I just finished making up a break out board on a piece of vero board..damn
bigmoose wrote:Doc, I like your new layout. Looks good!
I am heading towards an AMP CPC Plastic connector with near Mil spec Pins. The cheap pins are good for 13 amps at about $0.75 a pin pair; and if things get dicey there are 17 amp rated pins at about $2.40 a pin pair in Series 1 size 17-16 pins will do 12 cells; but for 48 volts I have to go with Series 1, Size 23-37 pins. That size 23-37 connector is like 1.75 inches in diameter though!
Doctorbass wrote:
Do you know why i like the DB connector?
D... B........ Doctor Bass ConnectorDoc
jonescg wrote:Now for my race bike I will be using four of these D-sub 44 HD plugs:
Unfortunately there is only just enough pins for my 43 balance wires. I believe 28 gauge wire will suffice for monitoring or balance charging at an amp or so.
Doctorbass wrote:I already used the DB44 connector for a 40s BMS but.. the pins are too fragile and too close!
caspo6 wrote:..... Is it okay to balance the two 12s groups using the common lead between them to the two chargers?
Cannon's part-numbering system uses D as the prefix for the whole series, followed by one of A, B, C, D, or E denoting the shell size, followed by the number of pins or sockets, followed by either P (plug) or S (socket) denoting the gender of the part. Each shell size usually (see below for exceptions) corresponds to a certain number of pins or sockets: A with 15, B with 25, C with 37, D with 50, and E with 9
Users browsing this forum: dm9876, JennyB, peters and 8 guests
