Re: Your Creation's Before & After Pics
Postby iperov » Sun Feb 05, 2012 1:55 pm
Sorry, bad english!
iperov
Postby lester12483 » Fri Feb 10, 2012 9:07 am
Specifications:
750 watt MAX brushless hub motor
Top speed 30 mph
Battery range up to 20-30 miles MAX on a charge
48 Volt 13 Amp Hour (LiNMC) AllCell Lithium battery (1000+ charges life cycle)
2.5A battery charger included 110/240 volt outlet capable
Battery charging time is 4 hours, empty-full
Cycle computer included
26 x 2.125 inch standard white wall tires
Custom grips
Front head light included
Bike weight with battery: 65 lbs
Maximum rider weight - 250 lbs
MT6 Hybrid- Electric Bicycle 48V
48V 13AH AllCell Lithium Manganese Battery
http://www.chicagoelectricbicycles.com
lester12483
Postby rui_fujino » Fri Feb 10, 2012 11:44 pm
Diamondback S:10 FS
Original Bike
Ebike 2.0
Conhismotor 48v 1000w
LiFePo4 52v hot
FSA XC282 Handlebar
Suntour M2000 Fork (original)
750lb coil rear suspension (original)
Tektro v brake (original)
Truvativ iSoflow Chainset 52/42/30T
Shimano 11-28T freewheel
Ebike 2.0 (28mph)
Ebike 3.0
CA-DP ver2.3
HS3540 (MethTek)
Lyen 12fet Controller
FalconEV bag
20s2p(83vhot) Lipo
FSA XC282 Handlebar
RockShox Dirt3 Fork
Manitou Swinger 3-way air suspension
Avid bb7 Disc Brakes
Specialized Armadillo Crosslands tire 1.95x26(anti-puncture)
Custom rear brake light
Ebike 3.0 (44.5mph)
20s2p lipo
Project 1: Apollo slant hard tail MTB 52v lifepo4, conhismotor, 52T-11T gearing 39.6mph top speed (with pedal)
Project 2: Diamondback s:10 Full suspension 20s2p (83.5v 10ah Lipo), 35kg, HS3540 sensored (MethTek), 12FET lyen controller, Bulk 600w balance charger.
Top speed 45mph(72.4km/h)
Project 3: DOPPELGANGER d2 Visceral
Project 5 Specialized Epic20s2p (83.5v 10ah Lipo), 30kg,HS3540 sensored (MethTek), 12FET lyen @ 50A
rui_fujino
Postby Ossielocal » Mon Feb 13, 2012 3:40 am
Gday gm6046 ,
My first go at an ebike was the same bike just a different kit ..it was one of these kits http://www.cyclone-usa.com/ It was alright but got a little warm and blow fuses all the time bit of a pain in the arse . This Ezee kit is pretty good i must say on the flate i get up too 40km/h which is a good enough speed for me .My old kit only manage an average 30km/h if i went to a higher gear she would blow a fuse .
gm6046 wrote:
Ossielocal wrote:Hi guys , this is my second build and on this one i used a Ezee 400watt kit with a ping 48v 10ah Battery .
Mainly use this bike for work ..Still needs a on off switch .And i'm not sure about the range on the battery ..but it should be good for 14ks .
Looks good, what was your first build?
Ossielocal
Postby motornews » Thu Mar 15, 2012 4:02 pm
48v 1500w 12ah
49klm speed
40klm range
motornews
Postby thewmatusmoloki » Fri Mar 16, 2012 5:57 am
sweet ride motornews
There is no spoon.
thewmatusmoloki
Postby iperov » Sun Apr 01, 2012 6:52 am
my Cove-Minimal with +10V 50A boosters and rucksack battery xD
(226.29 KiB) Downloaded 4 times
Sorry, bad english!
iperov
Postby PetersReviews » Sun Apr 01, 2012 11:53 pm
Hi Ossielocal,
The bike looks great! Where did you get the ezee hub? I didn't know they were making a rear hub. If anyone else out there knows an honest shop where I can order one or another small direct drive hub please let me know. My last rear hub was a disappointment but I've heard great things about the ezee!
Peter
PetersReviews
Postby iperov » Wed Apr 04, 2012 11:26 am
Fixed-gear bike with "electro-compensator of absence of gears".
