24 Connection Connectors...
Looking for something? Need a special part, but can't find it online anywhere? Post what you need, maybe others will have it to sell. Guest may post replies to topics already here. All topics here will expire after 60 days of inactivity.
Postby SlyCayer » Mon Mar 12, 2012 6:48 pm
Hi,
I would need some 24 port/connection connectors for balance lead wires, any recommendations? my wires are 18AWG.
http://www.JCCayer.com Where you can find tools and Dewalt(A123) batteries.
SlyCayer
Re: 24 Connection Connectors...
Postby adrian_sm » Mon Mar 12, 2012 8:19 pm
A few people here are using DB25s.
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Postby SlyCayer » Tue Apr 17, 2012 8:08 pm
Hi,
I ended up using 24 Anderson PP15/45 PowerPole Connectors and snapped them together... Made for a very clean and high current connections.
SlyCayer
Postby Evoforce » Thu Apr 19, 2012 2:14 am
Glad you found your solution.
"Energy is all consuming and it is never ending. It just changes form as it morphs through time and space... " Evoforce
        Several 5403 motors,  no time to build projects! Phoenix Racer(5303) crystalyte suspension mtn bike LiFepo4 72/20.  (409) crystalyte 48 volt hardtail.  In process... Phoenix Cruiser(5304)  LiFePo4 48/20.  First electric bike a 2009 XB 502-700 style, 36/20 sla scooter bike.  All charged by solar!
Evoforce
Postby Evoforce » Thu Apr 19, 2012 2:15 am
Molex connectors also work well.
Evoforce
Postby SlyCayer » Thu Apr 19, 2012 7:02 am
Yes, the molex would of also worked, but at 5A maximum it would of been a little short on the amps...
SlyCayer
Postby Evoforce » Thu Apr 19, 2012 2:17 pm
They also make molex for varying gauge sized wires. I'm sure you know this already but make sure that the andersons are securely held together. We know what the result is of a disconnected sense wire.
Evoforce
Postby SlyCayer » Wed Apr 25, 2012 6:28 am
Evoforce wrote:We know what the result is of a disconnected sense wire.
That would seriously suck, LoL, but my programmed software will not turn the battery one if one or more pack is not showing any voltage... The only way for the board to turn on charging or discharging is when the voltage will be between 2.4V and 3.8V and LVC will be at 2.8V and HVC at 3.65V, shouldn't be a problem, unless my software would have a bug, which would suck seriously.
SlyCayer
Return to Items Wanted
