I prefer lipo only because it's cheaper
Re: I prefer lipo only because it's cheaper
Postby cwah » Sat Dec 31, 2011 11:28 am
dogman wrote:Say your $450 of lipo lasted 400 cycles, that's more than double ( $1.25) the $.50 per cycle my first ping cost. Add another $150 for lipo chargers, and you reach about $1.50 per cycle. That first ping had the 1c cells, and the chargers have improved so chances are the cost per cycle is not so much different given the current price of a new ping. Assuming you got 700 cycles from a new 48v 15 ah ping, the cost is closer to a buck a cycle than fifty cents. But still perhaps at least 30-50 cents per cycle cheaper than lipo, and that includes the price of the charger, when the lipo calculation did not.
I agree in term of pure number of lifecycle lifepo4 is largely winner.
But if you do the math in term of usage (and not number of cycle), if we consider you do about 200 cycles a year, a lipo would last 2 years. And with 2 lipo would can end up using it for 4 years. I don't have the data about Lifepo4 shelf life, but I suppose we could agree that after 4 years it's time to change battery.
If you get a lifepo4 48V15AH (720Wh) with ping:
http://www.pingbattery.com/servlet/Cart ... d=24782801
- Weight: 7.5kg
- 485$ battery + 119$ shipping (to uk)= 604$ total cost.
If you get 3s*2p (zippy 6S1P at 5AH) you have a pack of 44.4V15AH (666WH)
http://www.hobbyking.com/hobbyking/stor ... _20C_.html
- Weight: 6*0.844g= 5.06kg
- 296.88$ batteries + 85.15 shipping (to uk) = 382.03$ total cost the first 2 years.
- 382.03 * 2 = 764.06$ total cost the next 2 years. (And this total assume that the lipo price remains the same 2 years later)
Ok, at the end you would have lost around 150$. And you also have to pay for additional charger. But you have a weight advantage, you can swap your lipo when needed and after 2 years you have brand new batteries. Also, we should consider that the technology evolve and after 2 years we will probably have better performing batteries.
What do you think of this calculation? Do you expect to use your lifepo4 for more than 4 years? Don't forget that batteries loose its capacity over years naturally (shelf life), so most likely the battery is not going to have much capacity after several hundred of cycles + 4 years in the belt.
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby mr.electric » Sat Dec 31, 2011 12:34 pm
Dogman's argument about Lifepo4 safety is valid. The added cost may be worth the peace of mind.
We are assuming Lifepo4 is safer to charge. Is that assumption true when we compare the newest hobby king Lipo packs - Turnigy and Zippy's to the Ping fully managed LiFePo4. Is the LiFePo4 less likely to set off the fire sprinklers at work? I am asking the Sphere because I have no facts to answer to this question only my assumptions that LifePo4 is inherently safer.
-Fat Sand Bike with 9c and 29ah pack
-Giants mascot scooter
mr.electric
Postby sangesf » Sat Dec 31, 2011 3:08 pm
Back in the day (3 years ago), I've had a lifepo4 cell (15Ah Yesa) pretty much dead shorted in my battery box, without knowing it...
Came back 20 min later to find it...
Worst thing was the cell was REALLY warm and bloated.. I'm sure it had vented and all, and I didn't use it after that, BUT.. no issue with it being "hazardous", by any stretch of the imagination..
I've also had the dreaded "electronic hawk" noise come from a pack that was WAYY over charged (4.6v per cell group), and although it didn't hold as much as it used to, it did work (at about half it's Ah it was previously.)
That pack is STILL running in my nephew's bike..
So yeah lifepo4 is REALLY SAFE!
sangesf
Postby dogman » Sat Dec 31, 2011 5:26 pm
I think your calculation compares 48v 15 ah ping with 44v 10 ah lipo. So its a bit off. Or do you mean 3p 2s 6s packs? Still a tad short, short enough to mean 100% discharges every day for my needs.
And tell me how many cycles you get, drawing the lipo down 100%.
I'm not buying it, till you compare the cost of headways or A123's. Per mile pings cheaper. But only if you need mere 2c cells to run your bike.
Again, make the argument for a shorter ride, where you only need to buy 5 ah to do the job and of course the lipo is cheaper. You can buy a much smaller pack. For those who's round trip is the right length, it's very hard to be the cost, weight and size of a 2p 2s 6s lipo pack. And you don't have to lug 15 ah for that shorter ride.
I agree lipo is better, thats why I own 3x as much lipo as ping. The decision has nothing to do with cost though, it's for weight, size and c rate that I bought a pile of lipo. But my lipo is never going to cost less than ping, per mile, per cycle, or per year.
