Charging a 36 volt Ping battery directly from photovoltaics.
Solar, wind, hydro and other non-fossil sources of electricity.
Postby shawname » Tue Apr 10, 2012 4:18 pm
I use a 36 volt Ping battery to power my electric bicycle. The charging steps look like this:
Photovoltaics to charge controller to battery to inverter to battery charger to battery management system to battery. A lot of steps, a lot of inefficiency.
I'd like to experiment with simplifying to: Photovoltaics to BMS to Battery.
Mr Ping does not want more than 42volts going into his little ping. I am using a 5 amp battery charger right now. I am thinking about assembling a 42 volt 3.5 amp panel out of eighty four 3x6 cells. A diode will prevent discharge.
Anyone tried this, or know if it will work or not? :?:
cheers,
Shawn
shawname
Re: Charging a 36 volt Ping battery directly from photovolta
Postby dogman » Sat Apr 14, 2012 11:11 am
I would think the main issue would be regulating the voltage. A 36v charge controller would be nice.
An alternate solution might be three 12v bms's. Then charge using the 12v charge controller.
dogman
Postby neptronix » Sat Apr 14, 2012 11:22 am
An RC charger that can do 10S-14S can simplify this. an iCharger 1010b+ can push out 43v tops.. the hyperion 14S can put out quite a bit more.
Most RC chargers are designed to run off 12V batteries. You can skip the inverter stage and the end result will be more efficient. It will cost you, but yeah..
neptronix
Postby Lebowski » Sat Apr 14, 2012 12:22 pm
would it be possible to put so many panels in series that you get over 100 V
out of the solar panel ? If your charge setup is like mine (eFuel 18V30A into iCharger 1010),
probably your power supply will accept the 100V DC directly. A modern
switch mode power supply does not need AC but will work of DC too.
Lebowski
Postby shawname » Sat Apr 14, 2012 3:57 pm
dogman wrote:I would think the main issue would be regulating the voltage. A 36v charge controller would be nice.
I was thinking that if the photovoltaics put out 42 volts max, that as the Ping battery charged, the voltage would also increase, until no current could flow into the battery.. Wishful thinking?
I did look for 36 volt charge controllers and fund this:
PT 36-5A, 36V here http://www.altestore.com/
It is a 36 volt mmpt charge controller with a 42 volt cutoff!
Thanks!
shawname
Postby shawname » Sat Apr 14, 2012 4:01 pm
Lebowski wrote:would it be possible to put so many panels in series that you get over 100 V
Hmm, interesting. It would take 200 solar cells as each one puts out .5 volt. That's a lot! Thanks, but hopefully I can find a simpler solution.
Shawn
shawname
Postby nechaus » Sun Apr 22, 2012 10:44 pm
iv made a few solar panels in my time.
its alot of soldering man, and its a pain in the ass.
i recommend to not use the 6x6 cells as they break really easily
Magic pie Dual Suspension
Peak 6kw Air cooled
Kelly controller (mini kbs series, smaller than a coke can, can do 80+ battery amps peak, Favorite small controller. Really punchy)
20s 16ah
60 kmh,
Safe, Beautiful handling.
nechaus
Postby dnmun » Mon Apr 23, 2012 3:12 am
ping uses 45V for the charging voltage on his 36V lifepo4 packs, not 42V.
42V is for the 10S limno4 packs.
dnmun
Postby shawname » Mon Apr 23, 2012 6:28 am
dnmun wrote:ping uses 45V for the charging voltage on his 36V lifepo4 packs, not 42V.
Yes, I have measured the voltage at the charger. But in a personal email with Mr Ping he recommended that I limit the voltage to 42 to avoid overcharging.
I did find this Mppt charge controller:
http://www.altestore.com/store/Charge-C ... ler/p1380/
Which seems to be custom made for the application.. The cut off voltage is 42..
shawname
Return to Alternative Energy
