lester12483 wrote:The batteries are rated at 2C.
Technical Specifications for 48V and 36V packs:
Maximum discharge current 20A continuousMaximum discharge spike 25A for < 2 seconds
Specific Energy: 154 Wh/kg
Average Lifecycle of the pack: >85% capacity after 1000 cycles.
Cell Type: 18650 2.4Ah
Maximum charge current: 10 A
Operating temperature range: “0 – 45°C
NO memory effect
2C Rating
Aren't "rated" values suppose to correlate with the # of cycles the battery is rated for (1000 in this case)? If so, I don't see how you can say it's rated at 2c, which is it's *max* continuous ability.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others...
viewtopic.php?f=6&t=34236&p=497325#p497325.