Another thing that's beautiful about lipo is that you can weed out a bad cell anytime. Just rotate in a fresh pack. Can't do that easy with a ping, that's for sure.
dogman
Postby neptronix » Sun Jan 01, 2012 5:01 am
I just can't use anything other than RC Lipo for the time being. I have ran various bikes at all sorts of different voltage / AH configurations now.. 10S 30AH, 15S 15AH, 20S 10AH, and all sorts of combinations in between... all on the 13 lipos i bought a year ago as a complete newb :)
Price is definitely not the only reason.. modularity ( as mentioned above ), light weight, small size, and power output are 3 other areas where it totally wins. Safety and cycle life is where it loses.
If you have a good pack that you have cycle tested to make sure there are not any dud cells, hasn't been abused, and is properly specced for your application, you really can have your cake ( light, small, powerful, cheap ), and eat it too ( plug it in to a bulk charger and don't worry about even plugging it into a balancer until next year )
neptronix
Postby cell_man » Sun Jan 01, 2012 5:31 am
- Weight: 7.5kg
The LiFePO4 pack is 8% higher capacity than the LiPo that you are comparing, even though the ping was based on 48V nominal, and 3.2V * 16 or 51.2V is the apples to apples comparison, based on that, the ping has 768, and the LiPo would then have a 15% shortfall. On top of that, you would need to use the LiPo more conservatively WRT charge voltage and DOD so you'd want to use less than the available capacity, at least 10% and more likely 20%. The LiFePO4 already has an integrated BMS, that weighs a bit. Figure in 15% reduction in capacity to keep the lipo happy, a further 8% shorfall in the LiPo capacity, multiply that by the starting weight of 5.06kg and you now have a pack of 6.5kg compared to a 7.5kg ping which includes a BMS and can be charged from a simple charger, if calculated with 15% less capacity and 15% safety margin the LiPo equivalent is 6.8kg. Did I mention LiFePO4 is far less likely to burn your house down.
Now compare 1 of my offerings, apologies for the self promotion, just letting you and others know what is out there. A 12S 20Ah A123 pouch pack. Weight is 6.7kg all in, including BMS and some mechanical protection for the cells. Nominal voltage is stated as 39.6V, but lets call it 38V, it stays above that most of thime even with pretty high power, so lets say 760Whrs. Apply the same 15% reduction in capacity to the LiPO, to keep the cells happy and correct for the smaller capacity of the LiPo in your example and what do you have, the LiPo equivalent is 6.8kg, and that is without any BMS in the LiPo. Even if you use the full capacity of the LiPo, you have an equivalent weight of 5.8kg. A stack of 12 20Ah A123 cells is 5.95kg, if all I did was fit a power cables, a couple of balance plugs and shrink wrap, you'd have a pack of about 6.2kg as a guess.
The above pack will supply more current than most will ever need and a BMS upgrade for higher current is an option. Drop me a line if you are interested in prices, but they aren't bad at all. I really don't see how LiPo is head and shoulders above those figures, or any other cells for that matter when you figure in everything.
Visit http://www.EM3ev.com/ for our Ebike Kits and in-house battery packs. Online Shipping quotes to most popular destinations, with automated PayPal checkout.
Browse the site or drop us a line via the contact page: http://em3ev.com/store/index.php?route= ... on/contact
cell_man
Postby cwah » Sun Jan 01, 2012 8:45 pm
Ok I think you're right. Lipo is not always cheaper due to the added security measure we have to take (complementary AH margin) and in my example I didn't compare same capacity batteries.
I've seen that BMSBattery allows you to choose the discharge current from a lifepo4:
http://www.bmsbattery.com/packs/161-48v ... -pack.html
You can choose from 20A to 100A. Isn't 100A already quite good for performance bike?
And I've just discovered the NiCoMn batteries:
http://www.bmsbattery.com/48v/403-48v-1 ... -pack.html
388$ for a 48V15AH battery. It last 800 cycles and only weight 5 kg. Lifepo4 at 7.5 kg is 50% heavier and is more expensive at 485$.
Isn't this one the best value battery?
cwah
Postby BikeFanatic » Sun Jan 01, 2012 9:43 pm
- Weight: 7.5kg
The Ping includes a charger, and the lipo does not. So cost is now equal. If I were a noob I would go for cell man or ping.