Hub weight - 1.9kg
lifepo4 Battery 250 W/h - 2kg
bike weight ~15kg
Sorry, bad english!
iperov
Postby lostrack » Fri Apr 06, 2012 12:25 pm
Bit of an update:
Before
After
Front
Side
side view800.jpg (182.92 KiB) Viewed 2351 times
Dash
lostrack
Postby Xanda2260 » Fri Apr 06, 2012 12:58 pm
Holy hell! That's some nice hardware!
The White Warrior - viewtopic.php?f=6&t=33918
Homebuilt 40mph+ tadpole!
Xanda2260
Postby scorpi00n » Sat Apr 07, 2012 12:33 am
Hey guys!
Just like to say Hi! as this is my first post :D
Ive recently purchased a kit from hyena and thought id put up a photo of what ive done with it..
The battery pack and charger is in the bag which I simply connect to the controller when im on the bike :)
I still need to get a saddle bag which I will attach to the seat so I can hid the controller.
scorpi00n
Postby veloman » Tue Apr 10, 2012 1:29 pm
Nice job, agniusm, neat.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby ohzee » Tue Apr 10, 2012 1:35 pm
Yea that scooter is choice.. professional looking work
ohzee
Postby bdc43 » Sat Apr 14, 2012 7:55 pm
HI guys,
Well, after much procrastination , I finally got around to posting my build. If you'll recall, I was starting out with an old 1985 CCM 6-speed mountain bike which had been sitting in a shed for about 15 years. So, without further ado, here she is:
Before:
After:
It's a rear 9C kit powered by a 48V Lithium-Polymer pack carried on the rear rack. I could have mounted a large pack within the frame triangle, but since I have to carry the bike up and down a 4 step stoop, I needed the pack to be removable so I would be able to lift the bike. After replacing the tires, adding a new chain, brake pads (I also checked the brake levers with a magnet and it turns out they ARE metal, coated in black plastic) and hubs (the bearings were shot), I replaced the old aluminum rack with a stronger steel one and added fenders. The performance is amazing! Very torquey, and I've had the bike up to 43 Km/h. I ordered the kit through Ypedal from Ebikes.ca. He also helped me with the installation and setup. He even built my battery pack for me.
Thanks Ypedal...couldn't have done it without you, man! :D
bdc43
Postby Ypedal » Sat Apr 14, 2012 8:02 pm
Good stuff !! you finally made it here !! 8) .. and thx again for the complimentary 6pack today.. it's cooling in the fridge waiting for it's glory day !
If anyone here has a spare set of cranks for a vintage square taper bottom bracket.. this bike needs a new set. the crank arms are bent making pedaling a real whopper of a time.. pedals are also not the best.. the entire cranks, pedals and BB need overhauling if you happen to have an old scrapper gathering rust .. open invite to take them off your hands !! :P
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby bdc43 » Thu Apr 19, 2012 6:50 pm
Well, I finally found a replacement crankset at the local bike shop....a little shorter than the originals ( I think something like 160 mm instead of 165). I just hope they'll fit. Should find out this weekend (they're calling for rain so it'll be a perfect time to do some work on the old bike). Can't wait to go for a test ride....I just hope the bottom bracket is still holding up. I had enough trouble finding a set of cranks, I can just imagine what a bottom bracket's gonna be like...Sheesh! :roll:
bdc43
Postby Dreddydave » Sat Apr 21, 2012 7:49 am
Started out as a GT Outpost Trail, circa 1995 (?).
Built as an ebike, with details in this post: http://endless-sphere.com/forums/viewtopic.php?f=6&t=34039
And now rebuilt with 12s6p:
The view when riding :-)
Dreddydave
Postby smudger1956 » Sat Apr 21, 2012 4:00 pm
Commencal Supreme
X-Lyte HS3540
X-Lyte 72v-45amp sensorless
8 - 5s1p 5000mah Lipo
Before
After
Commencal Supreme FS
X-Lyte HS3540
X-Lyte 72v-45 amp sensorless
8 - 5s1p PolyPower Lipo
ABS - 2 fingers and a brain...
smudger1956
Postby kevo » Sat Apr 28, 2012 9:32 pm
Smudger,
Nice build. Like how the rear brake rotor matches the hub size. Great choice of battery/hub/bike 8)
Thanks Justin of http://ebikes.ca for your amazing talents, dedication and contributions to ES!
Post licensed under "Open Source" http://creativecommons.org/licenses/by-nc-nd/3.0/
kevo
Postby iperov » Sun Apr 29, 2012 9:27 am
Sorry, bad english!
iperov
Postby Demeter » Sat May 19, 2012 1:16 pm
BeOne Cikara 29er 2007
Now with Crystalyte G rear hub and 48V14AH LiFePO4 battery.
