FighterCat HV 16S 200A programmable ESC for RC Drive
Postby zombiess » Tue Apr 10, 2012 3:41 pm
*SOLD*
This is the controller only, you'll have to register on FighterCatRacing.com to get what ever else is needed to program it. The leads are shorter on this model than in the specs and are ready for connectors to be soldered on. As much as I really want to play around with this I just don't have the time or proper resources.
Includes 120C temp safety, 12" 8 gauge battery wires, Pre-installed 6mm Bullets, Pre-installed 3.5mm spark suppression lead.
The FighterJet 200HV is specifically designed for low air flow environments and tested at 220 amps (and more!) on 16s. (16s preferred)
Components are designed to handle 100volts, FET's 75v. Realistically, 72 volts or 17s operating voltage. (16s preferred max)
PLEASE NOTE WE DO NOT SUPPORT THE USE OF THIS ESC WITH THE LITTLE SCREAMERS MOTOR
There have been some successes and also some serious failures with this ESC and the LS motor. This does not mean it won't work, it just means we can't help you with this configuration if it does not.
We have been unable to reproduce the field errors with the ESC and motor combination, in fact the lab tests work so well, we can't get any problems to occur at any timing setting or load variation.
Please consider using Neu, Lehner, Tenshock, Scorpion, Suppo, HK4030 or Leopard motors if having issues with the LS. All of which have so far been tested well with this ESC as well.
Noted to play espeically well with Lehner motors.
Full voltage tested (72v) with 4 pole, 6 pole, 8 pole, 10 pole and 12 pole motors.
Max Constant Current: 220A
Max Current: 680A (burst)
BEC: OPTO
PWM: 8 KHz 16 KHz 32KHz
Input: 3 to 17s LiPo (16s preferred max)
Current Model Features: 8 Gauge Input Wires, Extra long 12 inches , 6mm female bullets pre-installed on the PCB) Comes with the bullet mates.
Physical size: 145mm x 50mm x 8mm (long and thin to dissipate heat evenly) = 6" x 2" x 1/2" approximately 320 grams or 11.3 ounces (5.5 Oz without heat sink - heat sink can be replaced)
Programming options:
Battery Type, Number of cells/auto, LVC Voltage & Cutoff type
Power Limit Forward & Reverse, 25, 50, 75 & 100%
Throttle Curve, Logarithmecal, linear, exponential
Acceleration, Soft, Medium & hard
Timing in 1 degree increments 1-30 degrees (Timing MUST be properly set or will cause failure)
Delay time, .25S to 5S
Timing Monitor, on/off (timing monitor will beep the timing setting when plugging in the ESC)
Drag Brake (%)
IMPORTANT: Timing must be set prior to test/use. It is crucial that a motor requiring 30 degree of timing not be run at zero. Failure to properly set timing prior to use will result in a permanently damaged ESC. Run a minimum of 5 degrees timing with 4 pole motors.
Note* Running a system at max capacity/voltge greatly increases the risk of failure and voids any warranty. It is recommended to plan within at least 25% of max capacities. Therefore it is recommended to plan to use this ESC on 16s / 200 amps or less. Please don't hesitate to run this ESC on 4s, 5s, 6s, 7s, 8s, 9s, 10s, 11s, 12s, 13s, 14s, 15s or 16s!
Greyborg Hub Motor, Lyen 18FET, Customized full suspension kids MTB. Top Speed 61 MPH
9C 8x8, 24S2P LiPo, Lyen 12 FET, Diamondback Recoil Comp. Top Speed 42 MPH
GreyborgUSA Dealer
zombiess
Re: FighterCat HV 16S 200A programmable ESC for RC Drive
Postby comradegerry » Sun Apr 15, 2012 1:31 pm
Hi Zombiess
Do you think it would work with an Astro 3210 :idea:
Gerard
comradegerry
Postby zombiess » Sun Apr 15, 2012 1:45 pm
sold
GreyborgUSA Dealer
zombiess
Postby comradegerry » Sun Apr 15, 2012 1:59 pm
Jeez, that was quick, I did not even get a chance. :shock:
comradegerry
Postby zombiess » Sun Apr 15, 2012 2:14 pm
it actually sold the other day, forgot to update it.
GreyborgUSA Dealer
zombiess
Postby SoSauty » Wed Apr 18, 2012 12:37 am
Fighter Cats should be compatable with the little Astros as they can be programmed to current limit at 25%, 50%, or 75% of rated, in this case 200A. Just in case you are overviewing controllers.
http://www.ebikes.ca/index.shtml No.#1 Trusted E-bike online sales!
3 hardtail MTBs:
-48V Lith-ion 10.5amp hr-408 C-lyte
-BPM 8FUN[*STOLEN]
-run Century rides w/Q100 mini
3 folders:
-20" wife's BaFang,
-20" TurnigyMax50cc airline suitcase folder,
-24" Stewart/Hass 9C; 3.5K/40mph fun racer
SoSauty
Postby Idontwanttopedal » Wed Apr 18, 2012 1:06 am
I got this to run a 80100
Idontwanttopedal
Users browsing this forum: soaresdacosta, xlzeo, zombiess and 3 guests