BikeFanatic
Postby John in CR » Sun Jan 01, 2012 10:59 pm
The Lipo numbers are incorrect in real world use in other ways too. First, multiply cost by 1.1 , since about 10% of the cheapies are bad upon arrival or exhibit a bad cell shortly afterward. Then multiply it's weight, size, and price by 1.2 or 1.3, since you don't dare run Lipo low and need to carry extra. Then as a new Lipo user expect a significant risk of you killing one or more packs from improper handling. What's the average? I don't know maybe another 10-20% as a low estimate.
Now the biggie in terms of value, which is your time. The Lipo lovers have an extra hobby in addition to DIY Ebiking, and it consumes ridiculous amounts of time when added up. That hobby is fiddling with their precious Lipo battery packs, plugging/unplugging, monitoring, inspecting, carefully charging, and endless balancing. Let's call that number an average of 5 extra minutes per cycle, which is probably low especially considering configuring the packs and making changes. Even if you assign a crazy low value to your own time of only $5/hr, that more than doubles the seemingly low initial price.
RC Lipo packs have the smallest form factor of what is broadly available at this time, and that's their only real benefit, other than power density though I haven't seen anyone needing more than A123's power density, and much of that extra volumetric energy density is eaten up by having to carry extra to avoid discharging too deeply. They cost as much or more up front. They carry far far greater risk, and require inordinate amounts of time caring for them in a manner to make them reasonably safe.
These are the realities that make direct comparisons of $/wh or ml/wh or g/wh invalid.
John
John in CR
Postby dogman » Mon Jan 02, 2012 7:19 am
All too true. All reasons why price should be part of the decision, but not the first consideration. Put it down around 10th or so on the list. First on the list is stuff like you just said.
Personally I don't spend that much time fussing with the lipo, other than returning it to a safe-ish storage. And I do pay the price, by losing a pack from time to time. I'd rather just buy another pack than fuss with it endlessly. Or spend a fortune on monitoring stuff.
dogman
Postby miuan » Mon Jan 02, 2012 8:34 am
So the 12S4P A123 pack holds about as much energy as 10S2P HK lipo.
While the A123 pack costs $350, the cheapest HK lipo equivalent can be had for $110.
I'm talking the hardcases that are said to occasionally burst on their own. I received 40 of them so far, all but one run great and stay in balance for 10's of cycles. I can easily strap them together with velcro and throw the hardcase bundle in a padded pannier bag.
Unlike the mythical depth of discharge, the time factor IS a biggie, no question here. If it wasn't my hobby, I'd certainly go with a plug n play battery, of which the A123 is a prime example.
miuan
Postby John in CR » Mon Jan 02, 2012 8:21 pm
"Mythical DOD"???? I'd like to hear about a cheapie Lipo pack discharged regularly to 90% or greater DOD and lasted even close to 500 cycles. Don't forget the 3-4X that balancing time goes up. BTW, fiddling with batteries has to rank up there with watching grass grow or paint peel as far as hobbies go.
John in CR
Postby French » Fri Jan 13, 2012 2:35 pm
I have one of Cell_Man's A123 52v 11.5ah triangle packs for both myself and my wife's bike. I have two chargers, so after the ride I simply hit the switch of the charger, plug it in, come back 1-2 hours later, unplug, and turn off. It costs me about 1 minute to charge both bikes. These batteries should last us 5 years+, as we casually ride with our little kids 2-3 times a week for about 10-15 miles per session. I know that I paid a good premium for the battery packs, but the simplicity is priceless and the weight savings/performance value vs. Lipo in my opinion are marginal at best in my situation.
My life is busy enough, I don't want to worry about setting my house on fire, or myself should I crash!
In the end, to each his/her own!
Two Treks, 4900 & 4300 (wife), MAC 8-Turn, A123 52v 11.5ah Triangle batteries
French
Postby mvly » Fri Jan 13, 2012 3:06 pm
I just prefer Lipo because of the configurability. I am sure if you contact cell-man and give him a dimension and he might be willing to customize your battery exactly to the dimension you give him. However for me, I would like to add/delete cells and check them out once in a while. I know that a BMS can do that for me, but after reading a lot of stories about failing BMS and having a defective BMS myself, I would prefer to complicate the charging a bit for better maintenance of the battery. John is right about all the increase in price of Lipo if you factor in all the disadvantage of Lipo. But as for now, I think I will save my money and wait for LiMn to get cheap enough. It's proven to be better and lighter than LiFePo4.
mvly
Postby neptronix » Fri Jan 13, 2012 3:24 pm
John in CR wrote:"Mythical DOD"???? I'd like to hear about a cheapie Lipo pack discharged regularly to 90% or greater DOD and lasted even close to 500 cycles. Don't forget the 3-4X that balancing time goes up. BTW, fiddling with batteries has to rank up there with watching grass grow or paint peel as far as hobbies go.
