each side)
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby gensem » Wed Jul 18, 2012 9:03 am
Go to a machine shop and ask for a new one... btw why did you have to use larger phase wires?
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
gensem
Postby binlagin » Wed Jul 18, 2012 9:08 am
I'm using the Kiwi's drop outs for the Giant DH Team. They seem to be pretty heavy duty and have held up so far.
I haven't actually taken the motor out of the rear swing arm yet to get pictures and confirm 100% that thinning the axle is what truely caused the failure.
I've messaged Zombiess to see if he's able to get his hands on a spare axle. *crosses fingers*
Oh and Gensem why did I do this? I'm a noob and I thought those wires where to thin....
100km/h+
binlagin
Postby gensem » Wed Jul 18, 2012 9:17 am
binlagin wrote:Oh and Gensem why did I do this? I'm a noob and I thought those wires where to thin....
They arent super thick either like 10awg tops.
But the deal is that they will not have to deal with constant current so it should be good for a lot of amps.
I ll find out it soon as im planning to run 160a main 240a battery on a cromotor.
gensem
Postby Emoto » Wed Jul 18, 2012 9:54 am
Alan B wrote:Nice technique! May have to do that myself.
ive got my motor and frame only atm, 135 dropout, and im thinking, i saw your thread and you have less to work with, but i have a couple of ideas that will work.
finding a disc that has enough materal to re drill the pattern is one thought
Emoto
Postby hillzofvalp » Wed Jul 18, 2012 5:04 pm
I haven't set up a rear brake yet over 800 miles.. Regen is soo strong and I have a lot of trouble mounting the caliper.
Sorry to hear about the snapped axle! Makes me worry! Tell us about your regen use, wheel size, phase/battery current, etc as well once you catch your breath. So far the dp420 and .5" thick dropouts have held up... But I'm quickly being deterred from bike frames for this type of power.
hillzofvalp
Postby binlagin » Wed Jul 18, 2012 5:31 pm
I've made a post with more detailed information about my failed axle here:
viewtopic.php?f=6&t=36090&p=611756#p611756
100km/h+
binlagin
Postby Emoto » Thu Jul 19, 2012 8:39 am
hillzofvalp wrote:I haven't set up a rear brake yet over 800 miles.. Regen is soo strong and I have a lot of trouble mounting the caliper.
Yeah regen being strong i can imagine is handy in you situation , but i would like to fit a rear brake,removing the adapter is a good aproach. ive got a dh frame and the swingarm is quite strong [i may modify it/ wider] would'nt be confident in a normal frame.
Emoto
Postby Emoto » Thu Jul 19, 2012 10:00 am
binlagin wrote:I've made a post with more detailed information about my failed axle here:
Ive just received mine, on first inspection i thought this was the obvious weak point, and now im a bit worried, as you can see the phase groove machining is quite deep only leaving 12.1 mm :shock: is this normal.
cromotor shaft
Emoto
Postby hillzofvalp » Thu Jul 19, 2012 11:54 am
I found it a bit questionable as well. That's nearly worse than m14.. Which would be something like 12mm of solid metal. Your measurement minus 1 mm of thread... :roll:
hillzofvalp
Postby nicobie » Thu Jul 19, 2012 12:59 pm
I wonder why they don't put the groove on the same side as the axle flats?
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby Emoto » Thu Jul 19, 2012 2:44 pm
nicobie wrote:I wonder why they don't put the groove on the same side as the axle flats?
Nicobie, your absolutely! right.
My other problem is the groove machining should not pass the shoulder and therefore weakening the shaft
Emoto
Postby hillzofvalp » Thu Jul 19, 2012 3:54 pm
If they put on the axle flat side, the wiring harness wouldn't come out where the dropout channel is. for most frames this would present an issue.
hillzofvalp
Postby hillzofvalp » Thu Jul 19, 2012 3:55 pm
Emoto wrote:My other problem is the groove machining should not pass the shoulder and therefore weakening the shaft
I agree, but it still conflicts with the design constraint of getting the wires in line with the axle slot. Don't they do it this way on other brands, too?
hillzofvalp
PreviousNext
Return to E-Bike Technical
Users browsing this forum: Samd, shenzhen_ex, skeetab5780 and 7 guests