Speed on flat without pedals ~37 kmh, with pedals up to 52, Range on asphalted roads ~60km. Weight 26kg.
Demeter
Postby motomech » Sun May 20, 2012 5:15 pm
First version, 2003 Rocky Mountain Edge X-country bike[but with jumper fork],MXUS geared mini-motor, 48 Volt 8aAh " rack battery", "Stand Alone" Cycle Analyst, Cycle Lumenator.Tiny stock controller was hidden under the seat. Pretty much "plug and play". Only the frt motor fitment took some time. Top speed, no wind, no pedal is 24 mph. Jives well with my stubby legs and the Edge's stock 11/44 gearing.
Changed over to "Lipo in the bag". The Lyen senorless "Mini-Monster" 23 Amp controller first went in the frame bag, but got a little hot for my liking, so I drapped it over into the bag's mesh side pocket. A piece of intertube covers the connectors and the shiney controller is wrapped in a piece of speaker grill cloth.
I thought I would try Lyen's custom left-side half-twist throttle. Two thumbs up![thumbs are happy, no more pushing or pulling :lol: ] Note "hair tie"parking brake. Looking for thick O-ring to go between half throttle and grip to serve as crude cruise control[All the old timey auto parts stores are gone for my area :cry: ]. Several attemps to install a stand have proved fruitless, just no way to attach anything.
Standard automotive 30 Amp toggle for power. EV Falcon bags have "button-hole"[slit]openings at both ends for convience. EV Falcon bags are awesome!
I don't go fast or far, just tool around in the 10 to 20 mph range, so I don't need much of a pack. Just a simple 12S1p 5000 mAh. At bicycle speeds I get at least 3 miles per Ah. Since the frame bag is not stuffed with Lipo, I carry my lock, poncho, tool kit, etc in the frt. half. If I need a more range, I have another 12S1P pack that I carry in the otherwise empty tail bag. I lost 1 mph top speed going from 48V Li-Mn to 44.4V Lipo.
Going from a 17A controller to a 23A model makes throttle control and frt. tire traction an ever present concern. The throttle can be abrupt[I may limit current with the CA] and the 900 or so Watts is about the limit of what I think is relalistic for a frt. mount on a MTB with a skinny road tire. On any surface other than dry pavement, it really wants to spin. :roll:
So..,to address those traction issues,... I've started work on version 2.0 + 2.0 :D
Motomech(reformed I.C.E. enthusiast)
2003 Rocky Mountain Edge w/2WD. , Dual Ananda Q100 "fast wind" W/stk. controllers modd'ed to 17A, 28 mph on 12S Lipo, Stand Alone CA, Cycle Lumenator
2007 GT Idrive 5 3.0, MXUS geared mini/Lyen Mini-Monster on the frt.
viewtopic.php?f=4&t=40567&p=592630#p592630
viewtopic.php?f=6&t=235&p=651777#p651777
motomech
Postby Kirk » Fri May 25, 2012 7:35 pm
ImageI have a Catrike Expedition (Candy Purple). Started out with Scwalbe Marathon Racers, SRAM Rival 10 speed groupo, TT500 thumb shifters, GXP bottom bracket, Truvative Elita 165 mm cranks 28/39/52T Truvative chainrings.
I added a GM 48V hubmotor, Stand Alone CA, 7 speed gear cluster (11/32T) SRAM 7.0 Grip Shifters and a 48V 48Ah 30C Lipo battery, Krispysteve neck rest, Axiom bags all a round.Next week it will get a tinted Windrap XT fairing and Catrike side bags, to hide the controller in, instead of the top bag, which will go away to improve the aero of the ride. Also a custom made 45 in. flag to give the cages a bit of warning.
Stable:
05 Catrike Road (Yellow), 20" 48V 1000W GM hub motor,12s24Ah Lipo batt.
12 Catrike Expedition (Candy Purple), 18s32Ah Lipo batt. Lyen 18 FET low RDS controller, C'Lyte HS3540 hub motor, CA-SA, Mueller Bros. Windwrap XT fairing, Terra Cycle Cargo Monster extension. Still evolving, should be interesting by next Spring.
2011 Roll Over America tour, 50 Velomobiles, 5000 Km, 24 days, Portland, OR-Washington DC, July 28th-August 24th 2011, damn I was tired after that.
Kirk
PreviousNext
Users browsing this forum: Cowardlyduck, Danos, johnboy77, Majestic-12 [Bot], MSN [Bot], Tpower and 6 guests