95 cycles and counting to 90% DOD, only needed to balance them twice so far... actually the second balance was not needed at all. Still delivering the full 5AH.
RC Lipo is great. Sort out the duds from the studs, treat them nice, and you can bulk charge to 90% DOD ( 5% off the top, 5% off the bottom ) for hundreds of cycles.
Nothing beats them for the weight/size/energy. If i was a daily commuter, my second choice would be the A123 cylindricals though, as i'd be up to about >300 cycles by now.
neptronix
Postby sk8norcal » Fri Jan 13, 2012 5:37 pm
French wrote:I have one of Cell_Man's A123 52v 11.5ah triangle packs for both myself and my wife's bike. I have two chargers, so after the ride I simply hit the switch of the charger, plug it in, come back 1-2 hours later, unplug, and turn off.
is it necessary to unplug the charger ?
I think I will forget to do that half of the time....
sk8norcal
Postby veloman » Sat Jan 14, 2012 3:53 am
If you want to get your bike running, not have tons of headaches and buying extras all the time, go Lifepo4, hands down the best choice. Ping even includes a charger. Plug and play. If you want a challenging hobby, sure lipo and makita lith-ion cells are a good choice.
Factoring in your labor time, lifepo4 is by far cheaper if you are just starting out. FAR FAR cheaper.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby French » Tue Jan 17, 2012 1:11 pm
I leave the chargers plugged into the wall.
When I said unplug / plug, I meant from the charger to the battery and not from the charger to the wall. :D
French
Postby 999zip999 » Tue Jan 17, 2012 2:24 pm
Just put it on a timer and walk away. Yes I would keep my charger unplug or on a timer to cut the power to it if not in use.
999zip999
Postby veloman » Wed Jan 18, 2012 12:18 pm
999zip999 wrote:Just put it on a timer and walk away. Yes I would keep my charger unplug or on a timer to cut the power to it if not in use.
I use a surge protector that has an on/off button. As soon as it finished charging, I unplug from bike and flip the switch on the surge protector. If i leave my charger on it stays a little warm. Best to be off when not in use IMO.
veloman
Postby cwah » Thu Apr 19, 2012 6:56 am
Just an update on the batteries specs:
- Lipo are still the best in term of performance, especially with the new zippy compact. Even at 85% usable capacity it still top at 150wh/kg. It's however the most expensive now.
- NMC are the cheapest one. Too bad about the low C rate
- A123 are much more expensive, but has the most value on long term because of its cycle life.
cwah
Postby Pure » Thu Apr 19, 2012 10:32 am
It really depends on your needs. If you want safety, then go LiFePo4, if you want high rate of discharge and up front savings, go LiPo. If you want both safety and a high rate of discharge, go A123. Price isn't as important as having a battery that fulfills your requirements.
My only complaint about paying through the nose for A123 (and other safe chems) is that with the way battery tech is evolving, and prices are going down. You pay for a battery that can last 5 years, but is out dated and worth half (new) of what you paid for it in 2-3 years.
Mongoose DH
X5304
60V20Ah LiFePO4
I'm polymerized tree sap and you're an inorganic adhesive, so whatever verbal projectile you launch in my direction is reflected off of me, returns to its original trajectory and adheres to you. So there!
Pure
Postby cwah » Thu Apr 19, 2012 1:40 pm
For me Lifepo4 is "expired" now. Why get the heavy lifepo4 when you can just get the A123 that have higher volumetric density (wh/kg) and higher C rate? They are both as safe.
And lifepo4 is barely cheaper than A123. So I don't see why I would ever get them.
cwah
Postby veloman » Thu Apr 19, 2012 4:28 pm
Pure wrote:It really depends on your needs. If you want safety, then go LiFePo4, if you want high rate of discharge and up front savings, go LiPo. If you want both safety and a high rate of discharge, go A123. Price isn't as important as having a battery that fulfills your requirements.
Are prices falling that fast? I am skeptical.
Isn't a123 just a brand of lifepo4?
I do think a123 is the best all around ev battery. I got a cellman pack, haven't used it much yet though. My "2c" lifepo4 with about 200 cycles on it is doing great.
veloman
Postby Pure » Thu Apr 19, 2012 4:34 pm
Perhaps not that fast but it does seem to constantly be evolving/getting better. I know the LiPo of 2 years ago was twice the price and dangerous as hell, with crap discharge rates.
Mongoose DH
X5304
60V20Ah LiFePO4
Pure
PreviousNext
Return to Battery Technology
Users browsing this forum: No registered users and 6 guests
